Question about HP Officejet Pro L7680 All-In-One Printer
HP all-in-one not printing cyan color
HP L7680 all of a sudden stopped printing cyan. Replaced cartridge even though not completely empty and still no cyan. Went through all of the diagnostics that the printer has for alignment, cleaning, calibration. Self test diagnostic says print heads are good. Only 8700 prints on this printer and heads, any ideas?
  • jdlib Jun 02, 2009
    Are you talking about the ink cartdridge or the print head. Ink cartridge is new and previous ink cartridge was not yet all used. Could it be the print head going bad? I removed the print heads and cleaned manually. Expiration date on heads is 5/10/2010. Looks like it prints fine for the first 2.5 inches then fades. By the end of the print there are noticable lines perpendicular to the sheet feed. Any further recommendations? Thanks.
    Scholar:
  • 84 Answers
Place a soft clean tissue paper over the cartridge print head and leave for about eight minutes. You can secure it with the aid of a rubber band. It should be held firm ok. If the tissue paper is not dampened by ink then the cartridge would have gone bad or the ink dried. You also know that they have expiry date and could go bad while yet in the packaging b/c it has expired. Good luck
Posted on Jun 02, 2009
Why wont cyan and yellow print at all?
Use your machines built in programme to clean the ink jet heads
Feb 17, 2016 | HP Officejet Pro L7680 All-In-One Printer
Alignment failed when run
If Printer heads health condition is not good, alignment wont completes..
Four individual cartridges & Two print heads, each print head prints two colors.. Black& Yellow, Cyan & Magenta.. Verify which color is not printing properly(Color missing Or white bands)..
Perform 2 or 3 times print head cleaning through printer menu..Try for alignment.. If success end.. if no, replace the print head which is not printing properly.. Before replacing the printer head ensure that cartridge ink should be above 30%...
Oct 07, 2012 | HP Officejet Pro L7680 All-In-One Printer
Excess cyan toner is on electrostatic transfer sheet even after wiping it. All black and white pages are printed with cyan background.I am even using original cartridges.
Since you have Cyan toner in places where it should not be then the only possible cause is a defective Cyan Toner cartridge. I worked on one just last week where the customer complained about Magenta toner on their prints. I also noticed Magenta toner on the Transfer Belt just as you see Cyan toner on the Transfer Belt. I replaced the Magenta Toner Cartridge and everything cleared up nicely. The Transfer Belt Unit can also cause similar problems but it would not be ONLY one color like Cyan. It would be a mixture of all colors. My bet is replace the Cyan toner and you will be fine. If you have an old empty one just shake it up a bit and try it as well. This might allow you to verify before buying a new cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 06, 2011 | HP Color LaserJet 2600n Printer
Will PIXMA MP640 print with an empty cartridge
No, it will not. I have this printer and last week I ran out of cyan. Even though i only wanted to print black and white documents the printer would not print anything until I replaced the cyan cartridge.
Jun 25, 2010 | Canon Office Equipment & Supplies
My printer has two cartriges that are empty would that prevent it from printing ?
Yes the HP CLJ 2600n printer will stop printing when a toner cartridge registers as empty. The cartridges will have to be replaced or You could use the "overide out" option. This allows continued printing even though the supply registers as empty. Beware that diagnosing print quality problems because of toner becomes more difficult.
Overide Out
To change this go to the PRINT QUALITY menu then REPLACE SUPPLIES and change the setting from "stop at out" to "overide out".
Jun 16, 2010 | HP Color LaserJet 2600n Printer
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
What does cyan mean on a brother 240-c all in 1 printer it says replace cyan it wont do nothing
Cyan is the "blue/green" ink cartridge which is required to print in full color. Some printers stop working when one or more ink cartridges is empty. Get a complete set for some savings and for the next cartridge that gets empty. Printers are cheap now, it's the ink that gets costly.
Mar 01, 2010 | Brother Multi-Function Center MFC-240C...
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
C7180 Print in color without all cartridges
You can usually print with an empty cartridge, even though the software will inform you that the cartridge is empty. Your print quality may be affected, however.
Dec 03, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
436 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
