Question about Goodman Heating & Cooling
AC not working
Fan on outside unit does not initialize but I hear the condensor kick in for two seconds then cut off. I can turn the fan freely with a stick so its not locked up.
    Guru:
  • 1,524 Answers
Change the fan motor capacitor.
Posted on Jun 02, 2009
Compressor/Condensor fan need to be turned by hand to get it started. Do I need a new fan motor or could this be a larger issue.
If the fan does indeed run ok without any bearing noise and the blade spins freely when you push it and then runs ok your motor start capacitor is bad on the motor. This is usually a small metal oval shaped can with two wire leads attached to it to help kick the motor armature into spinning when your ac unit first turns on.
The capacitor is about 4 to 6 uf (microfarads) and at is available at a local electrical supply house and is under $10 and if your handy with small tools this could be replaced by yourself if you are willing. BE SURE TO PULL the OUTSIDE POWER DISCONNET before taking any covers off. 240 volts ac for the compressor motor and fan motor plus even the 110 volt control power will kill you before you can blink! The control relay from the thermostat in your home is 24 volts ac. Get a friend with a voltmeter to verify the circuits are truly dead before you attempt repairs. Good luck and use a voltmeter to make sure the power to the ac unit is off! Regards, Dennis
Aug 16, 2015 | Heating & Cooling
How soon after replacing the condensor fan, is it supposed to kick on?
Condensor fan should start when the compressor starts. If the condensor is hot at top and bottom, turn the refrig off and check the fan for power, should spin freely by finger, and coast to a stop.
Good Luck,
Bill
Aug 17, 2012 | GE Refrigerators
A/C stopped working, condensor unit outside fan will turn by hand and wind freely, can hear a clicking at condensor outside when turning on and off A/C unit, Changed both fuses and still not working and...
What you are hearing is the contactor clicking...trying to turn on the compressor...
Check for 220v power across the 2 poles of the contactor on the incoming side and then check the out going side if you have power...thinking that there is no power to the unit..
heatman101
Jul 19, 2011 | Maytag Heating & Cooling
AC unit not kicking on...
You need a "Y" terminal. "Y" is pretty standard on every heat pump. It is the wire that will energize the compressor contactor at the outdoor unit, allowing the compressor and condensor fan to run.
Apr 03, 2010 | Heating & Cooling
My unit ran fine on saturday but outside fan did not work on sun.
your capacitor is bad for your outdor condensor fan. it is either sep from comp or its all in on normally a 55/5 sometime they blow if it a rheem or ruud unit. check the capcitor.
Aug 16, 2009 | Heating & Cooling
Goodman AC fan working but not cool air.
0204 built the second week of 2004 sound like you have a loose or burnt wire in the a-c and arcing when the unit comes on. turn the breaker off next time you fix an outlet
Aug 02, 2009 | Goodman CKL24AR24 Air Conditioner
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Jul 26, 2009 | Heating & Cooling
A/C not working, outside fan not turning without assistance
is fan spinning fast enough it has to have alot of velocity to cool condensor coils if you haft to push fan to get going its probably shot and get new motor the ac is a sealed system and hardly ever will leak freon!!!Best of Luck to You!!! :)
Jul 02, 2009 | Bryant 462AJC021BA Air Conditioner
Compressor on my RV coleman ac unit bogging down
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
Jun 29, 2009 | Coleman Mach 15 Air Conditioner
Fan whining and blades not going
Sounds like your compressor outside is frozen up or (locked up) the smell is outside correct? it could also be your fan also in your condensor unit outside the easiest way is to listen for fluid movement (if your freon is moving then your compressor is working and you need to lean toward a fan motor. check to see if you can move the fan blades in the compressor (outside ) if the problem is in the house then approach in the same way with the power to the unit turned off only If you cannot turn it most likely fan motor replacement is in order, and pressure sensors are not letting your condensor run. theres a few things to try hope i have helped .Honestly it probably would not hurt to let a service man look at it anyway, but this way at least you're a little wiser chris
Jun 12, 2009 | Goodman CLT36AER36 Air Conditioner
Heating & Cooling Logo
129 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
