Question about Car Audio & Video
Setting clock how do i set the clock on hiace tape deck model number 08600-00928 this is a standard deck for hiace hilux
  • 40 Answers
Turn off power and hold set button use the volume button to turn the hour and min
Posted on Jun 02, 2009
What is the gap setting for a Toyota Hi Ace, 1992 Commuter. Engine Number 2RZ 0248 127
spark plug settings? ' IH8MUD Forum
https://forum.ih8mud.com > ... > Vehicle Tech Forums > 95-older Toyota Truck Tech
  1. Cached
Apr 6, 2007 - i changed my spark plugs and feel my truck is running worse. i was told ... of the gap in my old plugs. any one know if that is the right setting or not? ... ps most Toyota plugs come pre gaped!! hehe!! ... 1992-86 L-4 22RE 1233 .032 9799 .... Flat Land Cruisers · NM- High Desert Cruisers · OK- Green Country ... Missing: ace ‎commuter
TOYOTA ' denso
www.denso.com.au/sparkplug/make/10/toyota
  1. Cached
  2. Similar
150+ items - Model, Engine, Year, Standard Plug, Gap (mm), Iridium Power ... Engine Year Standard Plug ? 3VZE VZN130 V6 1991 on K16RU 3.5L? 2GRFE V6 11/2006 on FK20HR11
Toyota HiAce 89-05 2.4L NGK Spark Plug Set BPR5EY
https://www.fullforceracing.com.au/toyota-hiace-89-05-2-4l-ngk-spark-plug-set-bpr5...
  1. Cached
NGK Spark Plug Set Suitable For Use With -Toyota HiAce 08/89 - 05/05 2.4L ... Notes, It is recommended that all spark plug gaps be checked prior to instalation. Missing: 1992 ‎commuter
Toyota Manuals - Workshop manual store
www.theworkshopmanualstore.com/Toyota-Manuals/index.php
  1. Cached
  2. Similar
Sep 8, 2011 - Keywords: http://www.workshoprepairmanual.com.au/Item/toyota-hi-lux-ln-series- ... It utilized a typical truck setup of A-arms plus coil springs inside front along with .... 2.7559 2.1654 SPARK PLUG SPARK PLUG DISTRIBUTOR IGN. ...... inside 1990 plus 1992) Juha Kankkunen (Champion inside 1993) plus ...
gap setting for Toyota Hi Ace 1992 Commuter Google Search
Nov 15, 2016 | Toyota HiAce Cars & Trucks
How do i remove alternator from 1996 toyota hiace
yes the voltage regulator is separate, please see your other post for response
Toyota Hilux Hiace alternator 36 months warranty
Jun 28, 2015 | Toyota Cars & Trucks
What is the exact number for ngk spark plugs that can last on toyota hiace 3y engine
The spark plug number from Toyota Parts is 9091901059, which crosses to BPR5ES-11 for the standard plug from NGK.
If you are having problems with the plugs burning out to quickly, I would have to ask if this HiAce is a dual fuel model? Maybe they removed the LP system before you bought it, and that's causing the problems your experiencing?
Also the HiAce is an 80's minivan not an '02 Camry.
I hope this helps!
Bob
Dec 25, 2010 | 2002 Toyota Camry
How do I change the time on m Siemens Microwelle plus oven please? Model number HF75960GB
Did you try pushing the clock button, setting the time (eg. 300) for three o'clock, and then push the clock button once more. If this doesn't work, don't push the clock button at the end. Just set it, and let it stay until it stops blinking - and then it should be set. If you need further assistance, let me know and I'll help you. I'm just going by the usual standard of setting clocks on microwave's - but maybe with this model, there's another way. Good Luck to you! - Jim
Mar 28, 2010 | Siemens Microwave Ovens
I need a hook up digram fof an optimus model 31-2025 stereo equalizer
http://support.radioshack.com/support_audio/doc48/48943.htm
Ten-Band Stereo Frequency
Equalizer (310-2025) Connections Faxback Doc. # 48943
Follow these steps to connect the equalizer to your audio system.
CAUTIONS: Use only shielded audio cable with RCA-type connectors (not
supplied). This type of cable is available at your local
RadioShack store.
Before you connect the equalizer, turn off all components in
your audio system and unplug their power cords.
Before you plug in the equalizer's power cord, complete all
connections and be sure the equalizer's POWER button is out.
1. To connect the equalizer to your receiver, connect the receiver's TAPE
OUT jacks to the equalizer's MAIN IN jacks.
Then, connect the equalizer's MAIN OUT jacks to your receiver's TAPE
IN or TAPE MONITOR jacks.
2. You can connect a tape deck to each set of tape jacks (TAPE 1 and TAPE
2) on the back of the equalizer.
To connect each tape deck, connect the equalizer's TAPE OUT jacks to
the tape deck's in jacks. Then, connect the tape deck's out jacks to
the equalizer's TAPE IN jacks.
3. Plug the equalizer's power cord into your receiver's switched power
outlet or any standard AC outlet.
WARNING: The equalizer's power cord has a polarized plug. To prevent
electric shock, do not use an extension cord or other
receptacle unless you can fully and easily insert the plug's
blades.
4. Connect the power cords of all other components.
(wr 08/04/98)
Feb 24, 2010 | Audio Players & Recorders
WAS GIVEN AN ADMIRAL SR3000 VHS, WOULD LIKE TO SET CLOCK
This may sound like a silly question,But have you replaced the battery in the remote?
Jul 06, 2009 | Audio Players & Recorders
Correct Tape Selection button configuration on TEAC V377 Model
Ferric tapes use standard bias and playback. FeCr (ferric-chrome) use standard bias and chrome pb. Chrome tapes use high bias and high playback.
Nov 27, 2008 | Audio Players & Recorders
Help
  1. press and hold the "clock" button. The time should start flashing.
  2. Adjust the hour by using the square silver buttons for "skip backward" or "skip forward" on the CD controls.
  3. Press the "clock" button again so that the minutes are now flashing.
  4. Adjust the minutes with the same buttons used to adjust the hour.
  5. Press the "Prog Set" button to conclude the process.
Oct 27, 2008 | RCA RS2620 Single Cassette Deck
Clock
Turn the system on and press the "Clock/Timer" button (located above the eject button for Deck 1). The clock will appear. To change the time, simply hold down either the < or > buttons (the ones you use to change radio stations and begin CD/tape playback). Press "Clock/Timer" again to lock in the time.
Dec 28, 2007 | RCA RS2622 CD Shelf System
Car Audio & Video Logo
219 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
