Question about Numark TT1520 Turntable
It wont turn on!!
Any ideas i think i blew something motor is fine so is the fuse??
  • medsone Oct 29, 2007
    nope no lights or anything!! i checked the plugs fuse it wasnt that and its on the right voltage?
    could you help?thanks!!
    nope!! no power at all i checked all the fuses i could find but i'm very new to this! could you help?
  • 515 Answers
If the fuse and the voltage are on the correct setting, the only other thing it could be is that the transformer fried, which is a common issue for Numark turntables. You will need to get it replaced professionally, as it is not an easy fix. Expect to spend anywhere from $70-100 parts and labor.
Posted on Nov 14, 2007
    Novelist:
    Champion:
  • 382 Answers
Are you getting no power what so ever from the turntable? No lights, or leds?
Posted on Oct 28, 2007
The push button starter doesn't make the motor turn over.
Sounds like you blew a fuse when you shorted the wires.
Need more info in your questions. All Vehicle questions should include Make, Model and Year of vehicle.
Sep 28, 2014 | Cars & Trucks
I crossed terminal leads on battery and blew something
There is a main fuse near the battery. It looks like a strip of metal, (which it is). Hope that's all there it is to it. If the bike wont run expect a damaged computer.
Jul 26, 2014 | 1993 Honda CB 750 Nighthawk
Microwave blows fuses
A short likely in the wiring for the light or at the safety switch embedded on the side where the door closes----be careful as a 20 amp fuse takes something major to take out.
(for it to blow)
This might be best left to a qualified service person.
Dec 22, 2012 | Microwave Ovens
1993 Chevy lunimina Broke down 2 times in 3 days done pretty much the same thing both times ill be driving down the road and the car will just stall out while driving changed a blown fuse fir the dis and...
I don't want to seem like a smart ****, but the blown fuses were telling you that something with the component that it was protecting is going bad. So changing the fuse the first time was a go idea, the second time was not. It told you, that something was failing and you refused to pay attention.
But at least you know which fuse blew, so now all you have to do is find out what it was protecting and replace it or what feeds it.
Aug 28, 2011 | 1993 Chevrolet Lumina
My 1992 flt wont turn over, I think I may have blew a fuse or something when i started to turn over the ignition with condensation on the motor, what should I be looking to fix or replace
M8, condensation on the motor would not normally blow a fuse. Thge most common problem would be a battery connection. Check for corrosion (can be removed with hot water) or loose terminals. Try to loosen terminals and give them a wiggle and re-tighten them. If this fixes the problem then the terminals will need to be thoroughly cleaned and sealed (petroleum jelly works fine). Hope this helped
Mar 16, 2011 | Harley Davidson FLHT Electra Glide...
Driver side door won't lock electronically
very common problem is the door lock actuator. i would recommend replace that. a good idea also would be to remove the door panel and check all the rods that connect to the assembly and make sure one didnt pop off.
Oct 16, 2009 | 2003 Honda Civic
The turn signals wont work, the windows wont roll
Check all fuses under hood in fuse/relay box, or power distribution box?
Oct 02, 2009 | 2002 Dodge Intrepid
Heat worked fine all winter. Turned on A/C and blew a fuse. Replaced 3amp fuse and worked for a few minutes and blew another fuse. Checked all connections, filter, obstructions, need help...
If your blowing fuses then you have something grounded or shorted. By grounded I mean a wire has come loose and is touching the cabinet or a part that allows it to go to ground or your motor, capcitor or compressor is shorted.
Apr 25, 2009 | Heating & Cooling
Numark TT1520 Turntable Logo
153 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
