Question about Spidem Trevi Automatic Espresso Machine
Trevi Spidem Espresso Machine that leaks
It leaks all over the counter and sometimes sort of coffee grounds are mixed in. I have decalcified it several times and it still leaks. I wondered if I decalcified every other day for a time? Would that help? The coffee still tastes fine and it works, just leaks. It is an office espresso, about 3-4 yrs old and I do not think it has ever been decalcified before.
Thanks
    President:
  • 1,618 Answers
Remove the brew unit and look at the white valve behind it, below that valve there is a small chamber which is probably filled with coffee grounds and water, clean chamber and below chamber is a small discharge hole that leads into the draintray, make sure it is clear.
Posted on Jun 03, 2009
Can I use coffee cleaning tablets with a Spidem trevi digital plus
I would not use this product unless you exactly know what it is, and if it's appropriate for your coffee machine. Instead get some Saeco decalcifier powder DEZCAL that you add to your water and follow your machine instruction on how to decalcify.
Nov 24, 2012 | Saeco Spidem Trevi Digital Plus Fully...
I rinsed coffe maker with decalcify powder, then rinsed coffee make many time with clear, fresh water but the coffee maker still reads, Decalcify/Ready For Use. Although I can make a cup of coffee, the...
Hi
I am assuming that you have a digital machine. If so, you have to go into the menu and go to "Reset Descale", push the enter button and choose "Yes" and push the button again. Then you can exit the menu and it should be gone.
Feb 03, 2011 | Spidem Trevi Automatic Espresso Machine
My spidem trevi automatica is leaking water (with some grounds) from the bottom. Last repair bill, 10 months ago for the same thing, was $235 + shipping. Is this a common problem?
Hi
Grounds and water under the machine or drip tray indicate that the drain behind the brew unit is plugged.
Remove the brew unit. You will see the injector in the back of the machine. Below the injector is a pocket that the excess pressure is relieved into when the machine is done making a coffee. This pocket will plug up with ground and oils. The drain is just above the center of the drip tray. Insert something into the drain and see if you can unplug it. Once it has drained run some hot soapy water through the pocket.
Jan 22, 2011 | Spidem Trevi Automatic Espresso Machine
Decalcify has appeared on the screen
its bunged up with lime scale then,,,,,get some kettel cleaner mix it up in warm water in a jug,,,poor it in the water holder and let it run through ,,,catching it in the jug to return it to the water holder again,,do this a good fuw times till it runs freely,,then flush it out realy well with plenty of clean water before you drink from it
Jul 01, 2010 | Spidem Trevi Digital Coffee Maker,...
The decalcification light stays on constantly.
I had the same problem with Spidem My Coffee with no instructions how to turn the light off. used the Saeco instruction and solved.
simply press the steam button for 6 seconds and the light will turn off
Jan 03, 2010 | Spidem Trevi Anthracite Espresso Machine
Spidem Trevi Water Problem/ my machine is leaking water and sort of coffee grounds. I have decalcified it several times, but it continues to leak. It is an office machine is 3 years old and I don no
Easiest way is to open the machine and find the blockage then clear it out and then get on a regular descale cycle. Check the brew unit also to make sure that it is not blocked. You model only has one boiler so if you're getting hot water from the steam wand it is possible that the problem is in the brew unit.
Jun 02, 2009 | Spidem Trevi Automatic Espresso Machine
Water leak
Good chance its leaking from the boiler if has been descaled or used for a period of time.
Just had the same problem with mine.
Jan 25, 2009 | Spidem Trevi Digital Coffee Maker,...
I think it´s your boiler that is leaking, if you don´t decalcify the machine regulary this will happen.
Apr 10, 2008 | Spidem Trevi Automatic Espresso Machine
Spidem Trevi Automatic Espresso Machine Logo
535 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
graybeard32301
ray gallant
nikolay nikolov
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
