Question about Microsoft Windows Vista Ultimate Edition
I want to do partition of my hard disk.So please help me
How can i partition harddisk
    Scholar:
  • 136 Answers
Ways to partition Hdd
1)Partitions can be created using the Disk management wizard from with in the operating system ie either in win xp or vista, but it has few restrictions and rules though, So to use these feature you need to have a good knowledge of it (not recommended for newbies).
2) Using the bootable CD/DVD of the operating System,here too procedure depends on which operating system you wish to use and partition the Hdd.
I ll explain the common steps for both then explain each in breif:
1) Insert the bootable into the drive, setup the BIOS to boot from CD/DVD ie set the first boot device as CD/DVD rom.save and exit the settings the pc will reboot.
2)When the PC starts it will ask you to press any key to boot from the CD/DVD rom, press any key here to start the setup process.
3)The loading of necessary files will start so let the process to complete, make sure you dont switch off the system untill the whole installation and partition process is completed.
Above all steps are common to both Win XP and Vista
Now XP specific process --
1)You will then get a Windows XP Professional Setup screen. You have the option to do a new Windows install, Repair previous install or quit. Since we are doing a new install we just press Enter to continue.
2)You will be presented with the End User Licensing Agreement. Press F8 to accept and continue
3)This step is very important. Here we will create the partition where Windows will be installed.Press C to create a partition.
4)Windows will show the total size of the hard drive and ask you how much you want to allocate for the partition you are about to create.
5)Notice it shows C: Partition 1 followed by the size in MB. This indicates the partition has been created. If we still have an unpartitioned space. Next heighlight the unpartitioned space by pressing down the arrow key. Then press C to create another partition. You will see the total space available for the new partition
specify the space you wish and repeate the process to create the partitions of your choice.
6)Choose format the partition using NTFS file system.This is the recommended file system. If the hard drive has been formatted before then you can choose quick NTFS format. We chose NTFS because it offers many security features, supports larger drive size, and bigger size files.
7)Windows will now start formatting drive C: and start copying setup files and the setup will start follow the instructions enter the product key when prompted to enter and you are done.
Now Vista Specific --
1)After loading of files you will see screen that allows you to setup your language, time and currency format, keyboard or input method. Choose your required settings and click next to continue.
3)The next screen allows you to install or repair Windows Vista. Since we are doing a fresh install we will click on "install now".
4)You can now type the product key that came with your Windows vista.
5)If you do not enter the product key you can still proceed with the installation in which case Windows will ask you which version of Vista you have purchased. Windows Vista Home Basic, Home Premium, Ultimate, Business etc. Select the version you have purchased and click next. Please note, although you can select any version of Windows and proceed to next stage. It is not good idea to select a different version to the one you have purchased becuase you will not be able to activate Windows at a later stage. Windows Vista can detect which version you have purchased once you enter your product key.
6)Tick "I accept the licence terms" and press next.
7)Choose the type of installation you want to perform. You will notice that upgrade option is disabled as we have booted from the DVD-R. Therefore we can only select Custom (advanced) option which basicly installs a clean copy of Windows from scratch.
8)Choose where you would like to install Windows Vista. If you have a new upartitioned hard drive you would get your hard drive listed,If have have an old hard drive with data or other partitions it will show up as logical drives. You can select the drive options (advaced) to format, delete, or create new partions.Windows will create a partition and format it using NTFS files system.
9)Windows starts the installation process and starts copying all the necessary files to your hard drive,
10)It will go through various stages of the setup and will reboot your system few times. When your PC reboots it attempts to boot from CD as its the first boot device. Do not press any key during the boot prompt so Windows Vista will continue with the installation by booting from your hard drive.
11)After installation copy process is complete you are presented with the Setup Windows dialogue box as show below. At this stage you need to choose a user name, password and a picture for your user account.
