Question about Canon imageRUNNER 400S Copier
Copier stops after 35 copies when using finisher
I have a Canon ImageRUNNER 400 w/ C-1 Finisher. When copying multiple pages and stapling (whether 2-sheets each or more), the system stops after each 35 copies and a message displays to "Remove Paper." I know this would come up for each print job but I am copying 360 copies of the same item. Any ideas?
  • 3 Answers
My Ir400 copier show empty paper trays when they contain paper and this same problem on one of the two working trolley trays. gear set, motor of both units are working. When interchanged the units board, all trays show empty kindly help me to identify the problem
Posted on May 16, 2011
  • 313 Answers
This is due to the output tray you sre using only having a small capapcity sensor what you should do is set it to come out from the finisher unit to the lower tray as this holds more sheets you can check this by looking at the output tray and when it asks you to remove paper see if the top pages are resting on the paper sensor in the tray. good luck A
Posted on Jun 13, 2009
How do I reload staples into my Xerox WorkCentre 7530?
You did not indicate finisher? Xerox MFPs' come with the most finishing options of any manufacturer.... I included instructions for all of them below. Enjoy!
Solution : Load Staples in the Professional Finisher With Booklet Maker The stapler in the booklet maker uses two Staple Cartridges labeled R2 and R3. Booklet stapling requires that both Staple Cartridges be free of jammed staples.
WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the printer has stopped copying or printing.
  2. Open the Finisher Front Door.
  3. Squeeze the orange R2 and R3 levers together and pull the Staple Cartridge unit out of the Finisher until it stops.
    NOTE: The Staple Cartridge unit does not detach from the Finisher.
  4. Grasp the orange tabs on both sides of the Staple Cartridge and lift the cartridge out of the Staple Cartridge Unit.
  5. Push the new cartridge into the Staple Cartridge Unit.
  6. If no jammed staples are found, repeat step 4 - 6 for the other Staple Cartridge.
  7. When finished, return the Staple Cartridge Unit to its original position.
  8. Close the Finisher Front Door.
Solution : Load Staples in the Main Stapler of the Professional Finisher NOTE: Using Staple Cartridges other than the recommended staples may impair quality and performance. Only use only Staple Cartridges recommended for this Finisher.
  1. Make sure the machine has stopped copying / printing.
  3. Grasp the orange R1 lever on the Staple Cartridge and push it to the right.
  4. Grasp the orange tabs and pull the cartridge out of the Finisher.
  5. Check inside the Finisher and remove any loose staples.
  6. Pinch both sides of the staple case and remove the staple case from the cartridge.
  7. Insert the front side of the new staple case into the Staple Cartridge, then push the rear side into the cartridge.
  8. Grasp the orange tabs on the cartridge, and then insert the cartridge into the Finisher until it click into position.
  9. Close the Finisher Front Door.
Solution : Load Staples in the Booklet Maker of the Optional Office Finisher LX NOTE: The Booklet Maker uses two staple cartridges. Booklet stapling requires that both staple cartridges contain staples.
  2. Open the Finisher Side Cover.
  3. If the Staple Cartridges are not visible, grasp the vertical panels to the left and right of the opening and slide them to the center.
  4. Hold the tabs on both sides of the cartridge and pull the cartridge out of the finisher.
  5. Hold the tabs on both sides of the new cartridge and insert it into the original position in the Finisher.
    NOTE: If you have trouble inserting the cartridge, make sure the staples are positioned correctly in the cartridge.
  6. Starting at step 3, repeat the procedure for the other cartridge.
  7. Close the Finisher Side Cover.
Solution : Load Staples in the Integrated Office Finisher WARNING: Do not perform this procedure when the printer is copying or printing.
  1. Make sure the machine has stopped printing or copying, then open the Front Cover on the Integrated Office Finisher located under the Scanner Assembly.
  2. Remove the Staple Cartridge by grasping the cartridge by the orange handle and pulling it straight out of the Finisher.
