Question about Nokia 9300 Smartphone
Incomplete booting i got a nokia 9300 from a friend but since then have been able to use it because it does not boot completely
  • 59 Answers
Format your mobile!
To Format your mobile proceed as follow;
Remember the mobile battery should be fully charged!
Take Out the battery & Insert it again! If the mobile is not ON turn it ON then quickly press Ctrl + Shift + F You see a warning msg saying something like! Do you want to format the phone! Press format & your mobile will be restored to its default factory settings.
Posted on Jul 08, 2009
0280:Previous boot incomplete - Default configuration used
Error Code: 0280 Previous boot incomplete - Default configuration used
Message Meanings : Previous POST did not complete successfully. POST loads default values and offers to run Setup. If the failure was caused by incorrect values and they are not corrected, the next boot will likely fail. On system with control of wait states, improper Setup settings can also terminate POST and cause this error on the next boot. Run Setup and verify that wait-state configuration is correct. This error is cleared the next time the system is booted.
What does the above mean ??? If the BIOS does not see a particular device loading ( like Hard Drive ) Try bringing up the Bios setting F-2 and reset to default. Hope this helps
BBBB
If one of the BIOS settings is incorrect or if the system is looking for a particular ggggg
Mar 17, 2014 | Acer Aspire 3100-1405 Notebook
No operating system found on a gateway solo 9300 laptop
if the hard drive has been completely erased then you will need to boot from a windows disc and re-install windows on it.
Jan 08, 2013 | Gateway Solo Pro 9300 series
How to format of nokia 9300i
Welcome to Fixya
This process erases from your Nokia 9300 all of your user data and settings, including your phone book, calendar, email, downloads, recordings, and certain factory installed programs such as Instant Messaging and BlackBerry Connect.
REMEMBER: Create a device data backup or synchronization before formatting.
You can restore device data and settings later. See the Nokia 9300 User Guide for further instructions.
STEP 1 - Format the Nokia 9300 memory
* Remove the battery for 10 seconds
* Replace the battery
* Open the Nokia 9300 to view the inside display
* When you see the screen with "NOKIA" in blue text,
* Press and hold the following four keys until a Format Message is displayed:
CRTL + Shift + F
* Confirm the process by selecting Format
* Formatting will begin
* After formatting is complete the Nokia 9300 will reboot with some basic settings. If prompted, accept the request to reboot
* Follow the instructions on your Nokia 9300 to set the time, date and city and to enter your contact information.
STEP 2 - Download the install-cingular-default-603.SIS to a compatible PC.
STEP 3 - Prepare a Multimedia Memory Card (MMC)1
* Transfer the .sis file from your PC to your device using MMC, data cable, Bluetooth or infrared. For instructions see the Nokia 9300 User Guide.
STEP 4 - Install the file install-cingular-default-603.SIS to your Nokia 93002
Note: This step is required to install Cingular specific settings and programs to your Nokia 9300.
* Insert the Multimeda Memory Card created in Step 2 to your Nokia 9300.
* Replace the battery cover (so the Nokia 9300 can read the MMC)
* Open your device, then open the File Manager:
Press the Desk application key
Scroll to and select Office
Scroll to and open File Manager
* Using the arrow keys, scroll to Memory Card
* Highlight the file install-cingular-default-603.SIS
* Press Open to start the installation process
* Follow and accept all prompts and requests
* Reformatting is now complete
(1) You may choose to install the file above using Nokia PC Suite. Please see the Nokia 9300 User Guide for general instructions to install software using Nokia PC Suite, and follow those instructions instead of Step 4 above.
(2) CAUTION: The .sis file above is ONLY intended for use with a Nokia 9300 with the appropriate software version. DO NOT install this file to a Nokia 9300 with any other software version. DO NOT install this file to any other model device.
Have a good one!
Mar 26, 2011 | Nokia 9300 Handheld
I have nkia 9300. and i forget phone lock pasword of my pphone..how ai recover my pasword
First Remove the Battery.. then Put it back to make a reset..
..then while Your phone is Booting up Press n hold ctr + shift + F .. then it will ask you if you want to format your phone...
Oct 18, 2010 | Nokia 9300 Handheld
How to format my nokia 9300i
CRTL + Shift + F
Oct 14, 2010 | Nokia 9300i Cellular Phone
I've got an Dell Inspiron 9300 LCD
Try running diags Fn + Power button see if anything fails
Since you can boot to the BIOS, then the system is posting, so I suspect you have either a Windows issue or a hard drive issue.
If the HDD passes diagnostics, I'd try booting to the XP CD and see if you can press R for recovery console and run the command CHKDSK /R and see if that resolves
Post back with the results
Jul 19, 2010 | Dell Inspiron 9300 Notebook
Can not install windows 98 on my gateway solo 9300
ok first your gona wana disable that ios password cuz wat that does is it locks some stuff up tht are critical to the system and then go in to your boot seequence and selct first boot device as floppy then 2 cd 3 hard drive and screw the rest then it should work
May 24, 2009 | Gateway Solo 9300 Notebook
Nokia 9300i Won't boot.
Try taking out the battery, putting the original SIM back in. Then reseat the battery again. If the interior screen doesn't come on, insert the power cable before switching on (using the power button on the outside of the case).
That's worked for me in the past.
Dec 20, 2008 | Nokia 9300 Smartphone
Hi i have nokia 9300, but a few days ago cannot send the sms they said system not enough memory. Close some applications and try again. But still cannot i deleted all the inbox, sent and everything but...
ALL YOU HAV TO IS TO FORMAT YOUR NOKIA 9300 USING KEY CTRL+SHIFT+F, YOU MUST TYPE THIS KEY WHEN YOU PHONE STILL APPEARING THE WORD NOKIA ON BOOTING SCREEN DONT WAIT TO SEE THE HANDS IF SO U R LATE
Dec 20, 2008 | Nokia 9300 Handheld
Gateway solo pro 9300 bios password is not remove
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.This is a better way
Dec 15, 2008 | Gateway Solo 9300 Notebook
Nokia 9300 Smartphone Logo
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
