Question about HP OfficeJet 6110 All-In-One InkJet Printer
Can't find how I initiate a scan on my HP 6110 all-in-one
I have bought a new PC running Vista and I have successfully load the HP 6110 driver and I can print documents. Unfortunately I can't seem to scan documents. There is one icon or method I can find to scan a document. On my old XP machine I was able to locate an icon for scanning. Can you help?
    Scholar:
  • 84 Answers
I suppose there was a problem in your driver installation. For most USB devices, it is recommended that the drivers be copied/installed on the pc prior to attaching it via the cable. So, if you attached the printer to the pc before copying its driver to the hard disk, you are likely not to have the right result ok. Put back the driver cd/dvd into the drive tray and uninstall. Restart your pc and then follow the step above. Good luck
Posted on Jun 02, 2009
In Windows Vista there is no the shortcut you mention above. Just use Windows Fax And Scan program and make your scans through is.
Link: http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&lang=en&product=79477
Posted on Jul 25, 2009
Does anyone know if Windows 7 fixes the problem that Vista users have with HP Officejet 6110 scan function? ie: not respondind to buttons on 6110 when trying to scan.
yes it will fix the issue :
Need to download the driver for Windows 7 from the hp's website.
Click on the below given link it will help you download the software :
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=79477&lc=en&cc=us&dlc=en&lang=en&cc=us
Select your OS;
Select the Full feature Driver;
Click on Download ;
Save to your desktop;
and then run the software;
Then while installation select the "Recommended" option and install it;
Try to scan from "HP Solution Center".. "home"
Also try to print
Also try to scan from the scan button on the printer
This should resolve your Issue
Oct 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Problems with HP deskjet f380. Will not print... scans and copies
the system for vista and xp is near to similar. so just click the following links 1 by 1 and go through the instructions as you r missing any minor step to be followed in loading your printer How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
Installing a printer on a Windows 95/98 network
INSTALL THE PRINTER on a PC
ENABLE PRINTER SHARING
MARK the NEW PRINTER as a "Sharable" Printer
INSTALL THE PRINTER ON THE OTHER PCs
Troubleshooting Windows 95/98 networking problems
http://www.mcgill.ca/ncs/products/soho/networking/printer/
How to install a printer driver locally for a remote printer in Windows XP/ Windows 2000-
http://support.microsoft.com/kb/282842
Jan 06, 2009 | HP DeskJet F380 All-In-One Printer
HELP VISTA DONT LET ME ADD THIS PRINTER
HP doesn't have a new driver, however, they say Vista will recognize it and they provide workarounds for you to print and scan.
Here is the support page for your 6110:
6110 Vista Setup
You will need to uninstall any software you have already loaded and delete your printer from the Printers and Faxes section of Control Panel before following the procedure.
Nov 07, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 1355 printer & Vista
HI,,,
just try to reinstall the software and driver...
Oct 27, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet J5750 can't scan,fax from PC and no HP devices detected error
This issue is common with every HP scanning software used with Windows OS which have a firewall running.
If you would try the following:
- check the task bar if HP digital imaging monitor is up and running
- if not, go to C:\program files\hp\digital imaging\bin and double click the file HPQTRA08.EXE
- now the monitor should run
- if not, pls reinstall the software (*)
- if yes, pls try to open HP solution center
- if solution center starts, pls try to scan or to fax
- if successful, no other steps are required
- if faxing is not successful, check in the printer folder, if you find a HP <device name> series fax entry
- if you cannot find it, unplug the printer and delete the entries in both the printer folder and scanner folder
- also run the software CD and start the uninstall_l1.bat and uninstall_l2.bat in the util\CCC on the CD (if 64 bit OS, the run the 64 bit versions)
- restart the PC with the loaded CD
- replug the printer and let it be reinstalled
(*) For a clean reinstall it is recommended to contact HP support. They know the best way to leave a clean system on the PC.
Hope it helps.
Henning
Oct 20, 2008 | Office Equipment & Supplies
Hp officejet 6110
Assuming that your OS is Vista, here are the steps that may help you resolve your issue.
Oct 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 1210 all-in-one Director does not work with VISTA
I've been fighting the same. Did some hunting on the HP and MS web sites. Found a "work around". Not what I wanted but at least I can scan. I think HP Director is gone for Vista users. :(
Scanning with Windows Photo Gallery
1. Click the Start ( ) icon.
2. Click All Programs .
3. Click Windows Photo Gallery .
4. Click File and then click Import From Scanner or Camera .
5. Click Import .
6. Click Scan .
Jan 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
Scanner will not function
See this info re vista driver, not needed for 6110xi and advance features no longer available.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00808543&lc=en&cc=us&dlc=en&product=79477
and also note on same page...
"You might find that some of the advanced features are no longer available when using this basic driver. You can upgrade to an HP product that is fully compatible with Windows Vista if the advanced features are necessary"
and also note Scanning with Windows Fax and Scanning
NOTE: This feature works only with Windows Vista Ultimate, Windows Vista Business, and Windows Vista Enterprise
Your disks I don't think will help, looks like it is case of Not fully vista compatable, there are also issues relating to your old HP Director software ie...
"In October 2006, Microsoft released Internet Explorer 7. The HP Director software that shipped with some HP products introduced between 2002 and 2004 may not be compatible with Internet Explorer 7. The HP Solution Center software, which replaced HP Director software, does not exhibit this issue with Internet Explorer 7."
link to above
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00802504&lc=en&cc=us&dlc=en&product=79480&lang=en
Nov 13, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
300 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
