Question about Toshiba 50H82 50" Rear Projection Television
PICTURE PROBLEM(white hazy picture)
WE RECENTLY MOVED OUR TV, AND NOW THE PICTURE IS "FOGGY". IT CAN BE BEST DECRIBED WHEN ON SATELLITE RADIO STATION, THE WHITE LETTERS OF THE SONGS AGAINST THE BLACK SCREEN ARE SURROUNDED BY A WHITE HAZE. WHAT MAY CAUSE THIS? I have the same exact problem. I cant adjust it enough with the remote it is a mitsubishi 55" projection tv.
    Scholar:
  • 150 Answers
Hi, symptom is caused by mis-adjusted focus, theres mechanical adjustment on lenses, and theres electrical on focus block, if tv was recently moved I would guess it`s mechanical, I strongly recommend you get a tech to do this, good luck video-tek.
Posted on Jun 02, 2009
Video problem on my Proscan LCD TV.
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
May 06, 2010 | Televison & Video
Do I need to ever clean the bulbs and mirror?
Only if your picture looks hazy or foggy and not clear.
If you do not know what you are doing or haven't done it before call your local tv repair shop.
Jan 20, 2010 | RCA HD52W59 HDTV Projection Television
Excessively bright whites...has a haze around any white items. all other colors are fine.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look white,dull, red/orange, etc. You may even see white halos around images.
Here is a photo of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution
What you will need to do is replace the coolant and clean the crt lens. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos, step by step instructions, etc.
May 12, 2009 | Televison & Video
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
FOGGY-HAZY PICTURE
The contrast setting should always be more than the brightness setting, it's purely common sense to have the black levels dark and the white levels light. I advise your brightness to be 40, and your contrast to be set to 60.
You shouldn't alter the hue, as most manufacturers would have spent significant time balancing this anyway, so set this to 50 and leave it alone.
The saturation shouldn't be altered too much, the best bet is to set this to 55 and let it be. Also, the colour temperature shouldn't be changed atall, so set this to the default setting and leave it alone.
As for the sharpness setting, this should definitely be set quite low. I advise setting the sharpness to 40, and the reason for this is most people assume that the higher the sharpness the better quality and detail, and they're completely wrong.
If you do what I said, you should end up with a crisp, smooth and colourful picture.
Nov 29, 2008 | Televison & Video
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
The TV is only showing half of the picture
Hi Bigtate,
There is not much for me to go on with your description but here goes,
I suppose you have a convential TV set with a glass picture tube and not one of the new types with the large screen slim style displays!!!
If it a glass type picture tube then the following assumptions are made.
I hope yopu have not shifted house recently and moved the TV around???
If you have its possible the Yoke (its a device on the neck of the Picture tube that controls magnetically the scanning dot) may have moved and only is letting you see half a picture...
This is a long shot but it could be the cause..
Now the picture is supplied to you by a fast moving dot of light (Black & White set) that scans from the top of the picture and moves very fast down to the bottom of the screen, then flys back to the top of the screen and starts all over again during this process the dot lights up the picture tube to provide you with
the picture you see... (On a colour set there are three dots)
Its quite a complex process and its all controlled by electronics inside the TV receiver.
If you are getting only half a picture then something is causing the dot to only turn on for the lower half of the picture during its write time to the glass screen,
You dont say if the half thats off is white or black, so there are many things that the service technician needs to know before even starting to look for this fault. During the dot doing its write cycle down the sceen, when it reachs the bottom and flys back to the top of the screen it receives a synchronous pulse from the TV station, and this TV signal is critical in making sure you see the same picture as is being sent from the TV station.
Sometimes this sync pulse from the TV station is very weak and so your picture may float up and down the screen trying to lock to the incoming signal.. this just may be your fault.. but you dont say if the half of the picture that you see is floating or not..
Your situation may be that your TV has partially locked to the station signal and your aerial may be problematic,
but then you dont say if its on just the one channel or all of your station channels. So there needs to be more analysis of your situation prior to a positive answer being provided....
Sorry I can be of more help...
From YUBEUT...
Nov 10, 2007 | GE 31GT660 TV
Samsung digital cam vp-d351
First try to take photo in a sunlight, if the photo is still hazy then clean the lense and make sure you dont put your finter anywhere in front of the camera.
If the photo is still hazy then it could in internal camera fault.
If the photo is fine in the sun but its blurry in the dark then take photo with flash if thats ok then you just need more lighting.
Also make sure the ISO Rating is auto or 100 many people set ISO to 800 and then forget about it. It causes hazy photos in the dark
Nov 02, 2007 | Fuji FinePix F401 Digital Camera
Phillips Magnavox 60 inch Projection Tv
I have a white glow around all the white letters and just all the white colors in general. What do I do ?
Sep 24, 2007 | Philips Magnavox 9P6034C 60" Rear...
Toshiba 50H82 50" Rear Projection Television Logo
189 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
