Question about Datel Action Replay for Nintendo DS
Get my action replay to not say unknown game and work:)
I tried to get my cheats for pokemon pearl but it said unknowon game so i went to wiki and they said to do this -_- PASTED -_- (when you see the green bar that says unknown game, right under it should be a code. write that code down and take out the game but leave the action replay in. then tap the green star and then press the a button. enter the name of the game, tap next, then enter the code that you copied earlier) i then did it but it went all blue and red stripey on me and froze so i did it again checked everything over and it still went buzzzy on me so i checked for more awnesers and there werent any so i just want to be able to fix the unknown game thingy on the main menu on my action replay
Sutebe
  • 11 Answers
SOURCE: ACTION REPLAY DS PROBLEMS
The AR should come pre-loaded with codes for most games. If you followed the directions carefully and there are no codes for your game I suggest following the AR update instructions in the booklet to reset and download the most up to date codelists for your games.
Posted on Jan 04, 2009
SOURCE: my action replay won't recognize my pokemon pearl
the solution is to not pull the action replay out while it is saying this product is not licensed or endorsed by nintendo-the way to fix it is to look at the bottom left corner of the top screen write it down go to add new game typy in the name of the and it will go to input display (i think) and you type in the number you wrote down the basd thing is you have to type in the cheats all over again and even the ones it came with trust me I KNOW
Posted on Mar 25, 2009
  • 89 Answers
SOURCE: action replay says unknown on platinum and pearl
To Answer your problem action replays don't come with ever game in its date base so you can manually put codes in. im assuming it came with a cd so you can update it and put new codes in the unknown message usual means it has no codes for that game hope this helps
Posted on Jul 28, 2009
  • 3 Answers
SOURCE: my action replay won't recognize my pokemon platinum "unknown gam
the ID is diff, When you turn on AR put in the cart when it tells you, take note of the letters and numbers below the "unknown game" bit. put ar back in. click the green and white button, select the game from your list and click EDIT. if the name ios already in click next, then put in the letters and numbers from before, click next. Done. it should recoongize th game now. if it doesnt contact datel :D
Posted on Aug 17, 2009
SOURCE: my action replay wont reconize pokemon platinum
k you know how its on the list of games what you need to do:
1:put your game in
2:if you look in the bottom left corner its got a code copy it
3:look for your game in the list
4:put the indicator on it but dont select it
5:instead of selecting it hit the pencil sighn on the touch screen
6:then it should show up like how you input ar codes . since its already got the name in it press next
7:erase the code thats already set in and change it to the one you copied down then svae changes and your done
hope this helps out
Posted on Sep 28, 2009
Testimonial: "thank you SO much i didnt really finish what you said but now my cheats work so THANK YOU!!!!!!! "
Are therepokemon platnim cheats?
There are no cheats built into the game itself (button sequences and the like) but cheating is possible with an Action Replay device from Datel.
http://en.wikipedia.org/wiki/Action_Replay
you can buy one here:
http://www.datelgaming.com/ProductDetails.asp?ProductCode=DUS0162&click=22
If you have an action replay then here is a list of cheat codes for Pokemon platinum
http://pokemonplatinum-version.blogspot.com/2008/09/pokemon-platinum-cheats.html
Mar 22, 2011 | Nintendo DS Lite Console
When I use my action replay whith my pokemon pearl game it says that my game is unknown and when I try to type in its ID it starts showing red and white stripes.
well i think you have to research online for the id of pokemon pearl and put it in the action replay and put in some codes in and then try it.
P.S. if it still doesnt work send the action replay to datel.
Jan 27, 2010 | Datel Action Replay for Nintendo DS
Action replay says unknown on platinum and pearl
Jul 28, 2009 | Datel Action Replay for Nintendo DS
Pokemon pearl wont work after using action replay
try to use th action replay walk trough walls cheat to get out it ussally works or if you've already tried this then I am sorry but you may have to delete your game file and start a new one.
If this doesn't help sorry but can you still rate this please. Xamous
May 29, 2009 | Nintendo Pokemon Pearl Version for DS
My action replay v. 1.60 said "unknown game" for the first time when I put in my "Meet The Robinsons" gamel. I turned it off, put in Pokemon Pearl and started a new game. I saved and turned it off. I
Maybe if you enter the Meet the Robinsons ID code and make it a known game it will work again. Or if you upgrade it with the disc and cord they include it will work. Well good luck!
May 16, 2009 | Datel Action Replay for Nintendo DS
When i put in pokemon pearl, my action replay ds freezes up and says start in red but nothing is click-able
I figured it out. I went to the list of all the games it had. Pokemon Pearl wasn't there, but Pokemon Diamond was. I clicked on Diamond and I got to cheat on Pearl!
Apr 28, 2009 | Nintendo Action Replay DS for DS and NDS...
My AR says my pokemon diamond has a different code then usual
Same thing happened to me, the problem could be that the game code was entered wrong into the Action Replay, there are a few things you could do about it. You can take out you Action Replay Code Manager CD and delete the game and re-enter it. Or if you don't have the Code Manager CD, go into the internet and look up the code for Pokemon Diamond Version, and fix it on your Action Replay.
Good Luck!
Apr 25, 2009 | Nintendo DS Lite Console
My action replay won't read pokemon pearl anymore
you are idiot gamer of pokemon bastard wew you are weak.....
Jan 15, 2009 | Nintendo DS Lite Console
How come my action replay cant work
The problem could be because the identification code on the game is diffrent than it is on the card.
Jan 13, 2009 | Datel Action Replay for Nintendo DS
Action replay ds
search codejunkies and everywhere else.if they have a code for that specific game(if its pokemon diamond it should still work)and then hit the pencil deal that had marks behind it. make sure your already inside the pokemon pearl cheat list and type "hyper ball cheat"or something lilke that then put in the code that was on the website and WALA! your on your way 2 becoming a pokemon MASTER!
Jun 06, 2008 | Nintendo DS Lite Console
Datel Action Replay for Nintendo DS Logo
368 people viewed this question
Top Datel Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Martin Murray
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
