Question about MTX T-Form04-05 Chevy Colorado Charcoal w/10'' sub plus amp Car Speaker
Can't remove right front hub assembly
I have all the bolts removed ,for the hub assembly on a 2005 colorado..but can't budge it .. and don't know how to remove the brake speed sensor from the inside of the hub.
  • 518 Answers
HUBS ARE NORMALLY PRESSED ON SO MAYBE YOU WILL HAVE TO PURCHASE A HUB PULLER
Posted on Jun 13, 2009
How to change front wheel bearings on a 4 wheel drive dodge nitro?
HUB AND BEARING
1. Raise and support the vehicle.
2. Remove the tire and wheel assembly.
3. Remove the caliper adapter. Refer to Brakes/Hydraulic/Mechanical/CALIPER, Disc Brake - Removal.
CAUTION: Never allow the disc brake caliper to hang from the brake hose. Damage to the brake hose will result. Provide a suitable support to hang the caliper securely.
4. Remove the disc brake rotor. Refer to Brakes/Hydraulic/Mechanical/ROTOR, Brake - Removal.
5. Remove the wheel speed sensor. Refer to Brakes/Electrical/SENSOR, Wheel Speed - Removal.
Fig. 47: HALF SHAFT BEARING BOLTS
6. Remove the axle shaft nut. (if equipped with four wheel drive)
7. Remove the three mounting bolts (1) for the hub. bearing assembly.
8. Remove the hub/bearing.
Installation
INSTALLATION
Fig. 48: HALF-SHAFT BEARING BOLTS
1. Install the hub/bearing assembly to the vehicle.
2. Install the three mounting bolts (1) for the hub/bearing. Tighten the bolt to 130 N.m (96 ft.Ibs.).
3. Install the axle shaft nut. Tighten the nut to 135 N.m (100 ft.Ibs.). (if equipped with four wheel drive)
4. Install the wheel speed sensor to the hub. Tighten the bolt to 13.5 N.m (10 ft.Ibs.). Refer to Brakes/Electrical/SENSOR, Wheel Speed - Installation .
5. Install the disc brake rotor. Refer to Brakes/Hydraulic/Mechanical/ROTOR. Brake - Installation .
6. Install the disc brake caliper adapter. Tighten the nut to 135 N.m (100 ft.Ibs.). Refer to Brakes/Hydraulic/Mechanical/ROTOR, Brake - Installation .
7. Install the tire and wheel assembly. Refer to Tires and WheelsAYheels - Standard Procedure . 5250a498-52fa-4c0c-8687-d0c1ee25e9f7.jpg Auto Repair Help US
Sep 02, 2014 | 2007-2011 HA590245 Dodge Nitro Front Wheel...
How remove the rotor to change bearing for 2005 chev colorado front
first you remove all the lug nuts and the wheel and tire. To get the rotor off you will need to remove the brake caliper. they are held in with 1/4" hex screws. If you don't have an allen wrench you can use a socket extension to removes these. Once unscrewed the calpet simply lifts off the rotor and the rotor is ready to come off. You will need to remove the axle nut and keeper then the rotor slides off towards you and the wheel bearings will come out with the rotor.
Sep 26, 2011 | 2005 Chevrolet Colorado
How do I get the rear drums off a 2000 Ford focus. I removed the spindle nut,
2000 Ford Focus Drum Removal ProcedureIf removing the drum to service the rear brakes: (note, do not remove hub retaining nut for this procedure)
1. Raise and support vehicle
2. Release the parking brake
3. Remove wheel and tire
4. Disconnect wheel speed sensor wiring harness from wheel knuckle and floor panel.
5. Remove 4 wheel spindle attaching bolts, then the wheel hub and drum assembly from vehicle.
6. Reverse procedure to install noting the following:
a. Torque wheel spindle retaining nut to 49 ft. lbs.
b. Torque wheel/tire assembly to 94 ft. lbs.
2000 Ford Focus Drum Replacement ProcedureIf replacing the drum and wheel bearing assembly:
4. Remove center dust cap.
5. Remove hub retaining nut.
6. Remove drum and hub assembly. Ensure wheel speed sensor ring is not damaged when removing drum/hub (if equipped).
7. Reverse procedure to install noting the following:
a. Inspect and clean wheel speed sensor ring if equipped.
b. When tightening hub retaining nut, rotate the hub assembly in counterclockwise direction.
c. Torque hub retaining nut to 173 ft. lbs.
d. Torque wheel/tire assembly to 94 ft. lbs.
e. Adjust parking brakes as necessary.
Jul 05, 2011 | 2000 Ford Focus
How do I get the rear spindle off so I can replace the emergency brake shoes on my 2006 chrysler pacifica?
