Question about Sharp VL-A111 Camcorder
Transferring from camcorder to DVD
Is there any way that i can transfer my videos from 8mm tapes straight to DVD through a DVD recorder?
My camcorder is a Sharp VL-A111
SOURCE: playback problem
Have the same problem.  This is what I have found in trying to solve the problem.  It appears that it is a tracking problem and it appears that either your new "used" camera has the problem or your original camera had the problem.
A simple test would be to take another camcorder and see if the tapes play. If they do, and a recently recorded tape DOES NOT, you may just need to get another camera. Or, see if the camera can be re-tracked at a repair shop. However, be sure you have copies of your most recent tapes recorded with the bad tracking
Posted on Mar 01, 2009
  • 423 Answers
SOURCE: Transfering 8mm video tapes to dvds
Hi there. You need to transfer your videos to your computer and then burn them to DVD using a program like Record Now, or Nero. You should be able to get this from Best Buy, or you can get it online from their websites. If you have any other questions, let me know with a comment. Thanks for coming to FixYa.
Posted on Mar 03, 2009
  • 411 Answers
SOURCE: No audio, but great video playback (Sharp VL-N1 analog 8mm)
mic is bad,so replace mic
Posted on Mar 04, 2010
  • 238 Answers
SOURCE: What type of recording tape does the Sharp
You should use 8mm casettes.
You can buy it from the below link.
Posted on May 05, 2010
  • 4889 Answers
SOURCE: How do I transfer the small tapes I recorded on my
You should capture the tapes. First connect the camcorder to the computer then open a video editing software like windows movie maker. Click the capture from camera button to start capturing. Once its done you can save the movie to your computer.
Posted on Aug 31, 2010
SOURCE: Transferring to DVD?
you can purchase a dvd recorder that has inputs for usb, dv in, video/audio in(yellow/white/red), and also a port for memory sticks. Sony has a unit called DVD Direct. They arent really available anymore from retailers but you can still get them on eBay. They work great and you can get them for about $120.
Posted on Sep 25, 2011
0 characters
1 Points
When attempting to transfer to CD for long term preservation, lines in video are transferring. Can the heads be cleaned are other things to be considered during transfer from original 8mm take of Analog...
8mm head cleaning tape should be available at most electronic stores.
If the tape does not help after two or three attempts you are best to take it to a techincian.
BTW: The tape is one of the best backup mediums. Transferring to DVD is a great option for viewing only.
Feb 06, 2011 | RCA PROV730 8mm Analog Camcorder
How can i convert tapes to dvd
You can connect the Camcorder to the Computer using A/V interface to transfer the recordings to Computer.
Once you transfer the recordings from tape to computer, you can use any burning software to burn the recordings to DVDs.
In order to capture the analog videos, you can use the Windows Movie Maker available in the Computer.
If you need further assistance please click hear to reach me..
HOping a positive thump after your issue is solved.
Jan 13, 2011 | Sony Hi8 CCD-TRV138 Camcorder
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine.
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
Sony handycam video cassette
To the best of my knowledge 8mm VTR's have not been available for some time now. On the other hand there are plenty of Hi8 cameras and players available after market. eBay is a great source. Keep in mind that Hi8 cameras and decks will also play standard 8mm video tapes.
There are also many video tape transfer services that will transfer your 8mm tapes to DVD or other formats of your choice. Just Google "videotape transfer service"
Aug 28, 2009 | Sony Hi8 CCD-TRV138 Camcorder
Mar 03, 2009 | Sony Handycam CCD-TR517 Camcorder
I have a sharp camcorder model vl-e785u and I am needing to know if there is somehow to download my tapes to a computer to burn to a cd.
I don't know about downloading to a computer, but you can buy a VCR/DVD recorder for about $140, put the VHS-C cartridge in the adapter and transfer to a DVD, or plug your Camcorder into a DVD recorder (about $119) and copy. It couldn't hurt to check out some of the transfer services that could do a little editing and copying for a modest fee.
Mar 01, 2009 | Sharp VL-E785U 8mm Analog Camcorder
Broken camcorder 8mm tape
Hi There, You can fix your tape yourself. 1- wind out tape from both sides of cassette. 2- cut both sides to form straight edges. 3- cut a small thin piece of clear scotch tape. 4- from cassette tape, put both sides together with recorded side facing down-- in other words you will be putting the scotch tape on the inside of the recorded tape. 4- line up the two ends and splice them together. - cut the excess scotch tape from the edges. Make sure there is no sticky stuff left there because if there is, it could rip out your video heads. The tape should only be played once and at that time, should be rerecorded to dvd or another media.
Hope this helps, mr cicmo
Jan 12, 2009 | Sony Handycam CCD-TRV68 Camcorder
Sony Digital video Camera Recorder DCR-PC6E/PC9E
did you received my message?
Clarification Request by welcomejee, posted on Sep 01, 2008 please mention what dvd recorder you have or you want to transfer movie files on PC hard disk.
Sep 01, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Transferring hi8 tape to Everio hard drive
I play the hi8 video back to the T V lcd 32 screen
Because you video in not in digtal format
From the Telly i set up the try pot install the camcorder jvc 30
everio zoom in to size start the camera camcorder
for video start the hi8 video in the telly pres the recorder
on camcorder and record. This is the way the piratcy is done in the Cinamas
Jan 03, 2008 | JVC Everio GZ-MG130 Camcorder
Maybe when you play the 8mm tape on the TV and have DVD/TV recorder hook up to the TV.
Oct 23, 2007 | Sharp Viewcam VL-A111U Camcorder
Sharp VL-A111 Camcorder Logo
46 people viewed this question
Top Sharp Video Cameras Experts
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
