Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Drip pan runs over even with water supply off
    Habit-Forming:
  • 62 Answers
The fan under the cabinet is not work of it is full of dust
Posted on Jun 02, 2009
Water leaking under fridge
a contant runing of water is most likely a leak in the ice maker supply hose , an intermitant drip of water is a drip pan thats full in bottom of fridge (closest to floor ) this water comes from the auto defrost cycle most times this water evaporates away , but as fridge gets older it makes more frost that needs melted hence more water ,sometimes it over comes the pan and runs to floor , a good flashlight and getting down to look underneath usually tells you source of leak
Feb 20, 2015 | Refrigerators
Our new Santa-Fe Classic dehumidifier is leaking water from the bottom of the unit. It's also sending a small amount of water correctly through the tube for dispersal. We've only had it for two...
The classic model drains thru the clear hose using gravity. The drip pan in that unit is about 1/2 way up in the cabinet. Make sure the drain hose exits the unit and runs flat or downhill. If the drain hose is coiled vertically or run up hill causing water to trap within the hose it can cause water to back up in the dehumidifier drip pan and overflow causing your problem. If your drain is higher than the base of the dehumidifier, you can raise the dehumidifier or you can purchase a condensate pump kit that will allow the drain water to be pumped up to 15 feet above the dehumidifier.
The drain hose may have become disconnected from the drip pan as well. To check, turn off the humidistat to stop the dehumidifier from running. Next disconnect the cord from the power supply. Remove the six screws holding the cabinet side (with the label) from the cabinet and remove the cabinet side. The drain hose connects to a nipple on the bottom of the drip pan.
Contact Therma-Stor service for further inquiries at 1-800-533-7533 - they are located in the USA and are very helpful.
Sep 07, 2011 | Therma-Stor Santa Fe Dehumidifier
Water leaking out of hose on a fujitysu split system ast24rga
Normally, an Air Conditioner removes water from the air and that water condenses on the coils of the inside section that does the cooling. The water condenses on the cooling coils just like moisture condenses on the outside of a glass of ice water.
This excess water drains out of the cooling section through a "drip tube" and is supposed to drain outside of the house, or a drainage system. Your "drip tube" has either not been installed (if it is a brand new installation), has separated and water is now dripping into the house instead of outside of it. Or it is clogged. This happens when algae builds up inside the "drip pan". If that is the case, you can purchase "algaecide" tablets which kill the algae that is clogging the drip pan and preventing water from draining out through the drip tube. These tablets can be found in many hardware stores, refrigeration supply companies, or even Walmart. You can put a tablet inside the pan. (You will have to remove the cover of the unit). You can often use a little bit of Bleach and that will act as an algaecide. Hope this helps,
Best, Mark
Dec 26, 2010 | Fujitsu Heating & Cooling
Hello, Can you please tell me what "waterproof system has activated" means. My dishwasher has alarmed to indicate the water supply needed to be turned off along with the message F70. The water has...
Hi Acfaries.When that happens you should find whats causing that.Please check this list if you can do it,if not please call your machine's service centre.I hope that helps.Thanks.
F70
Float switch fault
Cause:
Water in the drip pan. Changeover contact of overflow float switc
Remedy:
1. Remove the water from the drip pan (e.g., with an absorbent cloth).
Note:
Upon opening the appliance and removing all water, there should be no
smudges, smears or traces of deposits.(rust, calcium, detergent, or salt?).
2. Check all hoses, connections and threaded unions for leaks.
Note:
If the leak source has not yet been detected, check the following areas
in the toekick and the drip pan for wear and tear:
�� Connection between the circulation pump and the sump
�� Axial face seal of the circulation pump
�� Connection between the drain pump and the sump
�� Connection between the salt container and the water intake
�� Connection between the water intake and the cabinet side wall
�� Overflow (e.g., excess foam formation)
�� Water level between the overflows (�� seating of the lower door seal?)
�� Connection between the cabinet and the salt container
�� Non-return valve in the sump (�� water running back from the drain hose?
Aug 25, 2010 | Miele Dishwashers
Water in the drip pan- what is causing it?
I assume you are talking about the indoor unit. One function of the a/c system is to dehumidify the air. Condensation forms on the cooling coil and runs to the drip pan. There should be a drain line on the drip pan that drains the pan outside. These sometimes become clogged causing the water level in the pan to rise. Try some mild drain cleaner to open the line. Hope this helps. Let me know what you find.
