My Kenmore 54351 dehumidifier (35 pint) runs for a bit, then stops. I see this problem appears to be common, according to the posts here. I have cleaned the filter (didn't know it had one) and it ran a bit and then stopped again.
Is there anything else I can try? This worked beautifully up until this spring.
i purchased a used kenmore dehumidifier 54351... it turns on when plugged in but then turns off...
(More)
i purchased a used kenmore dehumidifier 54351... it turns on when plugged in but then turns off after a minute or so.. the humidity in the room is between 70 and 80% I would think it should do something... I have played with the dial and nothing changes... the unit seems clean and not well used.. any recomendations on my first step? the switch that detects the drawer is fine... haven't gone any further. is it worth trying to fix?
My 54351 dehumidifier only collects about 1/2 cup of water in a 10 hour period, but after I turn it...
(More)
My 54351 dehumidifier only collects about 1/2 cup of water in a 10 hour period, but after I turn it off for several hours, I later find over a quart of water in the collection bin. The unit is only 6 months old. Should I take it back to Sears?
My kenmore dehumifier model 580 (35 pint) cycles on and off and will not stay on for an extended...
(More)
My kenmore dehumifier model 580 (35 pint) cycles on and off and will not stay on for an extended period.
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running....
(More)
Dehumidifier fan runs lights turn on but only get about a cup of water after all day running. Kenmore model 580.54351 35 pint Basement is wet and not sure if this model is for basement temps but it works the same in warmer temps.
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change...
(More)
Mine has stopped running because it has reset itself to 01% from 50%. But you can't manually change the %. It just beeps. the bucket full light flashes even though the bucket is empty. I usually set it on 3 hrs on/off. Have tried powering on/off, etc. Coils not iced up.
