Question about OKI Office Equipment & Supplies
Reset image drum error code 342 on OKI 9600
I have a OKI c9600
I the middle of a print run of about 20 pages the printer run out of A3 paper.
After reloading A3 the printer didnĀ“t start agian.
It showed the following erro code 342
The graphic display of the printer show me that I should reinstall the cyan picture drum - that its not in place properly.
When this is done - the printer restart showing the picture with "lewel bars" - than there is a "?" on cyan picture drum.
Clicking on "Help" sow the Error code 342.
What to do?
With regards,
SOURCE: OKI 9800 with "342" error code
problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Posted on Sep 16, 2007
The Machine
  • 788 Answers
SOURCE: LSU ERROR shows in display panel
The LSU is the Laser Scanning Unit or "printhead". There is a mirror in there that spins really fast, if the mirror spins too slowly (bad motor, low voltage) it gives an error. Sounds like you would need a replacement LSU. Have the printer serviced.
Posted on Jan 14, 2008
SOURCE: Printer jam message in oki
Disconnected sensor at paper exit
Posted on Sep 24, 2008
  • 78 Answers
SOURCE: fatal error 917 on an Oki C9600 printer
A fatal error 917 means there is a problem regarding the belt **** sensor.
Usually it means the printer can't see the transfer belt rotating.
First thing to try is to remove and re install the transfer belt, if that does not work you should replace the transfer belt.
Posted on Jan 07, 2009
  • 2120 Answers
SOURCE: OKI 3300 Image Drum Problem
Did you remove the plastic tape from the new cartridge?
Posted on Feb 16, 2009
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
OKI C9600 paper jam problems: Paper jams continually, either on first attempt to printing or if it prints a page the 2nd page inevitably jams. Printer has only done 1500 pages since new ,and i have removed...
Wow! That's quite the printer you have there. The C9600 does have a feed roller in the front; and it's not uncommon for paper to still get stuck. Does your paper "fan" when it goes through; or simply, go through and jam? It's possible a paper feed sensor is bad too. Another thing you might want to check is the paper tray; and that the paper is set to the proper size.
Also be aware, the OKI 9600 had a recall a year or so ago for some potential "shock issues" I would advise you to check with OKI directly to determine if this printer is part of that issue too.
Jan 04, 2011 | Office Equipment & Supplies
C9600 OKI.....On the printed sheet there starts to be a light layer under the text. I goes from side to side on the sheet although the backround ought to be quite white. Any information of the end of the...
Perhaps drum exposed to sunlight too long. It will ruin drum.
Could be foreign material inside drum or printer.
Run heavy stock through printer with nothing on page, to do this-
Open up Word. type a period, or a comma.
Print 10-20 copies.
This may clear it up.
Mar 26, 2010 | OKI C5400 Laser Printer
My Oki C9600 Printer showed an error message, Reset Drum Basket - Waste Toner Transfer Error. After removing and replacing the toners, drum and waste toner bottle a new message appeared, 940: Fatal Error....
940: Error
The transfer mechanism of the
toner duct for ID is not operating
Check to confirm that the basket
assembly is in position (if it is
engaged with the gear of the
Check to confirm that the holder
magnet D contains a magnet,
and check the magnetic polarity.
Replace the HAL IC circuit
Replace the duct assembly
Dec 21, 2009 | OKI C9600hdn Laser Printer
Have a oki c9800 error 923. have replaced the motor unit for black image drum but it prints some pages and gives the error again
923: Error - Black Image Drum Lock Error
The K ID unit is not operating
Check to confirm that Image Drum is seated properly.
Check to confirm that the K ID
unit is in position.
Replace the K ID unit.
Replace the K ID motor.
Dec 10, 2009 | OKI C9600hdn Laser Printer
OKI C6100 has the following error when printer is turned on: Replace Image Drum 562:C Drum Life
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Nov 11, 2009 | OKI C6100dtn Led Printer
K image drum
Go to
menu>Configure Device>Print Quality>select Full calibrate now
once it's completed then run following action:
Menu>Configure Device>Reset>Reset Supplies>New transfer kit>yes
you are done but it works if there still remaining bit transfer kit if its run out then not gonna work.
Good luck and rate all answers.
Mar 31, 2009 | OKI B4600 Printer
OKI 5600 - Can you do a 'clean'?
Here's the 'secret' sevice manual:
I would also (very carefully) check for torn paper around the rollers of the imaging drum that might be rubbing the area.
Nov 09, 2007 | OKI C5200n Laser Printer
693 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
