Question about Maytag MMV5186A Microwave Oven
Maytag microwave START button will not work~all other buttons do
Less than one year old...when i enter a cook time, the start button will not work...i'm promted to enter a cook power, but when i do that, still the start button will not work.
  • William Miller
    William Miller May 11, 2010
    It may be a bad door switch or door switch mount.
    Try lifting up and / or pushing down gently while you press Start after entering the time.
    Let us know if that works.
MicrowaveSvc
  • 9047 Answers
SOURCE: Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 28, 2007
Illeagle
  • 525 Answers
SOURCE: Panasonic microwave start button
You may have a sticky door switch. Try a simple "slamming" of the door, don't over do it, just a little harder than normal. This may help pop the plunger in the switch back up. The switch could have also become loose and moved out of its adjustment.
If this does not help, a technician should save you time and money with this sometimes perplexing problem.
Posted on May 24, 2008
SOURCE: display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
determined from whirlpool that the f2 display is from the control circuit board. the board's problem is intermittent and needs eventually replacing. not covered by warranty. determined that whirlpool has reduced the warranty for the electronic circuits in its appliances from 5 to 1 year. this is great for consumer confidence in whirlpool. have had trouble with 2 other new whirlpool appliances. probably will not buy another whirlpool appliance.
Posted on Aug 04, 2008
  • 3 Answers
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave won't heat
Sorry my Clarification Request came out as a single blob of a paragraph.
That's not how I typed it. I never write that way!
So I've pasted it here, but as a solution.
Magnetrons generally should last about 2000 hours, but several factors can shorten that.
If it's not OVER ten years old (from the purchase date or the date on the tag inside the unit) then the magnetron is still under warranty.
From the owner's manual:
"For the second through the tenth year from the date of original purchase
"The magnetron tube, if the magnetron tube fails due to a defect in materials or workmanship. During this nine-year limited warranty, you will be responsible for any labor or in-home service costs.
"For the above limited warranty: To avoid any trip charges, you must take the microwave oven to a
General Electric Customer Care® servicer and pick it up following service. In-home service is also
available, but you must pay for the service technician’s travel costs to your home."
GE Customer Service is here, and you can verify the warranty status and find your nearest authorized servicer.
If you're sure the magnetron's bad, it's still under warranty, and you or a friend are handy, they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
It does sound like the magnetron overheated and the magnetron's thermostat opened until it cooled down.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
Since yours is a counter top model, there are less of those factors to worry about.
When you hit Start to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
You can find helpful exploded view diagrams and order parts if needed by entering your full model number from the tag on the oven here.
Let us know what you find out or decide.
Posted on Jul 07, 2009
Sears kenmore elite has a message display to enter tcp code. kenmore microwave oven
TCP is "True Cook Plus" in Kenmore speak.
Here is a cut/paste of a section of the manual.
*CUSTOMIZING TrueCookPlus' You may find that you prefer TrueCookPlus® to cook your food more or less. TrueCookPlus " can adjust to your tastes - to cook your food hotter or cooler - automatically: Example Clear 1. Press the Clear button. (§H§ 1 2. Press the TrueCookPlus® button twice. 3. If you want less cooking time when you enter a TrueCookPlus code, press 1. This will decrease the time by 6%. 345 4. If you want more cooking time when you enter a TrueCookPlus® code: Press 3 for 3% more cooking time. Press 4 for 6% more cooking time. Press 5 for 9% more cooking time. 2 5. Press 2 to reset TrueCookPlus* to factory setting default time. 6. Press the Start button.
I didn't try to clean up the copy
Hope this makes sense and helps.
Sep 14, 2017 | Kenmore Microwave Ovens
How do I change the power level?
Usually, power level is selectable using the keypad.
Jan 03, 2016 | Samsung 1.8 Cu. Ft. Over-the-Range...
Hello, I have an AEG microwave, 6 years old. When I turn the button to chose the cookingtime and the WATT , the display shows what I choosed so thats OK. When i then press the start button the microwave...
This can be due to wrong choice or fault in the power supply ,main board or the magnetron.
You should try with a preset selection and if the microwave works then the fault relates to correcting the power to time settings.
Check out with microwave cooking tips.
Feb 01, 2013 | AEG MC143EUX 750 Watts Microwave Oven
Jes1139wl03 microwave has power but will not start cooking
The problem is the magnetron/inverter board if less than 7 years old, parts alone will approach the price of a new microwave oven.
Apr 13, 2012 | GE Microwave Ovens
Let me know the functions of microwave?
Sorry to read about your problem, I hope this helps you out.
Display: This is used to show the time, cook time and options you chose during you use.
Cook: Use this feature to cook fresh vegetable, frozen vegetables, rice and cassroles.
Enter/Start: This is used to start and enter any option you choice while operating the unit.
Stop/Clear: Use this function to clear or stop the unit during cooking or choosing a feature.
