Question about Spidem Trevi Automatic Espresso Machine
Spidem Trevi Water Problem/ my machine is leaking water and sort of coffee grounds. I have decalcified it several times, but it continues to leak. It is an office machine is 3 years old and I don no
My trevi machine is now leaking water and is not drawing water through the coffee. My assumption is that it's pipes or hosing is plugged, but I may be mistaken. What do I need to do to clean it? I have decalcified it several times and it seems worse. I don't think it was ever decalcified in the past, it is an office machine. Should I do it every other day or something until it stops?
    President:
  • 1,618 Answers
Easiest way is to open the machine and find the blockage then clear it out and then get on a regular descale cycle. Check the brew unit also to make sure that it is not blocked. You model only has one boiler so if you're getting hot water from the steam wand it is possible that the problem is in the brew unit.
Posted on Jun 03, 2009
2 Suggested Answers
mirran
  • 515 Answers
SOURCE: Spidem Trevi Water Problem
I think it´s your boiler that is leaking, if you don´t decalcify the machine regulary this will happen.
Posted on Jul 11, 2008
Can I use coffee cleaning tablets with a Spidem trevi digital plus
I would not use this product unless you exactly know what it is, and if it's appropriate for your coffee machine. Instead get some Saeco decalcifier powder DEZCAL that you add to your water and follow your machine instruction on how to decalcify.
Nov 24, 2012 | Saeco Spidem Trevi Digital Plus Fully...
My spidem trevi automatica is leaking water (with some grounds) from the bottom. Last repair bill, 10 months ago for the same thing, was $235 + shipping. Is this a common problem?
Hi
Grounds and water under the machine or drip tray indicate that the drain behind the brew unit is plugged.
Remove the brew unit. You will see the injector in the back of the machine. Below the injector is a pocket that the excess pressure is relieved into when the machine is done making a coffee. This pocket will plug up with ground and oils. The drain is just above the center of the drip tray. Insert something into the drain and see if you can unplug it. Once it has drained run some hot soapy water through the pocket.
Jan 22, 2011 | Spidem Trevi Automatic Espresso Machine
No water for brew
Remove the brew group and clean the shower screen at the top. This might be blocked.
Jul 13, 2009 | Spidem Trevi Anthracite Espresso Machine
Trevi Spidem Espresso Machine that leaks
remove the brew unit and look at the white valve behind it, below that valve there is a small chamber which is probably filled with coffee grounds and water, clean chamber and below chamber is a small discharge hole that leads into the draintray, make sure it is clear.
Jun 02, 2009 | Spidem Trevi Automatic Espresso Machine
Saeco Trevi leaks from "inside"
What can have happened is that through an overflow of used coffee the hole in the back is stuffed with the ground used coffee. The way to solve this is getting out the brewing group and rinse the hole with water after removing the cloggin coffee residu. You can find this hole just beneath the outgoing axle.
Mar 05, 2009 | Saeco Vienna De Luxe Espresso Machine
Spidem trevi digital plus coffee machine not working as it should
it sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
Jan 27, 2009 | Spidem Trevi Digital Coffee Maker,...
Water leak
Good chance its leaking from the boiler if has been descaled or used for a period of time.
Just had the same problem with mine.
Jan 25, 2009 | Spidem Trevi Digital Coffee Maker,...
Apr 10, 2008 | Spidem Trevi Automatic Espresso Machine
Water leaking from bottom. what's up?
the best thing to do open the machine cover go easy when the cover is off visual look you probably got a disconnect pipe if not activate the machine be carefull you got live power in there try to make a coffee you a clear pipe black hose connect to it probably dry rubber hose if its that put everything back and clean the machine with a decalcifier block pipe with calcium buil up pressure inside if you have a dry hose its gonna pop off dont forget to rinse the machine very good after that stuff is very corosif if it help you dont forget to rate this cheers
Jan 16, 2008 | Starbucks Saeco Italia Digital Barista...
Spidem Trevi Automatic Espresso Machine Logo
458 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
graybeard32301
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
