Question about Toshiba Satellite A105 Notebook
Green screen on Toshiba 34N9UXE
My TV brand is TOSHIBA and the model is 34N9UXE , once again I describe the problem as below : 1.When I turn ON without connecting antenna or video cable ,the screen is blue After connecting the antenna or video cable ( it means that we give the signal to TV ) the screen become green, but the sound is normal. 2.Even when I go to menu the screen still green.
  • 53 Answers
You can have a bad CRT, a bad chroma module, either one can show the symptoms you are describing. You will need a TV repair tech for the right diagnosis.
Posted on Jun 02, 2009
Horizontal small green lines, with no visible picture. Toshiba 52xv645u model. Menu screen is visible. Today, the tv works again.
It sounds that the LVDS cable; the cable that connects to its T'Con board to panel have loose contact with its edge connectors. Re-set it once and check. For more information go to http://electronicshelponline.blogspot.com/
Dec 16, 2013 | Toshiba Regza 52XV645U LCD TV
My 40" Toshiba LCD TV (model 40RV525U) won't turn on. While plugged in the green power light constantly blinks, but the TV won't power on. Unplugging the TV stops the power light from blinking, but once...
These blinks are fault indications, and are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. If you're sound in electronics, this will make the repair easy. If you wish to get more details about these blinking codes, check this link. Blinking codes to many brand TVs are described in detail. http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Oct 06, 2013 | Toshiba 40RV525U 40 in. LCD TV
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
Hi Toshiba Team, I have a Toshiba MD20FL1 and need a new remote control. Tried 2 different remotes and none of them worked so far. I know that this Toshiba model is a little old for a TV but I don't...
Hello
You just buy one Philips Universal Remote Control model number [CL 034]. Your Toshiba set is listed in its codes and are given here.
......... 0517 0419 0512 0613
........................... 0719 0112 0506 0111
........................... 0618 0627 0437 0041
................. 0094 0802 0111 0313 0715
Direct Code Entry
1. Press and hold the CODE SEARCH
button until the red indicator stays
on, then release the CODE SEARCH
button.
2. Press and release the desired Mode
button (TV, VCR, etc.). The red
indicator blinks, then stays lit.
3. Enter the 4 digit code from the code
tables. Note: after a valid code entry,
the red indicator turns off. For an
invalid code, the red indicator
flashes.
4. With your device on, press
CHANNEL UP. If the device
responds, no further programming is
required. Note: If some buttons do
not operate your device, try one of
the other codes for your brand
Code Search (by Brand)
Lets you search for a code for a specific
Brand within the Code Library for a
particular manufacturer.
1. Turn on the device (TV, VCR, etc.) to
be controlled.
2. Press and hold the CODE SEARCH
button until the red indicator remains
button.
3. Press and release the desired Mode
indicator blinks off once.
4. Press and release the numeric button
(0-9) corresponding to desired
Manufacturer (see table below).
Note, pressing "0" performs a full
library search same as Device Library
Code Search Method.
5. Press the CHANNEL UP button ((or
POWER or PLAY (VCR only))
repeatedly until the device to be
controlled changes channel.
6. Press and release MUTE to install
the code.
Note, when all codes under a Brand
have been searched the red indicator
flashes rapidly for 3 seconds
Dec 08, 2010 | Toshiba MD20FL1 20 in. TV/DVD Combo
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
TV screen went black/ red blinking light
LOOSE CONNECTIONS ON THE MAIN BOARD! OR CHECK FOR A YELLOW FLAT CAPACITOR IN THE FRONT OF THE MAIN BOARD NEAR THE CRT'S. BURN'T, PART VALUE, 1200PF-2KU
Mar 16, 2009 | Toshiba 50H81 50" Rear Projection...
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Screen remaining black after the TV is turned on
Some newer sets appear that way when there is NO signal to the set. That and my Sony looks like that when the bulb is burned out.
Dec 23, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
TV: vertical colored lines on TOSHIBA TV Model 36ZP46P
HAI,1.REPLACE SOME CAPICTORS IN HORIZONTAL SECTION.
       2.ADJUST FOCUS ON LOD(EHT TRANSFORMER).
       3.REPLACE HORIZONTAL OUTPUT TRANSISTOR.
Jul 05, 2008 | Televison & Video
Toshiba model tz50v61 convergence
need to repleace convergence ic # stk392-110 or stk392-160 on hitachi brand
Mar 16, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba Satellite A105 Notebook Logo
290 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
