Question about HP 301566-001 Storageworks Ultrium (301566001) LTO 1 Tape Drive
Blinking Front LEDs
Ocasionaly the drive isn't working. The upper two LEDs and the lower Two LEDs are blinking on the front. (the upper two than the lower two, than the upper two,etc)
After reboot it worked again but now this fault occured the third time.
What is the problem?
Sadly I don't have the manual from that Streamer.
  • dirk_schombu Jun 15, 2009
    Thank you. But is there anyone who has the printed or .pdf manual to look up what is that blinking pattern meaning.
    since last time I had no problems but will now try a cleaning tape.
    Scholar:
  • 74 Answers
It sounds like the drive is getting confused
Check all cables and try new ones if possible as well as the terminator.
Again try and make it the only device on the bus if you can.
Try upgrading the firmware with the hp ltt program
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=406731&lang=en&cc=us&taskId=135&prodTypeId=12169&prodSeriesId=406729
After that you could also try a cleaning tape and a new data tape for an lto test in ltt.
Failing that i think you need to send it for repair
www.tape-drive-repair.com
Tape-Techie
Posted on Jun 12, 2009
How to remove starter from 2004 pacifica
REMOVAL
Disconnect the negative battery cable.
Remove (UPPER RADIATOR CROSS MEMBER) and relocate (UPPER RADIATOR CROSS MEMBER REMOVED) the upper radiator crossmember, (Refer to 23 - BODY/EXTERIOR/RADIATOR CROSSMEMBER - REMOVAL).
Remove the radiator fan module (FAN MODULE IN VEHICLE) (Refer to 7 - COOLING/ENGINE/RADIATOR FAN - REMOVAL).
Remove the wiring harness clip from front mount.
Remove the coolant line clamp bolt (COOLANT LINE BRACKET).
Remove the upper nut from the front mount (FRONT RUBBER MOUNT UPPER NUT).
Remove the upper starter mounting bolt (UPPER STARTER BOLT).
Remove the middle starter bolt (MIDDLE STARTER BOLT).
Raise vehicle and support.
Remove the lower front mount nut (FRONT RUBBER MOUNT IN POSITION).
Raise and support engine (SUPPORT ENGINE).
Remove the lower bracket bolt to transmission (BRACKET TRANS BOLT).
Remove the lower bracket bolt to engine block (BRACKET ENGINE BLOCK BOLT).
Relocate the front mount and bracket.
Disconnect the positive battery cable from starter
Disconnect the solenoid connector from starter.
Remove the lower starter bolt (STARTER LOWER BOLT).
Remove starter from vehicle.
Aug 16, 2011 | 2004 Chrysler Pacifica
Trying to remove an alternator from an 06 altima
Removal and Installation L4-2.5L (QR25DE) Engines To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of this section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Engine cover
    • Front/right-side engine undercover
    • Drive belt
    • Alternator harness connector
    • Engine ground wire from top mount
    • Alternator upper and lower mounting bolts
  3. Set the alternator aside and remove the top mount.
  4. Remove the alternator.
To Install:
  1. Slide alternator in place.
  2. Install or connect the following:
    • Alternator top mount
    • Drive belt
    • Engine cover
V6-3.5L (VQ35) To Remove:
  2. Disconnect the negative battery cable.
  3. Drain coolant from the radiator into a suitable container.
  4. Remove or disconnect the following:
    • Radiator
    • Front/right-side engine under cover
    • Drive belt
    • Idler pulley
    • Alternator adjustable top mount
    • Alternator lower mount bolt and nuts
    • Alternator lower front bracket bolt
    • Alternator harness connectors
    • Alternator
To Install:
  1. Install or connect the following:
    • Alternator in place
    • Idler pulley
    • Drive belt
    • Radiator
  2. Replace the engine coolant.
  3. Connect the negative battery cable.
  4. Start the engine and check for leaks.
  5. Recheck coolant level and top off as needed.
Oct 15, 2010 | 2006 Nissan Altima
I have a model T-10 endurance treadmill when it starts to run about 10 seconds it will stop and code E-1
Unplug unit and remove motor shroud ,check upper & lower wire for solid connections , check condition of magnet on front roller to see if missing or still in place if not replace the roller. Next to the front roller, their is a speed sensor ( reed switch ) unplug the leads going to the the lower board use a multi meter to check continuity of the switch by inserting the leads into the connector and manually rotating the front roller back and forth opening and closing the reed switch if not operating properly then replace the switch.
