Question about Symbol LS 4000 (LS4000-100000) Handheld
No PS/2 Ports on new PC only USB ports. Need to make work with USB connectivity.
The barcode scanner was connected via PS/2 Port from an American Microsystems box to the computer. The new computer does not have any PS/2 ports to plug the barcode scanner into it only has USB ports.
    Guru:
  • 597 Answers
I have a P/S 2 port to USB adapter that I got with a microsoft natural keyboard once. So I know they make them. Here are a few you can get.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=ps2+adapter
Posted on Jun 02, 2009
None of my USB ports on my p2210 monitor are working How do I fix. Thanks
be sure that you connect usb cable between pc usb port and monitor usb port and try its usb
good luck sir
Apr 01, 2011 | Dell P2210 Monitor
Tip
How to connect a barcode scanner to your computer
<p>If you run a business, you probably need a barcode scanner to help control the items in and out of your iTunes. It is also possible to bar code reader to a computer at home. These devices connect through a USB port like most other external hardware. <br /> <p><br /> <p>1. Connect the barcode scanner to your computer via the USB port. A window showing the computer has detected a new piece of hardware. <br /> <p><br /> <p>2. Insert the CD driver installation. Wait until the installation wizard. <br /> <p><br /> <p>3. Follow the instructions to complete the installation. Remove the driver CD and replace it with a software CD is provided. <br />
on Jun 26, 2011 | Computers & Internet
I have 4 usb ports, and would like to know which one is the 2.0 port
If all the ports come from the same board (motherboard or expansion board), all should be 1.1 or 2.0, if they come from different boards, you could have mixed USB 1.1 or 2.0 ports, one simple test that can be done by connecting a USB 2.0 memory to the ports you want to test, if you receive a warning about a high speed device (2.0) connected to a low speed port (1.1), you have a 1.1 USB port where you connected it, if such warning doesn't appear you have an USB 2.0 port there.
Mar 09, 2011 | Computers & Internet
Symbol barcode scanner LS4071 + base RL475
Hi, you will need the 25-17821-20 and STI80-0200R cables to connect to PS/2. You must have a PS/2 keyboard for this connection.
If you would prefer to connect to a USB port you should get the 25-17821-20 cable with the STI85-0200R.
The RL-475 was for the IBM, but it also supported Synapse which is the STI cable.
Nov 18, 2009 | Computers & Internet
PS 2 port problem
What is the model number of your motherboard? VIA does not make Processor's/CPU's.
VIA makes chipset's for motherboards.
In order to answer your question I'll need the manual for the motherboard. No manual listed here: http://www.via.com.tw/en/products/mainboards/others/p4xb_m.jsp
Here is a picture of the VIA P4XB-M motherboard. This model can not use DDR2 memory. (Only, 184pin PC2100 DDR266 DIMM)
Found here: http://www.upgradecomputermemory.com/ram.cfm//memory/V/VIA-Technologies/P4XB-M-Motherboard/256MB-VIA-Technologies-Desktop-184pin-PC2100-DDR266-DIMM.html
VIA P4XB-M
http://www.via.com.tw/download/mainboards/4/11/P4XB-M.pdf
99.0% of motherboards still use PS2 ports. One colored purple for the PS2 keyboard female port, back side of the MB & the other colored light green, female port, back side of the MB PS2 mouse port. By default, most motherboards have the jumper for PS2 keyboard enabled. Location for this two-pin jumper varies from board to board.
A USB port looks like this:
http://www.rickysays.com/images/usb-port.jpg
The PS2 port's are found in the upper left hand corner of this same picture. This next link will show how to connect USB motherboard jumpers including their wire locations. (Standard for most motherboard USB connections).
Mike
Dec 15, 2008 | VIA P4XB-M Motherboard
SCANNING PROBLEMS
We are major Symbol/Motorola dealers...I can help. I don't understand your question. (By the way, by changing the cable on your keyboard wedge models, you can also use them on the USB ports. Give me a call at 1-866-306-7226, or you can also contact the Help Desk at 1-800-653-5350
Cheers.
Bill Matisz,
qdata inc.
Edmonton, AB
Mar 03, 2008 | Symbol LS2208 Handheld
Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Jan 03, 2008 | Symbol LS 4000i Handheld
A USB mouse will work but the PS/2 mouse failed. What causes it?
Hi melch, On the PS/2 mouse, chances are that the surface mounted fusible link/resistor supplying the +5VDC is open. It is normally very near the PS/2 port and marked [0] or labeled F???. This can be verified by measuring the absence/presence of +5 at pin 4 of the connector. In some cases, it is the I/O chip that gets damaged. Re "only two(2)USB port" aside from the 2 rear USB ports, the Asus CUV4X-C has another pair of USB connectors that are normally connected to the front panel of the casing. It is located very near the motherboard battery. Re "...prompting...high speed USB port...", normally by updating your OS (say XP to SP2) or downloading/installing latest VIA 4 in 1 Drivers should make your USB 2.0 compatible. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Sep 23, 2007 | ASUS VIA Apollo Pro133A Chipset CUV4X-C...
Datalogic Dragon D101
You could use a ps2 splitter cable to connect both the barcode scanner and the keyboard to the pc. You would also have to use the correct scanner codes to ensure that the scanner is configured properly. Alternatively, you could try connecting the scanner with only the ps2 to usb and miss out the extension cable to determine if that is the problem. If the scanner is a ps2 wedge scanner, it will need reprogrammed with the correct scanner codes for usb.
Aug 28, 2007 | Datalogic Dragon D101 (902151240) Portable...
My XP Media Center PC does not recognise the scanner
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port? You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC. If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
Oct 16, 2006 | Symbol CS1504 Handheld Barcode Scanner
Symbol LS 4000 (LS4000-100000) Handheld Logo
384 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
