Question about Refrigerators
I want to reverse the hinges.
I have a sub zero refridgerator with hinges on the left side. Is there any way for me to switch the hinges so that they are on the right side?
  • 142 Answers
Only if the fridge is set up for this. Look at the top right corner of the case and see if there is a plastic plug. If there is it is drilled and tapped for the mounting hardware that is being used on the left. Remove the hinges and put them on the right side. The door handle should have the same set up.
Posted on Jun 02, 2009
Sub zero refrigerators 632 door won't stay closed
Thee is a plastic cam at the bottom hinge of the door. Mine cracked and I bought a new one online for like $30 (for a piece of plastic). Got a strong friend to lift the door off the hinges while I replaced it. make sure you get the right one for left or right doors.
7014663 Sub Zero Refrigerator Bottom Cabinet Hinge Cam LH (7014663) (7014663) - Genuine Refrigerator Parts
Sep 01, 2014 | Sub-Zero 632 / S
Can you reverse the door handles on all 650s?
No they are shipped from the factory as right hand or left hand and there is no place to mount the hinge brackets on the opposite side.
Apr 24, 2014 | Sub-Zero Refrigerators
Switch door to open other way
Start at the top hinge remove it. Yank the top door off. Remove the middle hinge and lift off the bottom door. Move the base hinge over to the other side.set the bottom door on it. Install the middle hinge then set the top door. Note: If the doors are reverseable their will be plastic covers over the holes on the other side. Be sure to put them covers in the side you took the door off in case yall ever want to reverse em again and for cosmetic reasons and such. If you have water and ice in the door get a pro to do it for you
Oct 05, 2012 | Dryers
No cooling
Look at the back wall on the left hand side. "near the middle shelf"
If you find a wet spot or ice ball odd are you will need a Evaporator coil.
See if the fan is running when you open the door. By pushing the fan and light switch closed. "light will go out, Fan should come on" easy way to see if thermostat is telling the compressor to run"
Sep 03, 2012 | Sub-Zero 561 / F
How much freon for sub zero 601R
The amount of freon for the refridgerator are listed on the tag where the model and serial number are. Open the door and look on the frame usually on the side the hinges are on.
Apr 28, 2012 | Refrigerators
Squeaky sub zero side by side refrigerator door
Dear joeyh630,
I'm sorry to hear that you are having a problem with the hinges on your Sub-zero unit. I would recommend that you apply lithium grease to the hinges using a cue-tip. Lithium grease seems to work well and also holds up nicely. You should be able to find this grease at a home improvement store or auto parts store.
If you have any further questions or concerns regarding this or any other issue, please contact us directly. You can contact us via phone Mon-Fri. 8:00-5:00 CST at 800-222-7820. We can be reached via email at CustomerService@SubZero.com.
Thanks!
Customer Care Team
Sub-Zero/Wolf Appliances
Feb 05, 2011 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Nov 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Refridgerator light out, panel out, freezer fine
It's probably the swtich (the one on the left at the top of the door opening).
Sep 25, 2009 | Sub-Zero 680 / F
The refridgerator side of my side by side subzero is not cod enough. the coils are clean..what do I do now? the freezer portion is cold but is producing ice at a very very slow rate. the refridgerator is...
You probably have a leak in the evaporator and there is not enough refrigerant left to cool properly. Sub Zero has a 12 year warranty so You may want to replace the unit. You need to call a servicer to check it out.
Sep 22, 2009 | Refrigerators
Refridgerator door
a lot of the sub-zero doors are good and heavy duty, but the plastic shim under the hinge wears and can drag when you go to close door, usually a simply repair to find a washer for the door hinge.
May 16, 2008 | Sub-Zero 700TCLH Bottom Freezer...
Refrigerators Logo
113 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
