PSP Charging problem
TEST : Take battery out. Plug in to wall. Wait 30+ secs with psp on. if the power turns off, then its the adapter which is broken, which costs about 5$
OTHERWISE:
Your battery needs to be changed. Standard flavor costs bout 8$, extra long lasting spicy flavor costs 16$. (lol, chips)
Seriousley though, after some time, wear, and in some cases, temp. changes, the battery can become so weak, that it will only hold about a 5 second charge. Once you get less than 1 hour play time W/O charger, need to get a new battery.
I have the same trouble. Brand New Battery works in one system fine the faulty system will not run on battery power only when plugged in. Works fine when plugged in. Will only work while plugged in and has a battery in it. Will shut down after a few minutes if running on ac power alone.
