Question about Toshiba 36A40 36" TV
Sound not good
The sound on my control is a maximum but on the tv is not good.
  • 105 Answers
Try to replace the speaker first otherwise the sound ic give the problem
Posted on Jun 07, 2009
Replace tv video card
FOLLOW this steps and fix it. God bless you
Perform some basic troubleshooting steps that apply to all TVs. These include checking the "Mute" button to see if it has been pressed, examining the L/R balance to ensure sound is coming from both speakers and checking the cable connections to auxiliary components such as the stereo system (which controls external speakers).
    • 2
Double-check the audio output jacks if you are using an S-video connection (a single round perforated jack) or component video connection (a trio of green, blue and red jacks). Those jacks only run the video signal to the RCA TV. In order to get an audio signal, you'll need to connect red and white RCA cables to their respective jacks on the TV.
    3 Check the back of the TV for a switch labeled "Int/Ext." It controls the sound input on some RCA TVs. If you don't have any separate speakers, the switch should be set to "Int."
      • 4
    Activate the sound set-up feature by pushing the "Menu" button and scrolling to the sound bar. (This option can usually be found only on RCA flat-screen and projection screen TVs.) The sound bar allows you to set the sound from mono to stereo, activate the surround sound features, adjust the sound for headphone use, set volume levels and activate preset sound levels for movies, sports, concerts, video games and other specific sorts of programming. If any of these settings don't match the configuration of your home theater system, it may cause problems with the sound. If you're confused about the options, select any settings that read "Normal" or "Automatic." That should set the RCA TV to factory standard audio settings.
      • 5
    Press the "Menu" button and scroll to the "Set-Up" option, then go to "Preferences." You'll see a bar on the menu marked "Maximum Volume." You can use that to limit how loud the TV can get, which can cause problems if you don't know it's been set. Move the arrow on the bar to reset the maximum volume, then hold down the "OK" button on the remote to hear what that volume sounds like. You can then listen to the TV as normal.
    Jul 20, 2013 | Sylvania Televison & Video
    Sound goes to maximum by itself
    Check your remote just to make sure you don't have a stuck button. Check the buttons on the TV as well. If they look ok, then you most likely have a bad Keyboard on the TV
    Apr 10, 2012 | Hisense TL2620 26 in. LCD Television
    My t.v. cannot regulate the sound. all the buttons on the right side of the set do not work at all, but my cable control can only adjust sound but the sound, at its maximum, is barely audible. HELP ME!!
    Try with your remote control. If the TV control buttons not
    pushed for a long time the switches develop this problem.
    Try operating the buttons. Some times it may function.
    Sep 04, 2010 | Televison & Video
    Sound turns up all the way
    Check the volume up button on the TV or on the remote control is not stuck in & jammed. This will cause the sound to go fully to maximum by itself.
    Sep 25, 2009 | RCA F36650 36" TV
    PHILIPS TV SOUND PROBLEM
    My phillips tv model # 55pl9773/17 sound is too low when im watching regular tv, but when i switch from tv to av1 or av2 (watching a dvd movie or playing video games) the sound is normal. How do i get my cable TV to sound the same?
    Sep 28, 2008 | Televison & Video
    Lost all sound
    I had the same problem. Do you have a cable box for digital TV? do you have a remote from the cable company? that is programmed to control the TV? get the cable company to unlock the sound control from it (a 3 number code) put your sound up to maximum if you can if you hear faint sound repeat above you should be able to hear the tv then then go to the sound settings and adjust as needed get the cable company to check the box in cas it has been zapped by lighting good luck
    Aug 26, 2007 | Protron PLTV-32 Television
    Protron PLTV-3750
    I had the same problem. Do you have a cable box for digital TV? do you have a remote from the cable company? that is programmed to control the TV? get the cable company to unlock the sound control from it (a 3 number code) put your sound up to maximum if you can if you hear faint sound repeat above you should be able to hear the tv then then go to the sound settings and adjust as needed get the cable company to check the box in case it has been zapped by lightning good luck PS let me know if you want to junk it/sell it? they are excellent TVs
    No sound on protron tv 1 yr old. can you help
    take it to a repairman problem in the audio circuit or IF circuit.good luck.
    Apr 07, 2007 | Protron PLTV-32 Television
    Toshiba 36A40 36" TV Logo
    76 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
