Question about Canon imagePROGRAF iPF8000 Printer
IPF610 Canon "Print head needs cleaning"
Keep getting this warning.
Have ran "clean print head A"
Have ran "clean print head B"
I have ran both of these multiple times and gotten no where. At this point it gives this message prior to each page printing.
" ! Print head needs cleaning. Press online to clear error."
This will happen for every new sheet to be printed.
Plotter is only 1 year old and has nowhere near the expected amount of print hours for replacement.
This has happened to me on my IPF8000 twice in the middle of jobs. I have had to purchase 2 sets of printheads..each set has only printed 3400 square feet....
Posted on May 23, 2010
  • JOE Bobby Aug 18, 2011
    Be careful when doing the deep cleaning cycle. If it doesn't fix it the first time stop. It is dumping all the ink into the maintenance cartridge. Soon you will be out of ink ($450.00) and a maintenance cartridge ($70.00) plus the print head runs ($640.00). I tried cleaning the printhead by removing it and pushing alcohal through it with a syringe. It still didn't work. I tried cleaning the cartridge out, and it was pretty clean, but notice the chip, it won't take, you have to buy a new one.
There is no solution, same problem. I have the same printer and same after one year. the only solution is DON T BUY CANON
Posted on Jan 21, 2010
I've had the same problem, and finally after hours of frustration, got Canon to provide a new PrintHead at no charge
Posted on Dec 14, 2009
    New Friend:
Guys I replaced both printheads a few weeks ago and i tried to print yesterday and pink lines appeared in whole the printed area.Any idea what the problem could be.? thank you.
Posted on Oct 18, 2013
I have replaced the print heads, and instead of printing red, which I made, it is printing black
DEAR FRIENDS; PLS DO THIS FIRST STEP FIRST
How to print nozzle check pattern iPF6100/iPF610/iPF710/iPF8000S/iPF9000S/iPF800/iPF9100
  1. Load unused paper.
  2. Press the Menu button to display MAIN MENU .
  3. Press or to select Test Print , and then press the button.
  4. Press or to select Nozzle Check , and then press the button.
  5. Press or to select Yes , and then press the OK button.The printer goes online and prints a test pattern.
Second later print out result pls compare you result print with my attachment picture.
replaced-print-heads-instead-printing-5j51azquscxy1hu2enwrxd50-4-1.jpg let say if anything color no same like example red = black,yellow = yellow black , cyan = dark or magenta = green.
this means got dirty on site purge unit and printhead unit. you need to call canon technician done services for you because i can't teach you how to clean the purge unit and print head unit scared you will spoil this both unit.
Hope can help you ,TQVM..
Apr 13, 2016 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Cost of print head replacement: $600-$700 and not realistic choice. What large format printer is available that will not have a regular print head failure every two years from light useage ?
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 28, 2013 | Canon iPF610 InkJet Plotter Printer
Despite repeated cleaning I cannot get the printer to work properly. I suspect that it may require a new print-head, Any recommendations as to where I might get one?
Before you throw out your print-head, try this to clear it:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
If no luck, then look for a replacement on at a Canon authorized seller or Ebay, Amazon or Alibaba, although I warn you that the print-head might cost as much as a new printer.
Dec 12, 2010 | Canon PIXMA MP540 All-In-One InkJet...
Problem with Printhead
I have the same printer with the same exact problem. Even the same color being affected. Unfortunatly no solution. It sounds like we have to replace the very expensive printhead.
Jan 13, 2010 | Canon imagePROGRAF iPF610 - large-format -...
Change print head on canon ipf610
I have a iPF600 and need to reinstall printhead. How do you get the printhead to move to the middle so you can take it out?
Nov 04, 2009 | Canon imagePROGRAF iPF610 - large-format -...
Black wont print
I stumbled on an ebay seller who is selling cleaning solution for print heads. Canon print heads are removable without special tools.
I gave mine a clean with metho, as I figured that it could not get any worse and I got the gist that I was going to have to replace the printer anyway.
I cleaned it with metho (just the bottom of the print head) and ran the clean print head function twice from maintenance and it is not working perfectly.
I do recommending taking this advice with caution as I do not know if this process could cause further damage or not work.
Sep 27, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Changed the print head in my Canon MP760 but now printing is blurred and very faint
Try cleaning the felt pads where the print head would rest when not printing. They get full of ink and cause more printing problems. I use water to clean them.Don't loose them, they are needed to keep the print head from drying out.
May 31, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Canon MP730 not printing. Printhead cleaning doesn't help.
You may need new print heads. They are around $50. Or, you could do this: Take the print head out of the printer, and run warm water from the tap (not high pressure), over the ports for about 5 minutes. Ink will drop out of the jets. Dont touch the electrical contact end of this head. This may clean the head enough so it works again. If not you need a new print head.
Apr 25, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
Black ink cartridge
try clean the cartridge nozzles and printers ones aswell.
Jan 03, 2009 | Canon PIXMA iP3300 InkJet Photo Printer
Canon imagePROGRAF  iPF8000 Printer Logo
3,366 people viewed this question
old marine
old marine