Adjustment
  1. Place parking brake lever in -full released- position.
  2. Raise and support vehicle.
  3. Remove plug in parking brake shoe support to access adjuster star-wheel.
  4. Through the access hole, rotate the adjuster star wheel in the following direction to expand the shoes outward against the drum:
    1. Left brake - Rotate star-wheel toward rear of vehicle.
    2. Right brake - Rotate star-wheel toward front of vehicle.
  5. Using an appropriate tool, turn adjuster star wheel until wheel will not rotate (dead lock).
  6. Back off adjuster six detents (teeth).
  7. Rotate wheel, checking for light drag. If drag is too heavy, continue to back off adjuster one detent at a time until light drag is present. Do not back off star-wheel more than 17 detents from wheel lock.
  8. Install access plug.
  9. Adjust opposite wheel parking brake shoes using same method.
  10. Lower vehicle.
  11. Apply and release parking brake lever once to ensure proper operation of parking brakes.
Removal & Installation NOTE The following procedure may be used to remove shoes on either side of the vehicle.
  1. Lock out automatic adjuster in parking brake lever.
  3. Access and remove rear hub and bearing.
  4. Remove parking brake cable bolt at knuckle.
  5. Completely back off parking brake shoe adjustment.
  6. Remove parking brake shoe adjuster spring.
  7. Remove shoe adjuster.
  8. Remove upper brake shoe hold-down clip and pin.
  9. Remove lower brake shoe hold-down clip and pin.
  10. Remove upper and lower shoes with return spring from shoe actuator.
  11. Remove return spring from shoes.
    Fig. View of the actuator (1), support (2), adjuster spring (3), return spring (4), caliper adapter (5), shoes (6), hold-down clips and pins (7) and adjuster (8)
To install:
  1. Install return spring between upper and lower shoes.
    NOTE Before installing shoes on actuator, make sure actuator hooked to rear cable is positioned with word -UP- facing outward.
  2. Install upper and lower shoes with return spring on shoe actuator located on parking brake cable.
  3. Install lower brake shoe hold-down pin through rear of support and lower shoe, then install hold-down clip.
  4. Install upper brake shoe hold-down pin through rear of support and upper shoe, then install hold-down clip.
  5. Install shoe adjuster. Place end of adjuster with star wheel upward.
  6. Install parking brake shoe adjuster spring.
  7. Install bolt securing parking brake cable to knuckle and tighten bolt to 21 ft. lbs. (28 Nm).
  8. Using Brake Shoe Gauge, Special Tool C-3919, or equivalent, measure inside diameter of parking brake drum portion of rotor.
  9. Place Gauge over parking brake shoes at widest point.
  10. Using adjuster star wheel, adjust parking brake shoes until linings on both park brake shoes just touch jaws on gauge. This will give a good preliminary adjustment of parking brake shoes, before a final adjustment is made at end of this procedure.
  11. Install hub and bearing with wheel speed sensor as well as all components necessary to access it.
  12. Lower vehicle.
  13. Unlock automatic adjuster in parking brake lever.
  14. Perform final adjustment of parking brake shoes
  15. Adjustment This vehicle is equipped with permanently sealed rear wheel bearings. There is no periodic lubrication or maintenance recommended for these units.
    1. Raise and support vehicle.
    2. Remove wheel mounting nuts, then tire and wheel assembly.
    3. If equipped with AWD:
      1. Remove cotter pin, nut lock and spring washer from half shaft.
      2. While a helper applies brakes to keep hub from turning, remove hub nut and washer.
    4. Remove brake caliper and rotor from hub and bearing assembly.
      Fig. Hub assembly
    5. Disconnect vehicle wiring harness connector at wheel speed sensor connector.
    6. Unclip wheel speed sensor connector from spare tire mounting support.
    7. Disconnect two sensor cable routing clips on rear suspension crossmember.
    8. Disconnect two sensor cable routing clips along toe link.
    9. Disconnect sensor cable from bracket on brake support.
    10. Completely loosen, but do not remove four bolts fastening hub and bearing in place. Once loosened from threads in hub and bearing, push bolts up against rear of hub and bearing to keep brake support plate in place when hub and bearing is removed.
      Fig. Rear hub and bearing mounting bolts
    11. Pull hub and bearing off knuckle and half shaft (if equipped with AWD), then thread wheel speed sensor cable through hole in brake support plate as it is removed with hub and bearing.
    To install:
    1. Position hub and bearing bolts though rear of knuckle and parking brake support just enough to hold support in place as hub and bearing is installed.
    2. Install hub and bearing by first feeding end of wheel speed sensor cable through hole in bottom of parking brake support. As this is being done, if equipped with AWD, slide hub and bearing onto half shaft. Place hub and bearing through brake support, onto knuckle, lining up mounting bolt holes with bolts and placing wheel speed sensor head at bottom.
