When i set up the buttonhole att. the needle goes up and down sewing stiches on top fo each other but the fabric does not move and makes it difficult to remove the fabric
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
SOURCE: my sewing machine will not sew it only makes holes
Assure the needle is threaded correctly.
Either its not properly threaded when you start to sew
OR the bobbin isn't correctly installed causing it not to catch the thread when sewing.
OR (possibly just with old machines) the tensioning needs to be adjusted.
It is difficult to say without seeing.
Hope this helps at least some. Good Luck!
SOURCE: the thread isnt moving with the sewing machine
is it possible that you didn't get the needle inserted all the way into
the needle holder?
is it possible that the needle is not turned the right way in the
needle holder?
SOURCE: i have a white sewing machine, model 955. the
I suspect you have a minute piece of thread stuck in the raceway
Testimonial: "I've taken it apart and can't find any thread anywhere. Where is the raceway at?"
