Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Murray 14.5 hp OHV - starts, runs then struggles, backfires dies
Murray lawn tractor 14.5 hp OHV Starts runs then struggles backfires and putters out. FUEL flow, spark is good I am going to take carborator off and clean... Any other SUGGESTIONS ??
  • 218 Answers
SOURCE: Need a belt. 12 hp 40 in. deck lawn tractor.
Hey...my name is Keith...im not sure which belt you are asking for...but the drive belt is a 37X61 and the deck belt is a 37X62..i hope this helps
Posted on Jul 01, 2009
SOURCE: Riding mower having problems starting then runs roughly
I have a Scotts _ John Deere law mower tractor model S2048-S2554 Serial number 020-001, the engine runs but sounds like it is going to die or it needs air --- it runs unnevenly
Posted on Jul 20, 2009
  • 13 Answers
SOURCE: Starts up fine then dies when hot
your automatic choke is defalting
Posted on Jul 21, 2009
kamakani
  • 104 Answers
SOURCE: Murray Lawn Tractor Model 42576x92A will not start...no spark?
http://www.partsandservice.com/bin/ipl.cgi
I found a wiring diagram that I hope helps you out.
Posted on Jul 29, 2009
SOURCE: DYT 4000 Lawn tractor won't start
I solved the problem after buying carb and fuel pump rebuild kits.The carb kit didn't fit anyway, but didn't need it. The problem was in the fuel filter. I had forgotten the problem happened when I ran out of gas. Inside the fuel filter is a washer held in place by a spring. Without fuel it apparently lost pressure and the washer slipped out of place about 1/2", which was enough to let all the gas through that could. The rebuild kit had a new rubber gasket. I won't let it run out of gas again.
Posted on Aug 11, 2009
I have a 17.5 Murray riding lawn mower engine runs well when I engage the blades it spits and sputters and starts backfiring what could be the problem
Sounds like bad fuel....runs fine when not under stress but poops out under pressure. Drain fuel and refill with new mix if it's a 50/50 gas-oil blend.
Apr 26, 2016 | Murray Garden
I have a Murray 20 model 20213A with a Tecumseh engine. The lawnmower will start but it dies a few minutes later. What could cause this and where can I get a manual for this model lawnmower?
Use high test fuel without ethanol, and
Murray 22" Lawn Mower - Carburetor Cleaning, Nasty ...
? 7:33
www.youtube.com/watch?v=_dzcDZUh1MY
May 10, 2013 - Uploaded by mountainbikekayak But here is the link for the start up of this Murray had to replace the plug as well also ... as well: Murray 22" Lawn Mower 6.5 HP OHV -- First Start after Carburetor Cleaning - Part III - May 9, 2013 ... When I start it, it runs for 3-4 seconds and dies. ... Youcan also find you engine Model # online and view the ...
Sep 09, 2015 | Tecumseh Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Murray 42506x92A (1998) 42" Lawn Tractor, starts easy, but surges and dies. Over and over... It acts like it is running out of fuel. I changed the fuel filter and spark plug, but no improvement.
Check the fuel bowl to see if anything thing is in it. If it has a auto shut switch on the bottom of the bowl, it may be the cause as well. Next check that the valves (ohv) are adjusted right.
Oct 08, 2014 | Garden
Murray Select 16.5 hp OHV 42
is one of the blades bent?is one of the bearing s seized or binding
Apr 16, 2012 | Briggs & Stratton Garden
I have a briggs and stratton 14 hp ohv engine on my murray lawn mower it starts and runs good until i go to full throttle or engage the blades then it seems to flood out and start backfiring i can lower...
It sounds like you are putting it into choke mode. The choke is usually all the way up on tractors. And it will make it backfire and flood out. Just rev it high enough to work and don't go into the choke mode. hope this helps.
Apr 21, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Need manual for Murray 20'' 3.5 hp lawn mower
sounds like its running out of gas. I changed spark plug, still sounds like its about to die
Apr 11, 2010 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,320 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