    3. Install four bolts fastening hub and bearing in place. Tighten mounting bolts to 60 ft. lbs. (81 Nm).
    4. Place wheel speed sensor cable routing grommet into bracket on parking brake support.
    5. Route wheel speed sensor cable along toe link and rear suspension crossmember connecting routing clips where shown.
    1. Connect vehicle wiring harness to wheel speed sensor connector.
    2. Install brake rotor and caliper.
      1. Install washer and hub nut on end of half shaft.
      2. While a helper applies brakes to keep hub from turning, tighten hub nut to 180 ft. lbs. (244 Nm).
      3. Install spring washer, nut lock and cotter pin on end of half shaft.
    4. Install tire and wheel assembly. Install and tighten wheel mounting nuts to 100 ft. lbs. (135 Nm).
May 18, 2011 | 2006 Chrysler Pacifica
How to replace rear wheel bearing on 2003 hyandia sonata
Hub & Bearing Removal & Installation To Remove:
  1. Release parking brake.
  2. Remove rear wheel assembly.
  3. Remove rear wheel speed sensor from carrier.
  4. Dismount brake caliper and support with mechanic's wire.
  5. Remove brake disc.
  6. Remove 4 axle hub mounting bolts. Special tool 09432-11000 (Typical) hyundai-08-00-6021.gif
  7. Using tool 09432-11000 (or suitable gear puller), remove tone wheel.
  8. Remove carrier.
  9. Remove stakes and remove flange nut.
  10. Support bearing outer race flange and press rear axle hub out.
  11. Using tool 09432-11000 (or suitable puller), remove inner race from axle hub.
To Install:
  1. Apply thin coat of grease to bearing contact surface and hub.
  2. Using and appropriate tool, press bearing into hub. CAUTION
    Do not press against outer race of wheel bearing.
  3. Install flange nut and stake nut until it meets concave portion of spindle.
  4. Install carrier.
  5. Use an appropriate tool to press tone wheel.
  6. Install hub/bearing assembly with rounded portion of outer race facing up.
  7. Install 4 hub/bearing assembly bolts and rotate hub to seat bearing.
  8. Measure wheel bearing starting torque with a spring balance or equivalent device.
    • Starting torque should measure 15.9 in lb (1.8 Nm) or less
  9. Install brake disc.
  10. Mount brake caliper.
  11. Install rear wheel speed sensor to carrier.
  12. Install rear wheel assembly.
Oct 28, 2010 | 2001 Hyundai Sonata
How technical is it to replace a front wheel bearing on a 2005 Pontiac SV6 and can I do it without any specialized tools
you will need a big socket (20 or 21 mm) and 1/2 inch drive to remove axle nut and torque wrench to reinstall. The book DOES call for a special tool to get the hub off the axle, but I have never used one before.
  2. Remove the wheel.
  3. Remove the wheel drive shaft nut.
  4. Remove the brake caliper and wire aside.
  5. Remove the brake rotor.
  6. Disconnect the electrical connector from the wheel speed sensor.
  7. Remove the wheel speed sensor connector from the bracket by depressing the locking tabs.
  8. Remove the 3 hub and bearing assembly bolts.
  9. Install Wheel Hub Removal tool J-42129 to the hub and bearing assembly in order to remove the hub and bearing assembly from the wheel drive shaft.
  10. Remove the hub and bearing assembly from the steering knuckle.
To install:
  1. Install the hub and bearing assembly to the steering knuckle.
  2. Install the 3 hub and bearing assembly bolts and tighten to 85 ft. lbs. (115 Nm).
  3. Install the wheel speed sensor connector into the bracket until the locking tabs click into place.
  4. Connect the electrical connector to the wheel speed sensor.
  5. Install the axle nut to the wheel drive shaft and hand tighten.
  6. Install the brake rotor.
  7. Use a screw driver or similar tool to stop the rotation of the brake rotor.
  8. Tighten the wheel drive shaft nut to 159 ft. lbs. (215 Nm).
  9. Install the brake caliper.
  10. Install the tire and wheel.
Sep 24, 2010 | Pontiac Montana SV6 Cars & Trucks
REMOVAL OF FRONT WHEEL BEARINGS
Front (4 Wheel Drive) To Remove:
  2. Remove or disconnect the following:
    • Tire and wheel assembly
    • Rotor (See: Disc Brake Rotor)
    • Wheel speed sensor and brake hose mounting bracket bolt from the steering knuckle
    • Electrical connection for the wheel speed sensor
    • Front drive halfshaft assembly (See: Halfshaft)
    • Hub and bearing assembly
To Install:
  1. Clean all corrosion or contaminates from the steering knuckle bore and the hub and bearing assembly
  2. Lubricate the steering knuckle bore with wheel bearing grease or the equivalent
  3. Install or connect the following:
    • Hub and bearing assembly mounting bolts and tighten the hub to knuckle bolts; Torque to: 133 ft. lbs. (180 Nm)
    • Wheel speed sensor and brake hose mounting bracket bolt to the steering knuckle and tighten the bolt; Torque to: 106 inch. lbs. (12 Nm)
  4. Torque the lug nuts to specification
  5. Test drive the vehicle to confirm the repairs
Aug 03, 2010 | 2001 Chevrolet Silverado 1500
I need a diagram on front hub and brake assembly for 1999 dodge 1 ton dually 2 wheel drive. the front brake rotor is warped i need to replace it
