Question about Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso
It wont brew drip coffee
What are the instructions to brew drip coffee in my Krups XP2070 Programable coffe machine?
    New Friend:
  • 39 Answers
What are the simptoms? Once you pour the water and add the coffee it should start when you press the coffee button.
Posted on Dec 29, 2009
Krups ea 8250
If it doesn't grind , than there is no coffe , it will surely come as water .
Grind it first , and than brew the coffe .
Oct 24, 2013 | Coffee Makers & Espresso Machines
I have a Krups xp2070 that sends hot water to the overflow instead of through the espresso (when trying to brew espresso).
The unit has two pressure valves that control release to the drip tray. Once they fail the hot water will go directly to the drip tray when the pressure goes up. The fix will be to replace the pressure valves (pair in series) which only cost about $20. I replaced mine and it fixed the problem. Good luck and happy espressos.
Dec 29, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
A Krups KM7005 coffee maker/grinder doesn't heat or drip water .
Mine had the same problem ... all the lights are on, grinding works fine, but no heat on the plate, and no dripping of water.
After a weekend on the workbench, I mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. To date, I have helped 13 people on this site fix this exact problem.
I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Dec 16, 2009 | Krups Small Appliances Espresso Machine
Krups XP2070 coffee machine - new - espresso side - water goes straight into the drip tray & not thru the filter. I have the exact same problem-that's why I'm on here looking for a solution!
You either have a blocked filter or defective valves. Try the unit without the filter to see if you get liquid out of the group. Most likely you have defective pressure valves (pair) which are not too expensiv to replace.
May 30, 2009 | Krups XP2070 10 cup Coffee Maker/15 bar...
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Aug 03, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Turning off the beeper
The manual is not too clear on this function. Turn the coffee side on, press the middle button on the coffee side for > 2 seconds and then use S1 and S2 button to select a mode that does not show the bell.
Jul 11, 2007 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups XP2070 10 cup Coffee Maker/15 bar Pump Espresso Logo
404 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
