No volume on television. The TV is not on mute. Hypersound is off. Tried to use remote to turn hypersound on but it will not work. All the sound setting will not work either. You can turn the Tv Volume up and hear the speaker's white noise only.
make sure you have tried the volume with the remote and the buttons on the set, if the buttons on the set work then their is a problem with the remote. if neither work then the sound circuit is bad in the set.
I think you are muting the the remote before you relocated...you need a remote to un-mute the sound of your TV...this cannot be done using the volume control in your TV unless you have the remote...if you loss the remote...buy a universal remote control
Take the set apart and see if there is a separate board in front of the set. Remove the board and check for cold solder joints first. If o.k., replace sensor. Then again you could contact toshiba and order another key pad for the set.
I know this sounds stupid but when was the last time you replaced the batteries in the remote? Can you use the TV volume button to change the volume up out of mute?
hi there, maybe you touch someting at the remote, try to experiment the bottons until it work, if still same problem, you have an amplfier section problem, test the speakers, some parts at the amplifier section. ty
