Question about Amana PTH153B35AE Air Conditioner
The unit has quit cooling. The compressor does not seem to be coming on.
Air conditioner will not cool, pth153b35ae. Fan works fine. Compressor does not seem to be coming on.
Check thermostat contacts, possibly not sending signal to pick up
Posted on Jun 02, 2009
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Front unit high cool and high fan not working
just replace the fan ..... its seems there is some voltage problem
Jun 25, 2008 | Dometic Rooftop RV Air Conditioner
Compressor starts then stops after maybe 3 mins
Any error codes? If not there may be a mechanical fault with the compressor/inverter. The unit is possibly short on refrigerant, so the compressor is not getting enough suction cooling from return gas, so may be clicking off on its internal over temp klixon.
all the best
Jul 05, 2010 | Mitsubishi MS-A09WA Split System Air...
AMANA PTH153B35AE PTAC Temp drop??
PTAC temp drop should be 20 to 25 degrees across the coil. They never put a service tap on these units. I sell Amana PTACs. You may be alittle low on gas. Check your air TD and that will tell you. The compressor may be overheating due to lack of cool gas to cool the comp. May need a service tech but get a free estimate first. Rus
Jul 04, 2009 | GE Zoneline AZ55H07D Air Conditioner
Interkool 900 stopped cooling - what to check before calling for service? The unit has worked fine for 4 years. The fan runs, but the unit does not cool the wineroom anymore.
t seems like there is a problem with the thermosat, or the compressor. Its not sensing the temperature being to warm to kick the compressor on and cool it down. OR the compressor itself id dead. Hope I could help.
Wayne
Jun 26, 2009 | Vintage Keeper Interkool 900 Air...
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
Window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
May 03, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Air conditioner fan will not come on and unit will run for 1 minute and stop
You hear the compressor kick in (Hum) but no fan comes on? Will the fan come on when just in fan mode, not cool, or do you have that set-up?
Aug 13, 2008 | Dometic Rooftop RV Air Conditioner
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Cooling
Check if the condensar ( outside fan unit) is getting enough free ventilation. IF there is no free air flow you will mostlikely be triping the unit due to short cycling. Ie the unit is pulling its own discherge air causing the compressor to trip due to high back pressure
Sep 04, 2007 | Haier HPAC9M Air Conditioner
Amana PTH153B35AE Air Conditioner Logo
228 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
