Question about Sanyo DS31520 31" TV
Funny half screen problem
I do not know the origin of the problem, but my television has been working great until recently. Now when I turn my television on I can only see the upper half of the screen and the shapes are distorted (people appear to be like midgets). The bottom half is black. The wierd part is that the upper half gradually gets bigger and bigger pushing down the black part and over maybe about 45 minutes I am able to watch the TV full screen or maybe with a half-inch left on the bottom. What is happening and is there a way (ie setting to change) to fix this? I have the exact same problem on my Sony KV-35XBR48 but I notice when I tap the casing, the screen goes FULL size immediately?? Any ideas?
    Genius:
  • Sanyo Master
  • 1,550 Answers
Maybe you got dried capacitors near the vertical IC or the IC himself are damaged you need to be atech for make the rapair because is dangerousli make it
Posted on Jun 02, 2009
Have a large black box in center / lower half of screen - How do I get rid of this?
check your CC settting, Closed Caption and make sure it is turned off..
Sep 21, 2014 | Televison & Video
ViewSonic N2700 Blinking power button
replace the power supply, buy it on the internet by looking up the model number on the power supply. I have this tv and it did this until I ordered a new one. it runs hot and has a loud fan.
Jun 14, 2008 | ViewSonic N2700W 27 in. HD-Ready LCD...
Plasma TV Background noise
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
May 28, 2008 | HP PL5000N 50 in. HDTV Plasma Television
My Screen!!!
hi
restatrt your system and press F8 KEY UNTILL U GET MENU.
then go to best configuration or safe mode.
then if u get normal window change your display resolution to 800x600 or 1024x768.if u get differ reso.
restart in normal mode u get good display in original content.
pls notify this solution
Mar 23, 2008 | Toshiba Satellite R10-S802TD Tablet PC
Green Tint on half of the screen
This is most likely a defect in the optical unit (about $1500.00 part). If out of warranty probably will just have to live with it. Those op units are also hard to get.
Jan 15, 2008 | JVC HD-61Z575 61" Rear Projection...
Rolling menu on screen
sounds like you have it in demo mode. In the menu will have it labeled demo on or off
Dec 09, 2007 | Zenith B32A24Z 32" TV
Top half of screen blacks out
Today, after speaking to the Sansui Manufacturer representative from Japan. He stated that all you need to do is to turn off the closed caption from the TV remote and not the DVR remote. Black screen can occur at the top half or the bottom half of the screen depending on how it was originally setup during installation. Try this and hopefully this fixes the problem.
Oct 06, 2007 | Sansui HDPDP4200 42 in. HD-Ready Plasma...
I have a Mitsubishi VS-60.. With a Picture
Vertical IC outputs , vertical Capacitors are most like the culprit on your deflection panel. good luck
Aug 16, 2007 | Mitsubishi VS-50501 50" Rear Projection...
Screen just split in half
Is the tv still in warranty? The problem is the upper buffer board, it's a small board that controls the upper portion of the screen. You will have to consult a service center to get it, it's very easy to install
Apr 15, 2007 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
Nope, Sorry to tell you, there is most likly a coupling capacitor or the vertical sweep IC itself could be defective. Although if you have had some sort of solid state Printed circuit board training, this should not be to hard to find, with a can of freeze spray. Unfortanatly this set has no user replacable parts inside of it, as everything is soldered into place and there is no easy fix. Although depending on how old the set is, is going, Im sure, to determine if you want to invest any cash into this thing. Without any training it would be a crapshoot Im afraid! So stay safe and seek the assistance of a pro. Good Luck Please do not forget to rate this!
Oct 16, 2006 | Sanyo DS31520 31" TV
Sanyo DS31520 31" TV Logo
202 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
