Question about Krups Small Appliances Espresso Machine
Krups model KM7005 water wont heat
Krups model KM7005 grinder works fine, but water won't heat and hot plate stays cold. KM7005 grind and brew. Water not heating or pumping, but grinder still working. Worked fine until our power went out last week.
  • Anonymous Mar 16, 2014
    Heat and pump not working
    Scholar:
  • 22 Answers
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Oct 19, 2009
  • SmallApplFix Jan 31, 2010
    Helped denovo, who's now enjoying coffee once agin.
    To date, have now helped 13 people with exactly the same problem with this rig. Looks like a weak-spot, or design fault. So easy to fix.
    Once again (see above), I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz
I have the same problem and have emailed 'smallapplfix' and the address he provided. Hope he really can provide some assistance...Got my fingers crossed!
Posted on Oct 22, 2009
My Krups km7005 will not heat the water, i need a wiring diagram and the tool to take it apart, thanks Dennis
Posted on Jul 20, 2009
Krups ea 8250
If it doesn't grind , than there is no coffe , it will surely come as water .
Grind it first , and than brew the coffe .
Oct 24, 2013 | Coffee Makers & Espresso Machines
Why, within a year, will my Krups KM7005, not draw water through the filter and into the pot??? Nothing is blocking the flow. Perhaps the heating element is no longer working to prepare the water. The...
you are correct ? i hope the heating element must work to boil water through the machine and check for the thermal fuse hidden with in the in line cord inside the machine. check all with test meter on continuity selection for electrical flow. thermal fuse got too hot and save the machine ,but the element is not on ! thermal fuses are not resettable ..and have to purchase them at your local Radio Shack 8-10amp rating in cases. and about $ 8.00 us each >^.^< good luck, let us know ?
Mar 15, 2010 | Krups Coffee Makers & Espresso Machines
HOT OR COLD WATER IS NOT BEING PUSHED THROUGH THE PUMP
Jan 12, 2010 | Krups Small Appliances Espresso Machine
A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
Dec 16, 2009 | Krups Small Appliances Espresso Machine
Krups KM7005 coffeemaker/grinder does not heat or drip the water
The heating plate is actually your hot water heater for the unit and it has most likely failed. The water flows through the heating plate and heats the water for brewing. Krups replaced my whole coffee brewer.
Dec 15, 2009 | Krups Small Appliances Espresso Machine
Krups grind & brew. It grinds but water
Check to see if your heating plate gets hot when it is on, if it doesn't your water heater/heating pklate has failed.
Nov 20, 2009 | Krups Coffee Makers & Espresso Machines
My Krups Grinder Brewer has stopped pulling water though the system. It just stays in the resevoir. Grinder part seems to be working fine.
The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 09, 2009 | Krups KM7000
Krups KM7000 won't brew
Your heating plate is your hot water heater, and most likely failed. Krups replaced my whole unit.
Oct 07, 2009 | Krups Coffee Makers & Espresso Machines
Krups km7005 water not heating nor hot plate
After a weekend on the workbech, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Aug 01, 2009 | Krups Small Appliances Espresso Machine
Apr 10, 2009 | Krups Coffee Makers & Espresso Machines
Krups Small Appliances Espresso Machine Logo
1,147 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
