Question about Whirlpool GH8155XM Microwave Oven
Microwave troubleshooting... I have a Whirlpool GH microwave which just one day stopped heating.  I unplugged and replugged the device to see if it needed to "reset" prior to executing a basic troubleshooting plan.I found that the magnetron was bad and bought/replaced it.  Now when I turn on the microwave, a loud noise can be heard shortly before the fuse is blown.  I've disconnected the magnetron and started it up and found that it runs fine (other than the fact it does not heat).  Adding back the Mag. again causes the fuse to blow.The channel designed to carry the microwaves to the internal cavity is inaccessible due to spot welded sheilding.  My guess is that there is something wrong with protective circuitry/sensors/or similar that manages the load and use of the Magnetron, but I can't find any troubleshooting tips specific to the sensors, just basic schematics.  Any help would be appreciated.  Microwave is 7 years old with medium to high usage.
  • 1 more comment
  • MWhelp Oct 24, 2007
    It blows the fuse after a few seconds of operation.  The operation is accompanied by a loud humming/buzzing definitely coming from the HV areas...Diode was my next guess as capacitor holds a charge and appears to be working.
    I'll test both and report back.
  • rjsets Sep 09, 2008
    I have a GE JVM1870SK03 Under cabinet microwave. Everything works, but does not heat. It also hums. I've replace the High Capacity Diode. That didn't work. I then changed out the magnetron and still it doesn't heat. I'm thinking that it may be the high voltage transformer? The fuse has never blown in any of my scenarios.
  • sirhock Oct 21, 2008
    Normal operation, but no heat!
My GE spacesaver microwave all of a sudden stopped heating up things. The lights, fan, turntable, etc. work, but nothing is heating up. Any suggestions?
Posted on Dec 26, 2008
  • 473 Answers
If it blows the fuse as soon as you hit the START button, it's almost certainly a shorted high-voltage capacitor.
If it blows a few seconds after you hit the START button, it's probably the high-voltage transformer. You'll possibly also smell a faint electrical burning smell from the rear vent after you shut if off.
If it blows the fuse as soon as it's plugged in, you probably have a shorted door switch, a shorted varistor, or an internally exposed wire shorting to the chassis, etc.
Posted on Oct 23, 2007
  • Craig Shelton
    Craig Shelton Oct 23, 2007
    I would also replace the recitfier (diode) when replacing the capacitor.
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Whirlpool gold microwave model gh6208xrs stopped heating
As a service tech do not attempt to service a MW call a professional or replace there are components within that raise voltage from 120VAC to upwards of 5000VDC leave it alone call a pro
Sep 02, 2014 | Whirlpool Microwave Ovens
Our microwave has stopped heating. The lights and carousel work, but it will not heat. What can I do?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Dec 13, 2010 | Whirlpool MH1160XS Convection/Microwave...
Elctric went off and a little symbol came up that looks kilk a small d and it will not heat .
Just unplug the microwave and leave it for about an hour. Then replug and turn on. That should resolve the problem
Please rate my help++++Thanks for using FIXYA
May 12, 2010 | Whirlpool Accuwave Microwave Oven
Built-in microwave stopped heating repair or replace
Hi, Replace...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 11, 2009 | Whirlpool GH4155XP Microwave Oven
Everything works except the cooking part/no heating/turntable not turning, help!
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
Jan 03, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave doesn't work
The magnetron is dead. it can be replaced if you do it it is cheap if you call a repair guy its cheaper to get a new one.. parts roughly areound $100
Nov 26, 2008 | Whirlpool Microwave Ovens
Microwave stopping working
check the fuse on the microwave. if its busted, something shorted out in the oven that tripps off your breaker. it could be your inverter.
Feb 19, 2008 | Microwave Ovens
Whirlpool GH8155XM Microwave Oven Logo
1,391 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