  3. Remove any loose staples inside the Finisher.
  4. Pinch both sides of the staple case and remove the staple case from the cartridge.
  5. Remove the new staple case from its packaging and insert the front side of the case into the staple cartridge. Push the rear side into the cartridge. The cartridge will click into place when it is installed correctly.
  6. Grasp the cartridge by the orange handle and insert the cartridge back into the stapler until it clicks into position.
  7. Close the Front Cover.
    NOTE: If the Front Cover is not completely closed a message will be displayed. The machine will not operate if the cover is even slightly open
Nov 18, 2013 | Xerox WorkCentre M-24 Color Copier
We used to have canon imagerunnerr 3100 and recently swapped out for 3220. Everything works basically the same except stapling. On the 3100 if I was photo copying and stapling a landscape document it...
Its only because I care about folksthat I answer questions like this since the chances of have my score diminishing is so great when the feedback rolls in.Ok,gut check tells me you have a different(less capable) stapler(finisher).The old standard has been upper left corner. then came the "zoom" stapler that could move to most anywhere to provide stapling on LTRR and legal.I bet you have a NEW and improved copier, but the finisher has less capabillities.Ask for the old finisher back if thats an option.The old finisher SHOULD interface with your new copier. I hope I helped.... ! :-)
Jan 04, 2011 | Canon imageRUNNER C3220 Color Copier
Anyone a Canon 5180 i imagerunner expert? Trying to do booklets but the page is coming out with all pages doublesided on one sheet. Help T
Assuming you have a saddle finisher?
Ensure the originals are programmed in correctly.
Highlight booklet on display. Select original size.
Orientation of paper in cassette needs to be A4R.
Program asks if you want stapling.
If no saddle finisher then ensure paper cassettte is A4R.
2 sided, reduce to 2 copies per page,
Sep 25, 2010 | Canon imageRUNNER C3200 Copier
How to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Nov 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
How do i refill staples in the the canon imageRUNNER 3300?
Look in the Reference Guide. This should come with your copier if you bought it new. Do you have Finisher J1 (internal finisher, paper comes out above paper trays) or the SaddleFinisher and inner2way tray (paper comes out on left hand side of machine).
For finisher J1 look starting on page 7-38. Saddle Finisher 7-61.
Can get Reference and Copy guides here: http://ww2.canon.it/supporto/manuali_operatore/elenco.asp?t=&i=IR3300&id=IR3300
The English versions (which I use, I don't speak Italian) are the ones with ENG in the name.
Jul 21, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Replacing the Staples
The copier will inform you when it's out of Staples. To check the staples, open front cover of the finisher (device on left that catches copies) There should be a pictorial diagram on how to remove/install cartridge on inside surface of cover. Page 7-12 of the Copier Reference Guide if your finisher has 3 trays. Page 7-38 of the Copier Reference Guide if your finisher has 1 tray. Hope this helps.
Jun 18, 2009 | Canon imageRUNNER 400S Copier
Canon imagerunner 2270 staples on the right side
Under user screen you have in lower left corner finisher or similar. press it, and chose staple and left or right
Nov 20, 2008 | Canon MF8180C Color Laser MFC Printer
Inserting staples
If the machine has an in-built finisher, the stapler is located in the rear of device. Pull the finisher release handle and pull the finisher towards you. Extract the staple cartridge by pulling up in the green tab at the rear right of the finisher. The staple cartridge can be opened by squeezing the sides together to allow the spring to act. (Sometimes it can be helped with a screwdriver popping the clear tabs located on the underside). Insert the replacement staple pack and pull the orange tab before closing the cartridge shut. Reinsert into the finisher and push down to locate it. Should work ok after all that.
Nov 26, 2007 | Canon imageRUNNER 3570 Copier
F-1 finisher not stapleing
Have you tried the staple setup procedure, or maybe swap the Finisher DC Controller off the Finisher that the known-good stapler carraige came from? I think DC Controller.
Nov 16, 2007 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 400S Copier Logo
121 people viewed this question
old marine
old marine
