I push play after a recording it plays for about 10 seconds a d turns off. When I turn back on it ejects
  • 10,594 Answers
Please intimate model and brand of unit to understand whats wrong with it and how it can be solved.
Thanks.
Posted on Jun 02, 2009
Sony CDP-C910 will no longer play cds or eject changer cartridge
Mine did the same thing. My player was primarily used in the garage and the cold weather may have caused my player to do the same thing. I just fixed my player. I removed the top cover and looked at the CD in the play position. In the upper right corner from the CD, you will see a spindle motor with a belt on it. Gently spin the motor back and forth carefully with your finger. I rotated it a half-spin in either direction, careful not to dislodge the belt. When I turned the player back on, the mechanism operated as it normally would and began playing the disc. I was able to eject and reinsert the magazine without any issues, solving the problem. Hopefully that will work for you.
Dec 17, 2012 | Sony CDP-C910 10-Disc CD Changer
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
Getting a rec error message whilst trying to eject mini disc
i have just solved the problem get a small flat head screw driver and whilst ejecting put it into the hole where the mini disk goes. now when i say gentle i mean gentle GENTLY feel for the edge of the mini disk you will find it. When you know you have found it very gently and slowly push the mini disk up and down and the disk will pop out you wont damage anything as long as you are slow and gentle. If it doesnt happen first time dont worry it will with patience but dont be heavy with it. The problem is the disk and not the player. you have a corrupt disk which is quiet common. Just throw the disk away. Turn the machine off for 10 seconds and turn back on put another disk in that your not bothered about and you will see that it shoudl play etc try recording onto that disk and you shoudl see that the player is working fine
hope this helps
Oct 08, 2009 | Tascam MD-350 Advanced MiniDisc Recorder
VCR ejecting my cassettes
Try removing the top cover & have a look to see what happens when you put the tape in & press play/rewind etc. Is the take up spool (right hand spool) turning properly or is there slack tape not being taken into the cassette? Are the heads spinning ? I think your problem is more likely to do with the tape not travelling smoothly around the tape path. Possibly the clutch gears need cleaned or the soft brakes may not be dis-engaging properly.
Jul 19, 2009 | Televison & Video
VCR ejects blank tape only
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Oct 09, 2008 | GE Televison & Video
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Play station 3
Push and hold the eject button for at least 10 seconds to force an eject of the disc. After the disc ejects, turn the system off and then back on to resume play. Hope this helps. Good luck.
Jun 22, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