Reheat: This is use to reheat dinner plates and left overs. Be sure that you do not use any plastic foam or metal plates/utensils this can cause damage to the unit and may cause injury.
Auto Defrost: This is used to defrost food by weight and type. EX: If you have 1 pound of chicken, meat or fish press in the food code by using 1,2,3 and then the weight in pounds (1 pound would be 1.0 enter.)
Quick Frost: This is use with the Rapid defrosting method for 1.0 pound frozen food. If you have a pound of meat, chicken or fish press Quick Frost and it will defrost for that weight only.
Cook Time: This is to set the cook time for the food you are trying to heat or cook. Enter the time you wish to cook and press enter/start (EX: 7mins and 30 secs = 730/start.)
Clock: This is used to set the time of day. Press Clock the the time of day it is and clock again (EX: 11:00 would be 1100 then clock.)
Number: This is the key pad used to enter the cook time, clock or power level.
More: This feature is to add time to the cooking time only in ten second intervals. If you want to add time without restarting press this button to add ten seconds each time it is pressed.
Less: This is used to decrease the cooking time by ten second intervals. If you want to decrease time without restarting the time press this to decrease cooking time in ten second intervals.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Power Level: This is use to choose the power level in which to cook or heat food or beverages. To change the default setting of 100%, press the power level button and press the level you desire, if you desire only 50% then press power level the 5 and enter/start. Hint: Change the Power level before entering the time your setting to cook
EZ-ON: This is to quickly start the power level to 100%.
Vent High/Low/Off: This is to turn the vent located on the outside of the unit during use. You have the option of turning it off, on, high or low.
Light High/Low/Off: This controls the light on the bottom of the unit if you have a mounted range above your stove or under your top counter cabinets.
Hot Water: This is used to heat water for beverages such as coffee and hot chocolate. Use Extreme caution when removing baverages from your unit, they will be hot and could cause injury.
Popcorn: This is used to pop popping corn, when placing the popcorn in the microwave press the this feature and enter/start and it will automatically start the correct time for cooking. This feature is designed for the individual packaged popcorn use. Do not place any foil or loose popcorn in the unit this could cause damage or injury.
Kids Meals: This is used to REHEAT meals for children it works at a lower power level. This can be used to reheat hot dogs, oatmeal, baby food and soup. Do Not place any metal objects or objects than can melt this can cause damage or injury.
Warm Hold: This is to keep foods or drinks warm for any length of time up to 99 minutes and 99 seconds. Although it is not a recommended to run a unit at the maxium time limit.
Melt: This is used to melt butter, margarine, chocolate, cheese and marshmallows. Do not leave these items unattended during the duration of melting time to prevent any unwanted over heating.
Soften: This is used to soften ice cream, butter, cream cheese, and frozen drinks. Do not place anything in a container that is made of foam or metal this can cause damge or injury.
*Child Lock: If your model has this feature it is used to lock the unit to keep a child from pressing buttons or causing injury.
Open: This is the handle or button on the front of the unit to open the unit after the unit is done cooking or in use. Do not open the door during the use, always press the Stop/Clear button first. Also do not remove hot items without oven mits or waiting time food is at a safe handling temperature.
Jan 03, 2011 | LG LMVM2277ST Microwave Oven
How do I adjust the power levelthen start the
Press "Power" until you get to the level you want. Then enter the # of minutes on the keypad (CANNOT use express cook times.) An alternating runnig hum will let you know the setting is working.
Nov 08, 2009 | Hotpoint RVM1635 Microwave Oven
My mother just bought an Emerson MW8119 Microwave and can't figure out how to only set say 15 seconds cook time. Is it possible?
Hi! I just purchased the same microwave, and came online to find the solution. I was then able to find the correct answer to this problem. On this model, Emerson does not put a "time cook" button for odd cook times such as 15 seconds. Instead, they have you push the "Power Button" prior to setting the cook time.
If you want to cook on full power, press the power button once, and then enter your cooking time and press start. If you want to cook on 50% power or 30% power or something like that, push the "Power Button" several times until the appropriate power level is displayed, then enter the cook time and press start.
The reason that it starts up right away when *********** pushes the 1 button is because Emerson has the quick cooking feature for 1 minute through 6 minutes. You only have to push the number once to get the 1 minute cook time or anywhere through 6 minutes respectively.
Hope this helps!
Jun 22, 2009 | Emerson Microwave Ovens
Apr 08, 2009 | Emerson Black Microwave Oven
Display has a f2 code on it. whirlpool oven is model mh1150xm and less than 3 years old.
Aug 01, 2008 | Whirlpool GH5184XPQ Microwave Oven
Sanyo Em-u1000w
i have the same microwave and mine does the same thing,try this push the clock button and enter the time or just push 100 and hit the clock button and then enter in your cook time and hit start.
Jan 10, 2008 | Sanyo EM-U1000W Microwave Oven
Maytag MMV5186A Microwave Oven Logo
694 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
