Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
Lights just flash on controller and wont move jet 3 wheel chair, it is the secondd row of ligths on the controller, the ones that indicate speed. They are flasing steadily
Lights just flash on controller by joystick and it wont move or do anything jet 3 wheelchair help!!! the second row of lighton the controller, the speed indicator lights flash steadily.
  • dcolla May 11, 2010
    How many lights flash? How many times do they flash? If you try to push the chair does it move?
    Problem Solver:
  • 7 Answers
Check that you don't have the charger cord still connected or the motor disengaged.
Posted on Jun 01, 2010
Same thing happened to my Nanna you need to get new batteries, good luck
Posted on Aug 23, 2014
Why controller light flashes but wont work
Flashing lights on a controller are showing you a trouble code. To find out what the code means, count the blinking LEDs.
Here's a link to Pride's troubleshooting guide for the Jet 3:
http://www.pridemobility.com/includes/download.php?f=troubleshooting/INFINFB2045_Jet_3_Ultra_Troubleshooting.pdf
Feb 05, 2015 | Jet 3 Ultra Power Chair
How do i reset a jet 7 mobile wheelchair
did you put it in lockout accidentally? try this! turn off chair, press and hold the on button till a beep is heard, push and hold the joystick forward till a beep is heard, then pull back and hold joystick till beep is heard, turn off, and turn on. it should work now?
Sep 04, 2012 | Jet 7 Portable Power Chair
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
How do I know if my jet 3 ultra is charging? I just bought a used one today and do not have a manual
The chair should have a meter on the rear panel where the 9 pin connector for the joystick plugs into the chair when you plug in the charger cord the meter should move up and the lights on the joystick should flash indicating the charger is plugged in. When the chair is fully charged the meter should read zero or bounce up and down. Hope this helps
Feb 02, 2011 | Jet 3 Ultra Power Chair
Jet 3 flashes "code 7".
The VSI joystick controller of the Jet 3 with a flash code of 7 LEDs flashing on the battery condition display indicates a possible joystick fault.
The most likely problem is with the joystick gimble. You can also get a 7 bar flash if the joystick is out of the neutral position at start-up.
Run the joystick in a circle and back and forth feeling for any sticky or broken/dead spots. Check to see if the spring and gimble come back to center when you release it. Turn off the VSI and try centering the joystick. Turn the VSI back on and see if you can get the fault to clear.
The only recourse is to have the unit rebuilt or replaced . A rebuilt VSI will run about $500 and a new one about $1600. For this reason it is best to check with your insurance before performing the work to see if its a covered item. Hope this helps
Nov 30, 2010 | Jet 3 Ultra Power Chair
When switched on power light flashes.
How many flashes? Count number of flashes should be a slight pause then flashes the same number of times . Your manual will give you flash codes and you can determine what the problem is. If all the lights are flashing and there is no pause the chair could be in "lockout" Your manual should tell you how to get the chair out of lockout I think that Pride uses the joystick to get it out of this mode.. Turn the chair on move the joystick forward till you hear a beep then move the joystick to the rear until you hear another beep release the joystick and the lights should quit flashing Hope this helps
Aug 12, 2010 | Pride Mobility Products New Pride Mobility...
I have a power chair it is a jet 3 ,the lights flash , i know there is a code to reset it , so can you help me. i have had it repaired before and they just reset it but i need to now how,
Hi. Different numbers of LED's flashing mean different faults.
Your machine can be in "lock " mode.
To unlock it, turn the machine on.
Move the joystick full forward until it beeps.
Then move the joystick full reverse until it beeps.
The machine should then work normally.
If you still have flashing LED's, count the flashes between the pauses, and let me know.
Good luck. Neil.
Jul 05, 2010 | Jet 3 Ultra Power Chair
Jet 3 power chair power lights just flash, no sequence of flashes
hold joystick back, press on button, move joystick forward, then let go.
Feb 17, 2010 | Jet 3 Ultra Power Chair
All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
Apr 28, 2009 | Jet 3 Ultra Power Chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
Mar 27, 2009 | Pride Mobility Products New Pride Mobility...
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
1,097 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