May 21, 2010 | Carrier 38CKC036 Air Conditioner
Honeywell HE260 leaks somewhere
Neither, even if the solenoid or humidistat stick, it should always drain properly. Is the unit mounted on the cold air return duct or the supply plenum? If it's mounted on the supply plenum, the water panel might be getting blown forward and spilling the water. High efficient furnaces also can leak water on the floor if its drain is restricted. If hum. is mounted on return duct make sure drain is clear by blowing through it. On Honeywell hum's I've seen the rubber hose from the solenoid valve to the distributor tray leak too, check the rubber 1/4" hose.
Dec 28, 2009 | Honeywell HE260A1010 Whole House...
PUMP WILL NOT STOP WHEN YOU PUT POWER ON . PUMP STARTS AS SOON AS YOU PUT THE POWER ON TO PICK A WASH PROGRAM EVEN BEFORE THE DOOR HAS BEEN CLOSED.
I have seen this on my unit. There was water in the drip pan under the dishwasher. Water in the drip pan comes from a leak. In my case, the water valve was getting so old that it was letting too much water into the unit when it was trying to fill. This cause the filling station to over flow into the drip pan.
A quick fix - I removed the water from the drip pan under the unit and I was able to turn down on the supply valve in the basement to limit how much water could come in. This allowed the unit to run without overflowing. I will replace the water valve soon.
Other possibilities, the float device used to detect too much water in the drip pan or too much water in the unit is stuck in the too full position. Or the pump out pump is stuck and not moving water.
Dec 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
Water leaking from under refrigerator
Analyzing the likely source
Instructions
STEP 1: Move the refrigerator out from the wall and look for the location of the leak. STEP 2: Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem. STEP 3: Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker. STEP 4: Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking. Fixing a condensation problem
Instructions
STEP 1: Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely. STEP 2: Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly). STEP 3: If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls. Fixing a drip-pan problem
Instructions
STEP 1: Pull off the grill that runs along the bottom of your refrigerator. STEP 2: Locate the drip pan, using a flashlight if necessary. The pan should be sitting on top of a set of black condenser coils and directly below a drain tube that carries water from your freezer when it is in defrost mode. STEP 3: Place the drip pan in your sink and fill it with water to test for leaks. If it leaks, order a replacement from your appliance dealer. STEP 4: If the drip pan doesn't leak, clean it with warm, soapy water, then reinstall the pan and the refrigerator grill. Fixing a clogged defrost drain
Instructions
STEP 1: Locate the defrost drain. It should be a round hole or a channel running under the vegetable and fruit bins in the refrigerator or along the floor of the freezer compartment. STEP 2: Inspect the drain for clogs and remove any debris. If necessary, use a small screwdriver to break up debris that's trapped in the drain hole. STEP 3: Fill a meat baster with hot water and force it through the drain to make sure the clog is gone. If the drain is operating properly, the hot water will fill the drip pan. Fixing a leaky ice maker
Instructions
STEP 1: Pull the refrigerator away from the wall and locate the copper water-supply line. It runs from the house water line to the refrigerator water-supply valve. (To get to the supply valve, you may have to use a screwdriver or a nut driver and socket to remove your refrigerator's back access panel.) STEP 2: Inspect the copper supply line, the supply valve, and the plastic supply tube that runs from the other side of the supply valve to the back of the ice maker. STEP 3: If a connection is leaking, tighten it with an adjustable wrench. If either the copper supply line or the plastic supply tube is leaking, you need to replace it. STEP 4: Turn off the water supply. The valve may be under the kitchen sink or connected to a cold-water pipe in your basement. STEP 5: Remove the faulty line and take it to a hardware store to get an exact replacement. STEP 6: Install the new line, tighten the connections with the adjustable wrench and turn the water back on. Overall Things You'll Need
Meat Baster
Adjustable Pliers
Adjustable Wrench
Soap
Nut Driver And Socket
Replacement Parts
Flashlight
Screwdriver
Who Can Help
Find Prescreened Appliance - Repair or Service Contractors at ServiceMagic.com
Overall Tips & Warnings
To keep door gaskets clean and supple, wash them twice a year with warm, soapy water, then coat them with a light film of petroleum jelly.
Some refrigerators have an internal defrost drain that is meant to be serviced by a professional. If you can't find your drain, call a pro.
To prevent possible electrical shock, always unplug your refrigerator before working on it.
Put carpet scraps or another soft material under the front legs before pulling your refrigerator away from the wall. Otherwise, the legs could damage the flooring.
Aug 05, 2009 | GE Refrigerators
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
80 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
