Question about Canon PIXMA MP160 All-In-One InkJet Printer
While printing a color job, the "alarm" button came on, an "E" flashed, and the number "2" alternated flashing with the "E." I had just replaced the ink cartridges, and the paper was in place. I turned it off and back on, several times, and cleared out any jammed paper. Every time I turn it back on, the same thing happens. The printing just prior to this event was PERFECT. What to do?
  • jenniroth Jun 02, 2009
    I hope this isn't a scam. I am about ready to call AMEX and void the charge. I don't need to be referred to websites or phone numbers that are already available for free on the internet. I signed up for your service so that someone could write back an e-mail that explained what to do to get the printer/photocopier working again. The "alarm" light flashes, an "E" and "2" also alternate, flashing. Canon MP160
    Canon MP 160 color printer/photocopier is showing error number 5100. It appears as though it is about to print, then stops, and the unit shows a red alarm light and flashes "E" and "2" alternately. I have just replaced the ink cartridges and the paper is not jammed.
  • 184 Answers
Hello jenniroth,
please follow these solutions one after the other to correct your error problem. try printing after each solution and see if it goes through. If the continues, move on to the next solution one after the other until your problem is solved.
Solution 1. Load Paper Correctly
1. Remove paper from the ASF.
2. Open the paper output tray.
3. Set the paper thickness lever according to the media being used.
Note: For paper thickness lever settings, use the following setings for the media type being used: Right side: Envelopes / T-Shirt transfers. Left side: All other media types.
4. Divide the stack of paper into two or three piles.
5. Fan out the sheets of paper so that they do not stick together.
6. Load paper in the auto sheet feeder with the paper's print side facing up.
7. Align paper to the right edge of the auto sheet feeder.
8. Pinch and slide the paper guide to the paper's left side.
9. Press <Black> or <Color> button to clear the error.
Solution2: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Solution 3: Remove foreign objects from ASF MP160
When printing, if there is any foreign material (such as a piece of metal or a pencil) in the printer, the printer my be damaged. If there is any foreign material, remove it at once. Follow these instructions to remove foreign objects from the ASF.
1. Power the printer off.
2. Open the paper support and confirm that there is not any foreign material in the auto sheet feeder. (If there is any foreign material, remove it by hand or with tweezers.)
3. Open the scanning unit (printer cover).
Note: After confirming that the scanning unit support is fixed into position, release your hands.
4. Confirm that there is not any foreign material in the printer. (If there is any foreign material, remove it by hand or with tweezers.)
Caution: To prevent injury or damaging the unit, avoid touching the inner parts.
5. Close the scanning unit (printer cover).
Caution: Be careful not to pinch fingers when closing the cover.
6. Power the printer on and confirm that the printer operates normally.
Note: If you cannot remove the foreign material in the above procedure, the printer may require servicing.
Solution 4: Remove Packing Material MP160
Remove packing material so that the print head holder can move.
1. Confirm that the printer is powered off.
2. Lift up the scanning unit (printer cover) then place the scanning unit support into position. After the support is fixed into position, release your hands from the scanning unit.
Caution: If the front cover is opened with the printer powered on, the print head holder may not operate properly, resulting in injury or printer problems.
3. Remove the orange protective tape and the protective material.
4. Close the scanning unit (printer cover).
5. Press the <ON/OFF> button to power the printer back on.
Solution 5: Reseat ink cartridge (MP160)
Reseat Ink Cartridges
Reseat (remove / reinstall) the ink cartridges if an error appears.
Removing Ink Cartridges:
1. After confirming that the printer is powered on, open the scanning unit (printer cover). The ink cartridge holder moves to the replacement position.
2. Press down on the semi-circular tab to release the cartridge and then remove it.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
3. Remove and replace each cartridge individually. Or, remove the second cartridge after the first has been removed.
Note: Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
Installing ink cartridges:
2. Insert the ink cartridge into the ink cartridge holder.- Black: the left slot- Color: the right slot*
*One black cartridge and one color cartridge must be installed in the machine in order for the printer to operate. It does not matter if the capacities (Standard or High) do not match.
