Question about Magellan Maestro 4040 GPS Receiver
Magellan wont get signal?
My gps works great except for the fact it won't pick up a signal. how do i fix that?
    President:
  • 1,111 Answers
Charge the battery fully, then set it outside in clear view of the open sky. it may take as much as 30 minutes to acquire the sats if that fails, try and leave it out longer...does it appear to try and link to ANY sats. on the map screen in the top righ t corner is a icon with bars in it, tap that and you should see it trying to acquire sats. if not, you might have other problems
Posted on Jun 03, 2009
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Road mate 700 won't pick up satellite signal
If this unit has an internal battery it may be bad, other wise I would reload the software or get a updated version of the operating software. Have you contacted Magellan?
Dec 03, 2010 | Magellan RoadMate 700 GPS Receiver
DOES NOT PICK UP THE SATELITTE SIGNAL
Sorry but you most likely have a major component failure in the GPS + ANT on the motherboard. If the unit is under warranty send to Magellan.
Oct 03, 2010 | Magellan Triton 400 Handheld GPS Receiver
I attempted an update to the map software version 2.62 or 3.61 Rel1. Something went wrong and the unit will now power on but only to the blue screen with Magellan logo and the black bar on the bottom. I...
run the update again..if it wont take it or wont see the 4040, it gets a little hairy to get them running again, but it can be done.
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
bill
Standing Member of G.O.T.
Sep 13, 2010 | Magellan Maestro 4040 GPS Receiver
GPS wont work!!
most likely the power port is damaged and needs replaced.
i repair those magellan gps if you need help. if i cant fix it there is
no charge. wmetz@comcast.net
May 28, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan 760 no satellite signal
I got a Roadmate 760 from my employer to use. It won't pick up my current location and is not working right. Help!
Jun 14, 2008 | Magellan Roadmate 760 GPS Receiver
Can't get correct update authorization code
get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.i own the 800 and the mastreo 4000 works great.
Feb 13, 2008 | Magellan RoadMate 700 GPS Receiver
No gps signal
http://www.tomtom.com/support/solution.php?GID=1&PID=1682&SID=0&CID=223&Language=1&query=wont+navigate&FID=386
Nov 04, 2007 | Tomtom GO 700 GPS Receiver
Loss of signal
Leslie, Not updating your GPS isn't going to cause signal loss. Push the options key, go to configuration, then to diagnostics, scroll down.. select reset gps. it will say it takes 5 min. to relocate.. etc. see if that fixes it. If it doesn't fix then when you restart your unit and the user menu appears. Press "-" key and "repeat" button at the same time.. then select clear gps user data or.. user data gps... something to that nature.. Hope this works out for ya. -Dan
Oct 18, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan GPS 310
to reset the unit hold down the right arrow while turning it on this fixed mine!
Mar 15, 2006 | Magellan GPS 310 GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
570 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