8–Stud Rotor
  3. Remove the hub extension.
  4. Remove the brake caliper assembly.
  5. Remove the axle nut cotter pin. Remove the axle nut.
  6. Disconnect the ABS wheel speed sensor wire from under the hood. Remove the sensor wire from the frame and steering knuckle, if equipped.
  7. Back off the hub/bearing mounting bolts 1/4 inch each. Then tap the bolts with a hammer to loosen the hub/bearing mounting bolts.
  8. Remove the bolts and remove the hub/bearing assembly.
Sep 16, 2009 | 2000 Dodge Ram 3500
Frt. wheel bearings 2003 h-2
2003 Hummer H2 V8-6.0L VIN U
Wheel Bearing: Service and Repair
WHEEL HUB, BEARING, AND SEAL REPLACEMENT
REMOVAL PROCEDURE
NOTE: Never place vehicle on the ground with the halfshaft removed or the halfshaft nut torqued improperly. Otherwise, bearing seals may become
dislodged causing premature wear and/or damage to the hub and bearing assembly.
1. Raise and support the vehicle. Refer to Vehicle Lifting.
2. Remove the tire and wheel.
3. Remove the rotor.
4. Remove the wheel speed sensor and brake hose mounting bracket bolt from the steering knuckle.
5. Disconnect the electrical connection for the wheel speed sensor.
6. Remove the wheel driveshaft nut retaining cover.
7. Remove the wheel driveshaft assembly retaining nut and washer from the wheel driveshaft assembly.
Disengage the wheel driveshaft from the wheel hub and bearing.
8. Remove the wheel hub and bearing mounting bolts.
9. Remove the wheel hub and bearing and splash shield from the vehicle.
10. Remove the O-ring seal from the steering knuckle bore.
11. Remove the wheel speed sensor from the wheel hub and bearing.
12. Clean and inspect the O-ring seal.
13. Replace the seal it the following conditions exist:
- Nicks
- Cuts
- Dry or brittle
- Compression set
INSTALLATION PROCEDURE
1. Clean all corrosion or contaminates from the steering knuckle bore and the hub and bearing assembly.
2. Lubricate the steering knuckle bore with wheel bearing grease or the equivalent.
3. Install the O-ring to the steering knuckle.
NOTE: Refer to Fastener Notice in Service Precautions.
4. Install the wheel speed sensor to the wheel hub and bearing.
Tighten
Tighten the sensor mounting bolt to 18 N.m (13 lb ft).
5. Install the wheel hub and bearing and splash shield to the vehicle.
6. Install the wheel hub and bearing mounting bolts.
Tighten
Tighten the wheel hub to knuckle bolts to 180 N.m (133 lb ft).
7. Install the nut and washer retaining the wheel drive shaft assembly to the wheel hub and bearing.
Tighten
Tighten the nut to 210 N.m (155 lb ft).
8. Connect the electrical connection for the wheel speed sensor.
9. Install the wheel speed sensor and brake hose mounting bracket bolt to the steering knuckle.
Tighten
Tighten the bolt to 12 N.m (106 lb in).
10. Install the rotor.
11. Install the tire and wheel.
12. Lower the vehicle.
Sep 15, 2009 | 2003 Hummer H2
2005 elantra need answer on removing rotors
REMOVAL:
Loosen the wheel nuts slightly. Raise the front of the vehicle, and make sure it is securely supported.
Remove the front wheel and tire from front hub.
Remove the split pin, then remove castle nut and washer from the front hub while applying the brake.
Remove the caliper mounting bolts, and hang the caliper assembly to one side. To prevent damage to the caliper assembly or brake hose, use a short piece of wire to hang the caliper from the undercarriage.
Remove the wheel speed sensor from the knuckle.
Disconnect the tie rod end ball joint from the knuckle using the special tool (09568-34000).
Remove the split pin.
Remove the castle nut.
Disconnect the ball joint from knuckle using the special tool (09568-34000).
Remove the lower arm ball joint mounting bolts
Remove the strut lower arm mounting bolts
Remove the hub and the knuckle assembly
INSTALLATION:
Reverse the order of the removal procedure.
May 23, 2009 | 2005 Hyundai Elantra
MTX T-Form04-05 Chevy Colorado Charcoal w/10'' sub plus amp Car Speaker Logo
456 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
