Question about Canon CLC 1140 Copier
E020-0181 We're getting this error on our copier ALL THE TIME. It tells us to turn it on and off, we do, but same error. Any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
I don't know about the color copiers but here is a list of error codes, and their likely problems.
Looks like you will have to ge t a tech to fix it.
http://www.visualhawk.vcc.ro/canon_error_codes_en.html
Posted on Oct 25, 2007
ERROR CODE sc865-01, TRIED CALLING TECH SUPPORT BUT HOLD TIME WAS FOREVER & CLOSEST TECH IS 4HRS AWAY WE HAVE ONLY ONE MULTIPURPOST SO WE ARE COMPLETLELY DOWN
Your message is not clear because you have not told us what type of machine you are having problems with.
As far as I can tell it is a Ricoh copier. First of all I would suggest turning off the machine, leaving it for 5 minutes and then restarting it. Sometimes it is just a sensor which is throwing a fit! Next I would check the toner level and the waste toner bottle. Finally check that the paper pathways are clear.
These are just commonsense suggestions and I apologise if you have already tried these.
Further research on the internet shows that it may be a hard drive error, if you can locate the hard drive -with the power off - check all the connections. If you still have no luck then you may need to format the drives
http://www.copytechnet.com/forums/ricoh-savin-gestetner/12877-ricoh-aficio-mp-c4500-error.html
Hope this helps
Feb 28, 2011 | Office Equipment & Supplies
I have a acer aspire 8930g but wont boot up right it get stuck and it say "A disk error occurred" press Ctrl+Alt+Del to reset this is the first time this happen
If this happens each time you try to boot, the message is telling you that you have a hard drive problem.
First--is it still under warranty? If so, contact Acer or the place where you bought it.
Next--if it is not under warranty, I would suggest booting from a Windows CD/DVD and choosing the repair option--you will need to scan the hard drive for errors. If you get an error when you attempt this, you're going to have to replace the hard drive.
Dec 31, 2009 | Office Equipment & Supplies
Canon Imagerunner 2200 with error code e000000-0000
Try to enter service mode, and from function clear the error.
Switch off and on. If the problem persists you have a problem with your fixing unit...
Sep 02, 2009 | Canon imageRUNNER C3220 Color Copier
Disply in "call for service" please suggest a solution
Hello sir; You have to find out what is the error code, to read error code just press 8 and clear/stop key at same time, except fuser error all others can be reset by turning the power off and on.
Aug 28, 2009 | Toshiba e-Studio 205 Copier
Error code: E000732-0001
Reader / scanner assy communication error, check all leads and switch back on.
Feb 04, 2009 | Canon ImageRunner 3320N Copier
Canon IR3170CI got a error E0014-002
k these are notorius for having bad upper rollers if they sit for a long time if you turn the green knob on the fuser and feel hesitation or its hard to move then easy.. or if it sounds like a washing machine at warm up you need a new fuser even if youswapped it the one you put in if not new may be bad
Dec 10, 2008 | Canon imageRUNNER 400S Copier
Error code E000003-0001
Unfortunately you need a tech, unless you are a handyman.
there is a problem with the fuser,
either the thermistor ( heat regulator)
the thermofuse ( fuse)
or the heat lamp has gone bad
Sep 08, 2008 | Canon imageRUNNER C3220 Color Copier
Cannon image runner c6800 error code E000001-0003
Its a fuser error and it has to be reset in service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
if the problem comes back there is a problem with the fuser but in my experiance resetting has worked 99% of the time
Mar 05, 2008 | Canon imageRUNNER C6800 Copier
5020i error code E000001-0000
turn on the copier and quickly press * (with the little head around it) then 2 and 8 at the same time, then the * again... this should put you in service mode. now press copier >funtcion>clear>err>ok. now turn the copier off and back on, If the code comes back call your service local service tech.
Jan 08, 2008 | Canon imageRUNNER 5020 Copier
Canon CLC 1140 Copier Logo
453 people viewed this question
old marine
old marine
