Question about HP PSC 1610 All-In-One InkJet Printer
Ink cartridge Got black ink cartridge in backwards. How to get it out?
  • 55 Answers
I would turn on the printer, raise the cover to get the catridge swing to the middle, then take off the power cord to have the catridge stay accessible. Gently push from the sides or bottom and slide it on the right track. when you're done, close the hood and re-connect the power.
Posted on Oct 23, 2007
SOURCE:
How do i get the ink cartridges in as canon pixma mg2200 to come out have followed instructions but they won't come out
The color cartridge (241) needs to be on the left and Black (240) right as it sounds as though they are in the wrong way as you are having trouble removing them either that or you put them in backwards put in label up with the number on the label facing U
Aug 08, 2014 | Canon PIXMA Office Equipment & Supplies
Please describe your what size ink cartridge do i need for pixma mp160 printer problem:
The following cartridges are compatible with Canon MP160:
Canon PG 40 Black Ink Cartridge Black Ink Cartridge
Canon PG 50 High Capacity Black Ink Cartridge
Black FINE Cartridge, High Capacity
Canon CL 41 Tri Color Ink Cartridge
1 Cartridge of Cyan, Magenta, and Yellow
Canon CL 51 High Capacity Color Ink Cartridge
Color FINE Cartridge, High Capacity
Nov 23, 2010 | Office Equipment & Supplies
Ink cartridge put in backwards
try to clean the cart once again.. or else try out with another set of cart as well
Oct 21, 2009 | HP DeskJet 5740 InkJet Photo Printer
Ink cartridge installed backwards
use a non magnetized screwdriver and take the top cover off then unscrew the screws holding the guide bar in and gently pull the ink cartrige out you may reuse the cartrige but not recommended.
May 26, 2009 | Lexmark X2600 InkJet Printer
Epson stylus color 850 black working poorly
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 22, 2009 | Office Equipment & Supplies
Replaced ink cartridge printer continues to say no cartridge
you need to follow the whole procedure on your to ensure proper installation as soon as you install the new one, follow the instruction on the screen to calibrate your new ink
Nov 08, 2008 | Brother MFC-440CN InkJet Printer
Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
924 says that black ink cartridge not installed
Hmmm....that sounds to be an issue with the ink cartridges...
You might be using ink cartridges purchased other than Dell or Staples...since these are the two who sell Dell Ink.
If thats not true, then take out both the cartridges in the printer.
Lets isolate the issue
1. Try only Black cartridge on Color slot(right). If you get Install both ink cartridges error, then its an issue with the Black ink cartridges and if you get message that install Black ink cartridge then its an issue with the prrinter.
2. Now install only color cartridge on Black cartridges slot(left), If you get color cartridge missing then its an issue with the Black cartridges which you are using and if you get install both ink cartridges then its an issue with the black slot on printer.
3. If issue found to be with Black ink cartridge then wipe the Nozzles(bottom) of the ink cartridge with lint free cotton cloth from back to front 5-6 times.
4. Also try replacing the ink cartridges purchased only from Dell or from Staples. Purchased from somewhere else or refilled might not work.
5. If issue found to be with printer, then i would suggest you to purchase new printer then.
Hope this fix the issue
Aug 14, 2008 | Dell 924 All-in-One InkJet Printer
Ink cartridge
calm down,call your computer repairs technician. eyo7 eyoifiok2005@yahoo.com
Apr 02, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
54 people viewed this question
Clive
Clive
Thomas F. Schneider