12)Next everything is self explainatory
Hope you can format and repartition your HDD wiht ease now
Posted on Jun 23, 2009
    Guru:
  • 597 Answers
You need to partition your hard drive before you install an operating system on it. If you boot off your windows CD and your hard drive has a partition already you will get a screen that prompts you to format it. You can also dellete the partition and make a new partition. AT that time you can select the size of the partition you want to make and creat multiple partitions. If you choose you can creat one smaller partition from the space available for you to format and install windows on and format the rest of the available space later on after windows is installed from the Administration Tools in control panel.
Posted on Jun 02, 2009
2 Suggested Answers
  • 435 Answers
SOURCE: cannot acess hard disk partitions?
Hi, I hope you are using Windows XP and you have partitioned the disk properly.
Goto Control Panel> Administrative Tools> Computer Management> Disk Management
Now you should see all the disks and partitions in each disk and partition names of each partition. Right click the parition and you get all options to do.
Note: Be careful not to mess with C:  partition. Try to stay away from it.
Posted on Sep 21, 2008
My external harddisk - WD 320G(my passport essential) can not recoginze on Window 7. Please help to slove.
First check physical connections of hard disk to your cpu. Check in 'device manager' disk drives tab. If its found check in "disk management" in that drive which file system its showing. If it shows raw partition mean your file system is corrupted. It requires remove that partition and create a new partition.
for open device manager : start > run > devmgmt.msc
for disk management : start > run > diskmgmt.msc
Aug 04, 2010 | Western Digital 320GB MyBook External USB...
How can i partition my 320gb sea gate ext harddisk
you can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
Jul 22, 2010 | Seagate 320GB FreeAgent Pro FireWire 400,...
Aspire 6930 has 320 GB harddisk,i faced some problem with Avasti Antivirus n i formatted the system to run my system smoothly, but now the problem is harddisk is showing only 128 GB. that too the partition...
You can Reformat the system and REMOVE all partitions. Windows setup will create a new partition from available drive space. If you need to save your data,You can also use a utility like partition Magic and resize the partition. There is a trial version available at no charge. just google "partition magic"
Aug 05, 2009 | Acer Aspire 6930-6771 Laptop
My computer didnt recognize my hard disk
Looks like the controller on the Hard disk has malfunctioned. I am afraid, that the Hard disk has to be sent to an expert nearby for Data Recovery. They would have tools which could be used for getting your data intact. But again it all depends on the level of damage to the Hard disk.You may get all / some of your data ot you may get none. Please consult your hardware vendor for this
Apr 13, 2009 | Western Digital Caviar 40 GB Hard Drive
Hard disk problem
you may try formating into a linux partion first using partion magic and then to any of the windows partition
Jan 18, 2009 | Seagate 40GB EE25 5400.2 Ruggedized PATA...
Disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Jan 10, 2009 | Seagate (ST3160827AS) 160 GB Hard Drive
Data Recovery
actually it is not able to delete the partitions when you are logged into windows....
try to disconnect the harddisk from the system(remove both the data and power cables) and then reconnect them again..
even if it doesnt work try the software called as PARTITION MAGIC
thankyou,.
regards
JC
Aug 13, 2008 | Computers & Internet
3 partitions missing on a 250gb SATA hard disk
i think you just got corruption. possibly heat related. or rootkit. uhh dynamic isn't right i think its logical .. right click the drive letter lower section and convert is best bet. i also dabbed with ptedit32 from bootable cd ubcd4win.com to fix lost partitions in prior experience.. but it was 1 partition and i found lba and other settings on drive sticker.
Jul 09, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Problems with booting
for any new hard disk first you have to create a partition table. Usually this is done when installing the OS. eg: for win98 you have to first create the partition in dos, format it, then run win98 setup. Now in WinXP this can be done when installing the OS. Similarly you may have to create the partition before runing UNIX setup. I Dont know the installation for UNIX. Usually the hard disk manufacturer supplies with some utility to do the partition. Like Disk Manager from Seagate.
Sep 06, 2007 | Compaq AlphaServer DS10
Microsoft Windows Vista Ultimate Edition Logo
256 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
