Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Home air conditioning too cold at "Fan On" setting
When I set the thermostat on my home air conditioner to "Fan On" (rather than auto), the compressor engages no matter what the temperature setting. In other words, it doesn't merely recirculate the air but continues cooling.
  • 614 Answers
Sounds like you have a wire shorted between y and g somewhere. Maybe a bad tstat. email me if you have more problems james3751@gulftel.com and I may be able to walk you thru the troubleshooting
Posted on Jun 04, 2009
    Problem Solver:
  • 10 Answers
You could have some wires touching or a bad t stat. take the cover off t stat after cutting power to furnace either at the furnace or breaker box. take wires off terminals G and R on t stat and wire nut them together return power. the fan should only be running. it compressor comes on with is cut power to furnace un hook all the wires make sure they aren't touching leave R and G together see if compressor comes on if so do the same thing on furnace with a jumper accross R and G. if the compresor comes on again un hook all the stat wires on furnace and t stat and ohm the wires out to see if you have resistance between any of the two wires together. if you do you have a short if the fan comes on by it's self any time while hooking wires on R and G together you have a bad t stat
Posted on Aug 08, 2009
When the air condition reaches the set temperature to cut off the blower motor keeps running and i have the thermostat set to auto on the settings.
check the operators manual but you will probably find that the fan will keep running so that the air in the room is circulated past the thermostat so that the temperature can be monitored and the compressor switched on when the temp reaches the upper limit
May 30, 2016 | Heating & Cooling
My domestic rv ac unit reaches the temp setpoint and the compressor shuts off but not the fan, it just keeps on running. Is this normal or should the fan shut off also?
Set fan setting to auto and not high or low setting. Fan will cycle with compressor after setting set to auto or " au" if a digital thermostat.
Mar 21, 2015 | Dometic Rooftop RV Air Conditioner
Cool will not come on when it's set in auto mode
A thermostat is only a switch, nothing more. It's job is to cut on and off the cooling/heating equipment based on a preset temperature setting. It sends 24-28 volts to a contactor or relay which does the actual closing (turn on) or opening (turn off) the power to the compressor or furnace, and that's all it does. There could be a problem with the other parts of the system. When the space temperature exceeds the preset temperature the thermostat should provide 24-28 volts to the compressor contactor, to start the compressor. The "Auto-on" switch on the thermostat controls the fan only. If there isn't 24-28 volts from the thermostat to the coil of the contactor, the compressor will not operate,
Oct 30, 2013 | Hunter Fan Company 42999B - Heat/Cool...
Do Goodman Split System fans turn off when the compressor shuts off? Is there a setting so the fan stops when the room reaches the desired temperature?
That is the job of the thermostat, but only if the "Fan-on/auto switch is set to auto. Look on your thermostat for the switch.
Aug 22, 2013 | Goodman Heating & Cooling
Where can I get a manual for my Emerson Quiet Cool Room Air Conditioner? Not sure the model, but these #s were on outside of box: 10DC93 784040B OE21M N14421, is on a little sticker on the right...
Let see if I can help. The numbers don't come up so we'll just try your information.
Exhaust - should be closed when using for Air Conditioning
Energy savings turns the fan off with the compressor when set for Air Conditioning
Fan Only means just that (no Air Conditioning)
Fan speeds Quite same as low, Norm same as medium, Super same as High
Temp settings, what the thermostat senses before cycling compressor.
Jul 04, 2011 | Emerson Quiet Kool 10GV13 Air Conditioner
How many wires should be for the thermostat and how they are labeled
most thermostats on a A/C unit have 2 wires attached to them. the thermostat is breaking the current goint o the compressor and fan depending on the temperature you set the A/C unit to. doesn't matter which color lead goes to what terminal.
Dec 17, 2010 | Heating & Cooling
AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Mar 30, 2010 | Dometic Rooftop RV Air Conditioner
Air conditioning runs all the time
I assume this is a manufactured home, this is probably a two transformer system, either your contactor is welded in the on positon or wyou have control wiring issues, (could be the thermostat)
Jul 12, 2009 | Coleman Heating & Cooling
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Heating & Cooling Logo
238 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