3. Push up on the front of the cartridge until it locks into place. (A click sound will be heard when the cartridge is locked in place.)
4. Confirm that the ink cartridges are installed properly.
<1> The ink cartridge is not installed properly.
<2> The ink cartridge is installed properly.
5. Fold the scanning unit support and close the scanning unit (printer cover).
6. Wait until the preparatory operation is complete; it takes about one to two minutes.
Solution 6: printer require repair or servicing.
If after going through these steps you still face the same error, then you may need to take your printer for servicing.
Cheers!
Posted on Jun 02, 2009
    President:
  • 987 Answers
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
    President:
  • 1,197 Answers
Even i had this same problem but before i tell u what i did to make it work for me..... check out the canon wesite and their solution for this problem...... clik on the link below and clik on each of the 3 solutions specified as remedy.... as u clik each u ll have a diagrammaic representation of what u need to do....
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=13368#SupportDetailAct
as far as me I did manage to finally get the printer to work. Actually, for a trialrun I popped the top off of the empty black cartridge and squirtedabout 20 ml of rubbing alcohol down the side and let it sit for abouthalf an hour (I was going to use gin but my wife thought it would be awaste). I installed the cart and managed to get it to run a fewcleaning cycles (still getting a low ink indication) and actuallyprinted -- very well, too -- an entire 8X10 color photo and a few pagesof text before it started to fade to grey. I then sprung for new blackand color carts, popped them in and am up and running. All the otherfunctions are now working also.
good luck with ur printer.... thank you
My Canon Pixma IP400 is not working and the orange light is flashing 5 times
How to reset waste ink / blinking printer canon ip4200
With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
While holding the Power button, release theresume/Cancel button. (DO NOT release the Power
button.)
While holding the Power button, press the Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
When the Power LED lights in green, press the Resume/Cancel button the specified number of
time(s) setting).
After pressing the Resume/Cancel button the required number of times -you must press the On/Off button to perform the task. For Example Pressing Resume/Cancel 1 time, then press On/Off - does a Service Test Print
Time(s) LED indication Function Remarks 0 times Green (Power) Power off When the print head is not installed, the carriage returns and locks in the home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings After entering the destination settings mode, press the Resume/Cancel button the specified number of time(s) to select the destination. For detail, see "Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used in servicing.
15 times Orange (Alarm) Return to the menu selection.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 23, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
My canon pixma ip4200 flashes orane 5 times
While holding the Power button, release the resume/Cancel button. (DO NOT release the Power
button.)
time(s) setting).
Thanks, Joe
Dec 23, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Waste ink absorber - what is it and how do we rep[lace it?
plz try
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s) according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.) [hth: I believe the power button has to be pressed once more after cycling the alarm button to complete the action. The power/resume-cancel button LEDs toggle to help you count.]
1 time Orange (Alarm) Service test print See 3-4. Verification Items, (1) Service test print.
See 3-4. Verification Items, (2) EEPROM information print.
3 times Orange (Alarm) EEPROM initialization [hth: does not re-initialize Waste ink counter]
5 times Orange (Alarm) Destination settings [hth: not applicable]
[hth: 7-10 not applicable]
11 to 13 times Orange, Green, Orange (Alarm, Power, Alarm) Return to the menu selection
14 not used in servicing
15 Orange (alarm) return to the menu selection,.
Note: If the Resume/Cancel button is pressed 16 or more times, the Alarm or Power LED lights steadily without
any changes.
Note : if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work.
Aug 26, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
Printer reads "Waste Ink Near Full"
www.fixyourownprinter.com/forums/inkjet/50418
The above link will assist you.
any changes.
[hth: if the alarm light is flashing 15 times at turn-on [cartridge not recognized error], none of these procedures seem to work. If anyone knows how to defeat this error, I would like to know.]
Aug 24, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
Error 5B00 trying to get to service mode to reset waste ink code but need to bypass the alarm mode.
Hello there..
Here is how you fix this error:
any changes.
I really hope this can help you.
Best regards
Andrea
Oct 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
selectable.)
button.)
Power
in
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
in servicing.
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
37 people viewed this question
old marine
old marine