If the above procedure did not resolve problem and still ERROR 1 then check the Motor Control Board LEDs 6 & 7 If LED 6 isn't on, change a new upper console if on then motor control board needs to be replaced if LED 7 is not on ( that a mouth full )
If LED 7 on - current overload circuit meaning too much friction between belt and deck you will need to apply good quality silicon lubricant that may be purchase @ gympart.com part# TM001
If then if the overload problem, still exists and lubrication did not the help then the belt and deck are worn and need to be replaced. Very seldom do we need to replace the Drive Motor problem is around 8% failure rate. You will get plenty warning if the motor goes out.
May 12, 2010 | Endurance T10HRC Light Treadmill
The front LED flashes red & blue when I turn it on. What does this mean?
LED Indicators - LaCie 2big Network
The LED indicators above the drive bays and the front LED indicate drive status and activity.
During Startup
  • Front LED – blinks red/blue until both disks are powered on, then turns solid blue.
  • Rear LEDs – blinks red/blue until corresponding disk is powered on, then turns solid blue.
NOTE: If the device is not able to initiate the boot process following disk startup, the front is solid red.
During Bootup
  • Front LED – solid blue
  • Rear LEDs – solid blue
NOTE: If a disk is failing, both the disk’s corresponding rear LED and the front LED will be solid red.
During RAID Synchronization
  • Front LED – solid red
  • Rear LEDs – The LED corresponding to the original disk will be blinking blue and the one being synchronized is blinking red
  • Once both disks are synchronized, their corresponding rear LED and the front LED will be solid blue.
Apr 06, 2010 | LaCie 2 TB 2big Triple Interface External...
Drum light keeps blinking on. Drum has been replaced
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until all the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. close the front cover
Mar 31, 2010 | Brother HL-2040 Laser Printer
How do i remove the outer bezel on a compaq presario cq61? i need to replace the screen. compaq presario cq61-110sa
1. Take the side door off as usual.
2. Locate the drive door lock inside the chassis.
3. Rotate the lock to the down position to unlock the upper front panel door.
4. Press the indentation located on the lower front panel to open the lower door.
5. Grasp under the bottom of the upper front panel door, lift up, and gently remove from the hooks. (Tip: The upper front panel door has finger holes.)
6. Remove any of the bay components by pressing both sides of the drive rails. There are no screws.
hope this helps...........
Mar 14, 2010 | Compaq Presario Notebook
Bottom door hinge replacement easiest way?
Hinge, Door Removal and Installation
  1. NOTE: A second person is required if the Flexi-Work Table 156-00070 is not available.
    Support the front door (20124) using Rotunda Flexi-Work Table 156-00070 or equivalent.
  1. Mark the location of the front door upper hinge (22800) and front door lower hinge on the front door and body.
  1. Remove the front door hinge-to-body retaining bolts.
  1. Remove the front door hinge-to-door retaining bolts and remove the front door upper hinge and front door lower hinge.
  1. To install, position the front door upper hinge and front door lower hinge to the front door and body. Install the retaining bolts. Tighten to 25-35 Nm (18-26 lb-ft).
  1. Adjust the front door and front door upper hinge and front door lower hinge as outlined, and remove the support.
Jul 01, 2009 | 1995 Ford Thunderbird
HLN5065W
there are 3 leds on the front that blink the error code. which leds blink gives you the error. if its just the standby/temp red led blinking, it has overheated for some reason. there are a couple other fans you could clean but check your ventilation. many people put too close to the wall or close it up in a cabinet. it needs atleast 4" from the wall and someway to vent out hot air and get cool air in. a different model had the temp sensor cause this issue, it is the silver thing right atop the lamp. you will have to pull the whole back panel possibly, there are two wires that hook to it and two screws holding it to the engine (lamp housing). if you get lamp and temp leds blinking, reseat the lamp door. timer and temp leds is a fan error, all 3 leds is a lamp error (lamp, ballast, colorwheel, dmd)
Dec 05, 2008 | Samsung HLN5065W 50" Rear Projection...
HP 301566-001 Storageworks Ultrium (301566001) LTO 1 Tape Drive Logo
341 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
