Wharfedale 3210hdaf pic appears briefly after start up. no osd audio ok
  • mp69 Jun 02, 2009
    the wharefdale 3210hdaf is only 18months old and has already had 1 new psu fitted to cure fuse failuer fault. the set powers on with perfect picture but only for 2- 3 seconds after which no picture no operating system display . audio ok
    when the psu was replaced it was upgraded from a vestel 17pw15-9 to a 17pw20-1
    i do not have workshop facilities ie scope / signal generator etc but as a retired maintenence electrician i'am not shy to try.
    suspect capacitor failure somewere but which board ?
  • 11,896 Answers
Do you have a mutli-meter? If so, I suggest checking the resistance of the ballast. also check each bulb sockets. If this model has a color wheel, make sure it is spinning. If you have access to a voltmeter check the power from the power supply connected to main board. It should be 13.5 volts
Let me know how this goes so I can further assist you.
Posted on Jun 02, 2009
    Brigadier General:
  • 3,917 Answers
Not sure how old is this TV. Many chronc problems can cause these symtons. No high voltage because of bad flyback, or HV spitter defec is the most likely, but there are chonic caps that fail in the power supply as well. Check for horizontal drive waveform. It sounds like could be missing. Also not to miss out the fact that The onscreen setup menus appear only on a TV that is connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings."
Thank You for contacting Fixya.
After my monitor is on for about 10-15 minutes the OSD box will appear and I can't do anything to get it off the screen. My cursor is behind the box.(which comes up automatically in the center of my...
If you want you can disable the program from starting with windows. Press "windows key" + R and then type "msconfig.exe". OK. Go to startup and just uncheck the name of the process that is running OSD and click OK.
Jul 23, 2011 | Computers & Internet
I can't get the OSD display to appear on my monitor.
it's in the manual footenotes. osd will not work with an hdmi connection to monitor. it will work with s-video or component. just switch input when osd is desired.
Jan 28, 2010 | Yamaha RX-V661 Receiver
Monitor problem
I don't see any OSD in the RX-V490 owner's manual. This unit only passes video through from a video source, like a VCR.
May 16, 2009 | Yamaha RX-V490 Receiver
I have got a problem with my 17 inch viewsonic monitor. as i open the monitor it shows osd locked. pls get me the solution.
Assuming this is a E70fB monitor
OSD Unlock : Press and hold the [1] and [▼] buttons again for 5 seconds. The message “OSD UNLOCK” will then display briefly, indicating that the OSD image settings are now unlocked.
Userguide available at http://www.viewsonic.com/assets/027/7929.pdf
Mar 02, 2009 | ViewSonic E70f 17" CRT Monitor
Problem with OSD Main Contorls unlocked/locked
Philips say "To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC."
Jan 29, 2009 | Philips 190B6CB/27 19" LCD
OSD Main Controls Locked
Hold the "OK" button for about 20 seconds
It will initialy come up with the message "OSD Locked" and then after the 20 seconds a ne message will appear "OSD Unlocked"
Dec 20, 2008 | Philips 150S4FB 15" LCD Monitor
Marantz sr-7200 no OSD
Press AMP then OK on your remote. If the menue does not appear press 9 on the remote. You must have your monitor connected through composit Monitor Out or S-VHS.
Also check your multiroom settings. Maybe your OSD signal is diverted through to other room. I do not have SR-7200 any more, unfortunately.
Jul 24, 2008 | Marantz SR-7200 Receiver
Wharfedale DVDRHD400
where can i get a remote for the wharfdale dvdr hd400
Jan 15, 2008 | Wharfedale DVD-M3 DVD Player
Arcam AVR 200 OSD
Hi
Think you might have to use composite video out for the OSD menu to appear. Think I heard somewhere S-Video out doesn't work for.
Haven't tried yet on my own, but I will in time :)
Cheers,
Simon
Jan 11, 2008 | Arcam AVR-200 Receiver
Wharfedale dvdrhd400 problems
Change the Scart setting (in the setup menu) from the default setting (RGB) to the other available setting (CVSC?).
I have a problem with my box restting the clock on a random basis, making it impossible to set a timer to record anything - let us know if you get the same problem via this site!
Jan 03, 2008 | Wharfedale DVD-M3 DVD Player
Televison & Video Logo
116 people viewed this question
Top Televison & Video Experts
Electro Med Services...
