Hi Maytag LA612 washer. The agitator won't agitate at all. It fills fine. I can turn to the spin cycle and it spins just fine. I replaced the belts, in hope that those were the problem, but no change.
  • Washing Mach... Master
  • 19,396 Answers
The belts do not give this kind of problem. ouplerWhen a belt is broken or worn, apart not agitating , the washer usually does not spin. One of the belts operates the clutch , if that was broken the machine may spin but not agitate.
Parts that can be involved are:
Drive motor : Hi Maytag LA612 washer. The - _.gifPS2017259
The motor is tested by energizing and testing the three switches that operate the motor, if one of them is faulty the motor may not operate when agitating. Here parts to test.
And diagram:
The agitator itself.
Any broken mechanic part in the agitator, as a retaining ring, or the shaft where transmission attach to agitator can cause the agitator not to work.
Here the diagram:
The transmission.
The transmission may have a worn or broken gear, or some other internal problem.
A wiring or control problem.
If you do not find anything else, check wiring, motor timer and timer board.
PS2022099
Regards
Posted on Jun 02, 2009
Hello, I have a Maytag Bravos MVWX550XW washer that will not rinse or spin, only wash. The drum moves. I replaced the washer inlet valve, did not fix the problem. Removed the lid switch assembly...
hi Melanie.
this is all i could find out.
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
How to Drain Washing Machine That Won Drain Family Handyman
What is wrong with a washer that does not spin? If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle
Washer Doesnt Agitate or Spin
Maytag Washing Machines will not rinse or spin Google Search
Dec 12, 2017 | Maytag Washing Machines
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Agitator won't spin and water won't drain during spin cycle
Hi
Try these things first.
1) Verify a circuit breaker isn't tripped
2) Advance the timer control dial slowly 360 degrees-
If the washer starts spinning, then we know the motor and drive belt are fine but that there is something wrong with either the timer control dial or the agitator solenoid. Call in a professional for this.
If the washer doesn't budge, then verify that the drive belt(s) is attached and not broken by removing the back panel. If the belt is broken, replace it. If it is loose, then tighten it by loosening up the bolt holding the motor and moving it on its swingarm (much like a car alternator) until there is a 1/2 to 3/4 inch deflection in the belt. Some washers use reversing motors. It's possible the motor works on the spin cycle but not on the wash cycle. If so, call a pro.
3) Visually inspect the lid safety switch- Is it loose or cracked? If so, the washer might work intermittently, stopping at different cycles.
4) Check motor and drive belt- Remove the main access panel (usually in the back). Is the motor spinning, but the drive belt isn't? If so, then you have a drive belt problem. Go here. If the motor isn't spinning, then go here for washer motor troubleshooting.
If none of these tips resolve the problem, then there's probably a more serious problem with either the motor, the transmission or the agitator itself. If this is is the case, call in a pro.
Thanks for using Fixya.
May 22, 2011 | Maytag Washing Machines
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag model la612 spins but won't agitate and making screeching noice
from the belt, please fastening the bolt and possibly it lose a little.
Oct 11, 2017 | Washing Machines
Maytag wahser not agitating
Either your transmission is bad which might carry a 5 year warranty or your lid switch needs replacement
Nov 14, 2007 | Maytag Atlantis MAV9750A Top Load Washer
Washing Machines Logo
1,010 people viewed this question
Top Washing Machines Experts
