Question about Peg Perego Vespa Scooter
Trouble Starting VESPA
I have a new 2007 Vespa LX50. When I start it the engine fades and dies within a few seconds. Can anyone help....do not know much about the mechanics Pretty much the same thing. It's always been hard to start and it sounds like a starter problem, not a battery problem. Now, if it starts it runs rough and dies before I can move it.
    Problem Solver:
  • 6 Answers
Check for bad gas -- water in gas , it is likely you have left the choke on.
Posted on Jun 03, 2009
    Problem Solver:
I can't get my Vespa started.
Posted on Jun 05, 2009
Engine would not start because of bad Air-Gas mixture
I want to thank you and those on this forum for the great tips. I had painted the Crank Case on my Vespa ET4 and cleaned out the air filter. In the process I reconnected a hose to the air filter that had been disconnected. Bad move. It must have brought gas into the air filter and thereby upset the air-gas balance and I could not start the my Vespa ET4 engine. fast forward.... my Vespa ET4 Engine did not start for days.
After reading online here I realize that a gas smell was coming from my air filter that I had cleaned....BINGO...it was drenched with gas from reconnecting that hose and I think the upset in the air-gas balance was insuring my engine would not start.
[u]Solution to my Engine not starting:[/u] 1) Remove plastic piece ( I think it is called a faring) to expose easy access to air filter cover and it's screws 2) Undo screws and take off air filter plastic cover 3) Remove foam filter and soak in mix of water and dish fliud to remove gasoline. Wring out foam filter. Dip in water mix again and wring out again. 4) Start your scooter normally. Squeezing brake level and pressing starter button. You may here a bit of a cough sound and scooter should start right up...Mine did..... Ah air...we all need it and so does our bike engine. 5) Bike ran for a while and then I shut it off. 6) Tried to restart bike to make sure this was not a one time thing...engine started and then stalled out.... what happened..... Guess way too Much Air now. 7) Put back Clean foam air filter and re-screwed air filter cover on. 8) Tried to start bike again and it started right up. Great stuff. 9) Moved accelerator and bike purred like a large cat....Beautiful. 10) Went for a drive on the bike to work out the kinks and everything ran smoothly. Done..... (Hope this helps)
Posted on Jul 07, 2011
Check your fuel flo your tank may have sediments in it...
Posted on Oct 24, 2010
2007 Vespa LX 125 wiring diagram
Hi, Michael for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Vespa, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2007 Vespa LX 125 wiring diagram Google Search
Wiring digram for 2007 Piaggio Vespa LX 125
VESPA LXV 125 Service Station Manual
Vespa VESPA LX 125 2005 Parts
VESPA LX 125 150 Euro 3 User Manual
Jun 07, 2017 | 2007 Vespa LX 125
How do I fix my Vespa scooter which has oil, shows a red no oil light and won't start
Disconnect battery and reconnect after 30-40 seconds if did Not reset. Your sensor or a connection failure is likely here are a couple Vespa Forums http://modernvespa.com/forum/wiki-troubleshooting heres an informative Vespa site with details if repairs are needed http://www.scooterlounge.com/vespa/links/index.shtml
Good luck
May 18, 2016 | 2011 Vespa LX 50 2T
Engine rattle in Vespa LX50
these toys don't have engines, just electric motors
Jul 25, 2014 | Peg Perego Vespa Scooter
Where is the battery on the vespa lx50
under the seat - near the gasoline inlet - open the screw and lift the battery cover
Mar 14, 2013 | 2007 Vespa LX50 4T
Gas overfill - Vespa LX50 won't start
It is unlikely that being unable to start is caused by overfilling the tank.
Remove the spark plug, clean it with a wire brush, and check for a spark. Turn the ignition on, put the spark plug and lead attached against the cylinder head and kick it over. You should have a fat blue spark under the electrode. Check the gap and replace the plug.
Another thing you can check for is either a pinch or an airlock in the fuel line to the carburetor.
Jul 30, 2017 | Sport & Outdoor - Others
2007 Vespa GT 200 starter engages when brake lever is pulled
Hi, Anonymous your right-hand control housing starter button has shorted out with the front brake light switch what you need is a wiring diagram that is in the back of your service manual if you can't find the first and best tool you ever bought for your Vespa, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa Starting Vespa with brake lever
pressing brake to start the scoot issue
2007 vespa gt 200 wiring diagram Google Search
Vespa GT 200 Workshop Manual
VespaGT200
VESPA RALLY 200 Manual
Nov 23, 2017 | 2007 Vespa GT 200
Trouble starting my vespa
check your takn and clean your fuel and air filter and check the fuel line from the tank to the carb and blow it out, 1 of these should help.
Jul 12, 2009 | Peg Perego Vespa Scooter
Vespa cutting out after around 40secs of running
getting to much fuel apparently.But have never seen or heard of one of these.
Dec 22, 2008 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
1,486 people viewed this question
Top Peg Perego Toys Experts
romney2012
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
