Home | Beko | 24 in. D3421F Free-standing Dishwasher | BEKO D3422FW Dis...
Beko 24 in. D3421F Free-standing Dishwasher
Problem for Beko 24 in. D3421F Free-standing Dishwasher
BEKO D3422FW Dishwaser stays on the pump out cycle.
By explorer2 on Oct 23, 2007
The main problem with the dishwasher is that it sticks on the emptying cycle ie the pump runs continously and will not move on to fill. I have taken the float switch apart (which is made of polystyrene) and it works fine for half the full cycle and then jams again on the pump out cycle. Could there be a blockage in the 2 pipes leading to either side of the float switch?
Same Problem
Jul 02, 2008
-   my beko 3422fs will not release the tablet & will not go on to a cycle just a dronning sound-   Guest
Jun 04, 2008
-   Please help!
my Beko Dishwasher 3421FW, which recently had a 4 week holiday waiting for a replacement lower spray arm, has now packed up altogether!
It is only splashing cold water around, and the selector knob moves to the end of the cycle within 10 minutes, also, the upper spray arm is not spinning (i think it's the seal), but that happened about a week earlier, was getting round to ordering a new part when the whole lot went
Any suggestions?-   Guest
Apr 09, 2008
-   I am having problems with my Beko D3422FS.
I turn it on, it fills with water, but does not wash. The rotary controller does not rotate through the selected program. I tilted the diswasher back and water came out. I tried to restart but the same thing happens.
Any suggestions on what the problem is and how to fix it.-   brenkinger
Dec 10, 2007
-   hi have tried tilting it bach but will only run for half the prog
-   Guest
Best Solution
posted on Dec 10, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hi the problem is the side vent has come away from the body .
look in side and take out the bottom draw on the left hand side about half way up you will see a small round vent ; it is this that is loose and letting in water in to the bottom tray and activating a trip switch in the base so you dont get water all over your nice floor. just turn it to the right and it should tighten up
Solution #2
posted on Nov 03, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
hi lay the dishwasher on it back water will come out dont worry let it come out, then stand it back up and press to strat and it will work , it did for me
Solution #3
posted on Jun 07, 2009
Very Helpful)
hepworth_nei
Rank: Apprentice
Rating: 100%, 1 votes
I found vent loose as suggested above and tilted it back to reset and it worked
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #4
posted on May 08, 2009
Very Helpful)
linz1340
Rank: Apprentice
Rating: 100%, 2 votes
DE3431FS . .The dishwasher constant pumping problem , i had this and followed the advise to empty contents and tilt backwards 30 DEGREES the machine to reset the float switch , and it worked a treat !!! many thanks to explorer 2 , top tip mate !
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #5
posted on May 06, 2009
Very Helpful)
JAMFGixxer
Rank: Apprentice
Rating: 100%, 6 votes
I can confirm Solution #2.
This usually happens whe you have a blockage in the waste pipe. For some reason, once you've cleared the blockage, the dishwasher doesn't detect that water has now passed through the system, even if you send through more water via filling the base (I did this about 4 times totalling 24litres of water and it still didn't reset).
Tilt the dishwasher back (I only had to tilt it about 30 degrees), this resets whatever switch it is that turns the pump off and allows it to fill with water.
Was this helpful?
Yes
No
6 people thought this was helpful
Solution #6
posted on Jun 08, 2009
Not Rated)
francesr76
Rank: Apprentice
Rating: 0%, 0 votes
thanks it worked
Comments:
Jun 08, 2009
- sorry only worked for 10 mins still making noise
Was this helpful?
Yes
No
Popular Solutions for Beko 24 in. D3421F
Questions and Unsolved Problems for Beko 24 in. D3421F
Do you recommend Beko 24 in. D3421F Free-standing Dishwasher?
Answer
Answer
prewash program run. won't do a wash cycle noe soungs like it's draining all the time
Answer
After starting the dryer the light indicater on the tank full flashes and after about 7 or 8 seconds... (More)
Answer
Beko 3422fs - Water won't heat up and it gets stuck half way through the cycle - all i can hear is... (More)
Answer
When I open the dishwasher there is a strong fish smell. I cleaned fishy dishes in it a long time... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Beko 24 in. D3421F...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
