Question about Sony VAIO FX120 Notebook
Won't boot. blue screen.continues same cycle
I installed windows xp, worked fine 1st day, second day won't boot. tried safe mode and last good config..still go through same process..won't read cd to reinstall windows xp either
  • beegoodwine Jun 02, 2009
    under my advance options i have: primary ide adapter = 10056mb; secondary ide apapter = cdrom; legacy floppy = enable; serial port; parallel port; ps/2 mouse; plug/play os; logo motion....don't see anything about SATA
  • fougzki May 11, 2010
    Did you try REPAIR option, on software side, getting software corruption to be patch by a new copy?
    You gonna need your installer OS cd. Then wait for the option Repair.
    Your problem could be driver problem commonly on video.
  • 479 Answers
please go in bios and there under adavanced u will find SATA options and pleas set those on either IDE or compatibility mode then it will work.
Posted on Jun 02, 2009
  • Gyanendra Kumar Jun 02, 2009
    please tell what are the tabs(options coming in bios)
Compaq nx6120,screen went blue with instructions which it prevent windows from logging on
Trying booting into "Last Known Good Configuration" or safe mode by pressing F8 as soon as your system boots. If you can get into safe mode without the blue screen, your can perform a system restore to the date before the problem occurred.
How to restore Windows XP to previous state description of the Safe Mode Boot options in Windows XP
Jan 07, 2014 | Computers & Internet
I want to remove win7 from my compaq cq57 laptop (intel core) and replace it with xp pro
In your case try the RAM part 1st.
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode).
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 01, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Windows wont boot up when I turn on my Toshiba
You need an antivirus program to be installed after installing your operating system. Do it in safe mode. If problem persists let me know.
Jul 10, 2009 | UltraLast FOR TOSHIBA SATELLITE A50/55...
Dell latitude d600 screen goes black during boot
ok after you have booted in safe mode do a restore to a date just before the last day it worked properly and try that restore is found here
start/programs/accessories/system tools/system restore
hope this helps
Mar 15, 2009 | Dell Latitude D600 Notebook
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
Can not boot
what's the 1st thing you see when you try booting? it should be black with white words detailing your boot cycle. if youre not seeing this, its hardware.
hopefully your blue screen comes later, which means it's more likely software as windows is trying to load. I assume this is what it is since you see an avast error.
i think F8 is safe mode-- are you sure you're pressing F8 every second or two as it boots to get into safe mode?
what did you do right before this started happening to you?
Jan 31, 2009 | Acer Aspire One PC Notebook
HP a1620n- Will not startup properly
try starting in safe mode then when it windows starts/full loads shutdown the computer. Then restart the computer-it should start normally.
Dec 01, 2008 | Computers & Internet
Help
Blue screens causes your system not to boot properly. It could be a corrupted video driver, system registry or could be a problem with a hardware component of' your system. Windows update causes also blue screens and incompatible application installed in the system as well.
You may try to boot your computer to following option.
Last known good configuration
Safe mode with networking.
1. Restart the system. At the moment you are turning on your system. After pressing the power button.. Keep on tapping F8 key (on/off) until you have the message "Advanced boot option"
2. Select the 1st option: Last known good configuration.. Press Enter until you have your login screen. If it doesn't work you may try the second option which is the "safe mode with networking".
If the two option won't work, you may need to try repairing the operating system or reinstall windows.
Keep me posted.
Thanks.
Oct 16, 2008 | Computers & Internet
XP Reboots by itself on arrival of login screen
have you tried safe mode? if safe mode is still a failure, you have no choice but to reformat 1 of those drives an do a clean installation of windows xp
Mar 17, 2008 | Computers & Internet
Sony VAIO FX120 Notebook Logo
93 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
