Question about CTX PV 720 17" LCD Monitor
Need parts monitor seems to go dark after 15 seconds.  It actually just dims so much you have to put a light shining on it to see the test screen.  I am looking to find the board with the ballast on it to replace it.  Any Ideas?
  • Walter Chavez Mar 17, 2008
    I have the same problem with the same monitor PV720, 3 of them, I believe it is the Inverter board, I am trying to locate thr part I think the part # on the board is INV17-411A, or FS2B1046.
  • 293 Answers
The problems on the backlight inverter power supply. Open it up and check all the capacitors, it look like a tiny battery cap on the side had writing on it. (Example 1000uf 16v ) if you are lucky you can spot it right away...with a bulged on top of each caps. If not, just replaced all of the caps... Good luck!
Posted on Dec 07, 2008
I have sam 51on lcd moniter with dim display problem
The screen displays is dark/ dim because there is no backlight.
There are two parts responsible for lighting the display. First is the CCFL (Cold Cathode Florecent Lamp), which is the back light and the second is the Inverter board, which provides high voltage to the CCFL. Either of the parts can be faulty or in some rare cases both.
In most of such cases that I received for repair, it was Invertor. Inspect the Invertor for any apparant physical damages (burnt coil or circuit components etc). Inverter can be checked by disconnecting the present CCFL and connecting a fresh/ working CCFL (Backlight) before actually removing the CCFL as it is difficult and unnecessary to take it out if its not the fault.
Hope it helps! Good Luck!
Apr 12, 2011 | Samsung SyncMaster 510N (Silver) 15 inch...
My samsung 940b it has a clear bright screen ( as normal ) just for 2 seconds then the screen turns dark but you can see very very dim Window logo.Turn off the power ( does not matter for how long ) when...
Shine a flash light onto the monitor, if you can see icons/desktopon the screen then you know you need a new monitor!
You should be covered under warranty!
Mar 02, 2011 | Samsung SyncMaster 940B Monitor
Monitor went dark and does not light up at all. Is it more cost effective to trash it and buy another or is repair feasable?
If you still get the blue power light output but it is dimmed, I've had the same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
Jun 24, 2009 | Gateway FPD2275W LCD Monitor
Dell FP1504 Displaying very dark " Ithink this is backlight issue
If you are not a technician you can´t solve this problem because are to desasembly your device and check the Q7 and Q8 and C5 that components are on bad conditions and need to be replaced,I told you because i repaired one of these monitors for the same problem
May 08, 2009 | Dell UltraSharp 1504FP Monitor
Dark screen on me laptop
the LCD backlight has failed, you will need to replace the LCD assy (about $200)
Jan 18, 2009 | Dell Inspiron 5150 Notebook
Dark screen
click on start>control pannal>adobe gamma> set ur
Acer AL1512 LCD Monitor Problem
Based on your description, the problem could either be:
  • CCF (cold cathode florescent) lamp; and/or
  • inverter.
Since the Acer AL1512 works fine except dark, we can rule out the video interface, power supply and ontroller. Again, the display showing (even dimly) is significant, it tells us that the components are working except that for some reason and most likely it is heat related. Possibly a cold solder, a loose connection and/or a dried up capacitor. You could actually verify this be shining a flashlight diagonally across the screen and some semblance of the desktop albeit dark would be slightly visible.
What is required is opening the LCD lid/panel to perform repairs. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 23, 2008 | Acer AL1512 15" LCD Monitor
LCD starts to display for about 2 seconds then goes dark.
lamp(s) perhaps.... with an LCD monitor (the desktop kind) you can shine a lite behind it. if you can see things on the screen it's the lamps... if you can't it's something else.
Aug 28, 2008 | Toshiba Satellite 1135-S125 Notebook
Dim picture
This is the way how to examine where the problem is. If the screen is going dark. You have to check that you can see the image on screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons (Power on both cpu and monitor), there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see any icon on the screen. I would say that there are some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or dark spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 09, 2008 | Dell E176FP 17" LCD Monitor
Monitor goes blank
Sounds like the back light inverter board is bad. It's a very common problem. LCD's use four small cold compact fluorescent bulbs to back light the display. (thats what gives the LCD it's brightness allowing you to see it) The inverter board runs these lights and when they go bad they will typically show symptoms like you have or the monitor power light comes on and you have either no display or a very dim display. If you ever have one that has no display but the power light is on you can check by shining a flashlight directly into the LCD from the front (right into the screen) if you can see an image then it's either the inverter board (most likely) or the CCFL bulbs have gone bad. The inverter board and CCFL's are replaceable. Good Luck, El Duderino
Nov 16, 2006 | Dell E153FPc 15" TFT LCD Flat Panel...
CTX PV 720 17" LCD Monitor Logo
173 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
