Question about kawasaki Full Suspension Mountain Bike Men
What is the location of the oil filter on a 1998 Kawasaki KLF300 Bayou 4X4?
Does anyone know where the oil filter is located on the engine of a 1998 Kawasaki KLF300 Bayou 4X4? Is is visible from the outside or do you have to remove a cover?
    Sniper:
  • 75 Answers
It should be on the front of the engine and may have a round cover over it that has fins on it or is ribbed.
Posted on Jun 03, 2009
WHERE IS THE FUSES ON MY 1997 KAWASAKI BAYOU 300 4X4? I DONT SEE ONE ANYWHERE???
Hi, Edward for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.kawasakimotorcycle.org/forum/kawasaki-atv-mule/98357-bayou-300-4x4-new-problem.html
WHERE IS THE FUSES ON MY 1997 KAWASAKI BAYOU 300 4X4 Google Search
Kawasaki KLF 250 Service Manual
OEM Parts for Kawasaki
1997 Kawasaki Bayou 300 4x4 Owner Manual
Jan 14, 2017 | kawasaki Motorcycles
Where is the fuse located on my 1997 Kawasaki bayou 300?
Hi, Edward for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kawasaki, despair not, for a mere $8 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.kawasakimotorcycle.org/forum/kawasaki-atv-mule/98357-bayou-300-4x4-new-problem.html Kawasaki Bayou not starting
Kawasaki Bayou 300 service manual repair 1986 2006 KLF300 Download Manuals...
https://personalmanual.com/1997-kawasaki-bayou-300-owners-manual
2002 Kawasaki bayou klf300 4x4 missies at half to full throttle cleaned the carb and bought new cdi,rectifier still misses
Hi, Ellis and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
http://www.kawasakimotorcycle.org/forum/mechanics-corner/35765-89-bayou-300-backfires-coughs-above-idle-speed.html
Kawasaki carb problem Gurus please help
https://www.tradebit.com/filedetail.php/118245427-kawasaki-bayou-300-service-manual-repair-1986-2006
May 01, 2016 | kawasaki Motorcycles
What list of things that control my neutral light from coming on for my kawasaki bayou 220
Bayou 220 250 KLF220 KLF250 Kawasaki Service Manual ...
www.cyclepedia.com/...manuals/kawasaki...manuals/kawasaki-klf250-ba...
The Kawasaki KLF220/250 Bayou requires the valve clearance, engine oil and oil filter be inspected every 600 miles. Keep your Bayou free of problems and in ..
Aug 05, 2015 | kawasaki Motorcycles
I have a 90 Kawasaki KLF300 Bayou 4X4 and I am having a problem with it running too rich no matter what I do. I have taken the carb apart several times, reset the mixture screw to factory setting. I have...
Hey Dave,
thought I answered this already,,,??? Classic "brass kit" symptom! >>> You need a "brass kit".. this is the needle jet and the jet needle in the center of the carb. The jet needle is the thin needle that hangs down from the center of the slide... The needle jet is the "hole" that the jet needle slides into...Remove the carb, take the bowl off, remove the main jet, the needle jet holder should be able to be gently tapped out, the needle jet is a short brasspiece,, it comes out through the hole where the slide goes,,, reinstall the NEW needle jet, needle jet holder...(it may have a groove in it for correct location). once its seated, you can reinstall the main jet..NOW >> to install a new jet needle,,, remove the slide from the carb.. remove the spring and seat from the slide that holds the needle jet in place.. NOTE which groove the clip is in on the old needle.... (should be the middle one). re install the new needle, reinstall everything else and your atv WILL run fine for a long time..This is a common problem on ATV's..
you need part #'s
1990 Kawasaki BAYOU 300 4X4 KLF300 C2 Carburetor
http://www.kawasakipartshouse.com/oemparts/p/kawasaki/16009-1503/needle-jet-n36w
http://www.kawasakipartshouse.com/oemparts/p/kawasaki/16017-1270/jet-needle-6
Jun 24, 2017 | kawasaki 2004 Bayou 300 4x4
I need a wiring diagram for a 87 kawasaki bayou, mine had the wires ripped out and now i cant figure out how they go
Hi and welcome to FixYa,
Perhaps the wiring diagram of a Kawasaki KLF300 could be referenced, should you be interested, please click here.
Good luck and thank you for asking FixYa. Merry Christmas.
Dec 24, 2009 | 1980 kawasaki Z 650 SR
Kawasaki bayou 4x4 using engine oil alot of smoke from exhaust
if it is using oil, then u got stuck rings, which keep running the bike and keep a eye on the oil, or you need the top end rebuilt.
Nov 21, 2008 | kawasaki Full Suspension Mountain Bike Men
kawasaki Full Suspension Mountain Bike Men Logo
456 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Phillip Edwin
Level 1 Expert
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
