Back to:
Tags:
Scanport N7 / 17
Screen is on but picture dose not show... cables...
posted by Speedymars on Oct 23, 2007
If you look closely the image is visible but very dimmed.  if flashlight pressed against screen it lights up the picture better. Brightness and contrast were turned to max and did nothing.  Everything else works properly just screen is dimmed to the point were you have to (HEAVILY) strain your eyes to see.
If any solutions please post.
(Picture below is with flashlight pressed up against screen.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 24, 2007
FixYa! (100)
KatFishGR
Rank:Guru Guru
Rating: 88%, 89 votes
Solution, replace monitor with a new one.
I have found, at my shop, that getting parts for these things can be pricey and by the time I charge labor as well, could just buy a new one.
Probably a bad internal power supply or the inverter that powers the bulb(s) went out, which is sometimes built in with the power supply itself. If, and I stress IF, the parts are available, be prepared to pay more than its worth.
Pick up a new one, shop around on different brands. Some manufacturers offer 3 year warranties. ;)
Rating Locked! (?) Speedymars has rated this solution as FixYa!
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Screen is on but picture dose not show... cables connected:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
salut, am si eu un monitor 190g de le philips, si nu mai...
Monitors
my monitor quit and wont come back on it trys the light...
Scanport N7 / 17" / 16ms / SXGA 1280 x 1024...
When the adaptor is plugged in the light on the adaptor...
Lost the Power Supply to this monitor. Can't seem to find...
This message happens even at startup. I've tried changing...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
