Question about Garmin Fishfinder 400c With Dual Beam Transducer
Fishfinder 400c? i have two questions lets say you are in 30 ft of water and the fish are in 9 ft and the fish finder is set to wide how far dose the cone go out. when the screen is moving where dose the pic start? dose it start at the transducer and move counter clock wise how dose the flasher featcher work
  • 285 Answers
Hi there.
Ok in WIDE beam mode the cone extends out 45 degrees from the transducer. This covers a fair area, but is best used only in shallow waters as the beam may not have enough power to penetrate deeper waters effectively. 30ft should be fine for WIDE mode however. Using a bit of trigonometry, the beam would extend to a diameter of 60 feet from the center point of the transducer on the sea/river floor.
The beam is a direct beam... It is not a rotational beam from the transducer... i.e. it does not rotate like a radar beam but shoots downward in the cone arc constantly. Imagine a torch being turned on and off very rapidly... The light shoots straight out from the torch in its own cone shape. This is essentially what the transducer does when it shoots out a signal every millisecond or so.
The image you see on the screen is the result of the hole cone of signals, however, the strongest sonar returns occur near the center of the beam. Weaker returns are shown which are located towards the outer edges of the sonar cone where the signal power is less. So if a fish passes right on the edge of the beam, it will only show up as maybe 1 pixel on the sounder screen as it is a weak return on the edge of the sonar cone, whereas if that fish passes under the center of the beam, it will show a larger, more continuous or arched shaped return as the fish moves from the outside of the beam, through the center of the beam, and out to the other edge of the beam under the boat.
Regarding the flasher... I would advise not to use this. It does work by showing a continuous top and bottom reading which displays as constant flashes around the circle readout. Anything it picks up in the beam will show as flashes in between the top and bottom readings. Using the display is far better and with practice allows you to better identify fish and bottom structure readings. Flashers were earlier forms of sonar readouts. Some older folk still like them but I believe the normal display is better for finding and identifying fish and can show structure shape as well (the flasher mode really cannot).
Hope that helps!
Please rate this solution on FixYa!
Posted on Jun 03, 2009
HOW CAN I CKECK HOW LARGE IS THE FISH TO FISHFINDER 160C?
the bigger the icon the bigger the fish no fish finder can tell you how big a fish is
Apr 15, 2013 | Garmin Color Fishfinder 160c
How do u put the gps locations in the Eagle Fishmark 500c Color Fishfinder
Hi, no good news I'm sorry. It's a fish finder not a combo fish finder/gps so you are unable to enter co-ordinates. Sorry Phil.
Sep 22, 2011 | Eagle Fishmark 500c Color Fishfinder
When we are deep water (500 ft or deeper) the fish finder will display 3.5-10 ft. and won't show the fish or shows tons of fish. Are we able to set the depth that we would like to see eg: if we are...
Im not familiar with your particular unit but you should be using a low frequency transducer for water over 500'; something like a 50 kHz transducer or a dual frequency transducer like a 50/200kHz for detail with the high freq. but increased depth range on the lower frequency. As far as setting it to 250 ft, you should be able to use the range feature and adjust the maximum to 250'. typically the factory default is automatic so it will caonstantly adjust the range based on the maximum current depth.
May 22, 2011 | Standard Horizon Standard Ff520 Fish...
I have had a Garmin 400c Fishfinder on my 20? Intruder for about 2 yrs. While fishing in the ocean last fall , I started getting intermittent false shallow readings on the unit (but the target depth...
Hello. Go to any autoparts store and purchase an aerosol can of electrical contact cleaner. It replaces ozone-depleting CFC's, trichloroethane, HCFC's, perchloroethylene and other carcinogenic chlorinated solvents. It will clean your contacts of corrosion and remove any and all moisture from them. And it will protect them well into the future. I use it everywhere on my craft, and on the trailer.
Spray the product, let it sit for an hour and then spray again. Use a cotton swab to remove any visible crud. Regards, Joe
Jan 12, 2010 | GPS
Eagle Cuda 168 has no display over 30 feet of water
Try good alakaline batterys(duracell or energizer)alot of those rechargables dont hold amperage and dont stay recharged long!!!! :)
Jul 05, 2009 | Eagle Cuda 242 Portable Fishfinder
Where do all the wiring go to on the garmin 400c
The rest of the wires are for interfacing (letting the unit 'talk') with other devices such as radar or GPS. These wires/colors are pretty standard and defined by NEMA (National Electrical Manufacturers Association). You need wiring diagrams for the devices to hook them up. For fun, see where 'nema' takes you with Google.
Jun 18, 2009 | Garmin Fishfinder 400c With Dual Beam...
Erratic depth and does not indiacte any fish
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Go to sensitivity set to manual then go up one on the menu and set it to 95 – 97 this will clear up the rapid change now set zoom to manual. Your back and running.
Mar 31, 2009 | Eagle Cuda 242 Portable Fishfinder
Garmin Fishfinder 400c With Dual Beam Transducer Logo
472 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
