Question about Compaq Computers & Internet
Does not display out although Monitor is working fine after checking ram,display card
Specification: Compaq D510 Desktop M\B: D845 Intel Ram: 512 MB Last week,I was doing work on pc suddenly it's power off Although monitor is running but cpu light is off.I check ram,Display and BIOS but i cannot figure out problem.There is no beep or sound.
  • dcs0 Jun 03, 2009
    Phas : "but since you said the CPU light isnt on at all, it will most likely be a dead motherboard"
    some times it sucessfully boot & windows login ,sometimes it counts RAM from 1 to 512 MB during BOOT SCreen,I do not know wat is the problem with this.
  • dcs0 Jun 05, 2009
    Yes i m trying 2 to 3 rams with different size & module but it can't work.
  • 4 Answers
If the power suddenly went from your board it may have caused a short circuit and effectively killed the motherboard. my suggestion would be to get hold of another motherboard and see if you can boot. if not then it will most likely be your RAM. but since you said the CPU light isnt on at all, it will most likely be a dead motherboard
Posted on Jun 02, 2009
  • Phas Jun 04, 2009
    if it is sometimes booting, but other times getting stuck on the RAM count then it could be errornous RAM. my suggestion would be to get a cheap stick of new RAM to test and see if the computer boots fine
I bought new 2gb ddr2 with 800 mhz and its not working on my motherboard d102ggc2 can u plz help me with the solution
i guess you did not check the compatibility of the RAMs to your MB limitations....
the only solution is to return the RAMs and get the RAMs that is supported by your MB.....
the MB (D102GGC2) can hold only a max of 533 mhz and max of 1GB each in each slot of RAM....
so if you are trying to install one 2GB card of 800 mhz IT WIILL NOT WORK....
get TWO RAM cards of 1GB each (total 2GB) of RAM.... each of 400 mhz....
hope this helps...
Reg
Suresh
to check what your MB supports, look for the details below...
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-029352.htm
Intel® Desktop Board D102GGC2 Technical product specification circuit388.gif Product Specification
This product specification applies only to standard D102GGC2 boards with BIOS identifier GC11020M.86A. Changes to this specification will be published in the D102GGC2 Desktop Board Specification Update before being incorporated into a revision of this document.
pdf.gif D102GGC2 Technical Product Specification [PDF]
File Name: D102GGC2_TechProdSpec.pdf
Date: April 2006
This document is an update to the specifications contained in the D102GGC2 Technical Product Specification. It is intended for hardware system manufacturers and software developers of applications, operating systems, or tools. It contains specification changes, errata, specification clarifications, and documentation changes.
pdf.gif D102GGC2 Desktop Board Specification Update [PDF]
File Name: D102GGC2_SpecUpdate03.pdf
Date: November 2006
Apr 27, 2011 | Intel D102GGC2 Motherboard
Is it possible to install windows vista in this computer?
No, it needs at least 1GB of RAM and a much better video card.
Jan 16, 2011 | HP Hewlett Packard Compaq D51S Intel...
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
Hello, my Compaq SR2010NX has had a nissue in rebooting with no video output for a few weeks now, getting worse as time goes by, repeat boot and turning on monitor at specific timestamps in boot up helps...
Hi friend,
Your system RAM is faulty,please replace the RAM with another RAM or if you are using 512/512 MB two RAM,remove the RAM vise a versa(one by one) and check.
Thanks,
Jan 28, 2010 | HP Compaq Presario SR2010NX PC Desktop
My compaq evo d51s is not displaying on the monitor at boot up.
Cleare Bios and replace the RAm if not solved use pci vga card, cirus logic or sis 6326 AGPcard
Nov 02, 2009 | HP Compaq EVO D51S Intel Desktop PC -...
Need video driver embeeded on d845 glly / intell
Intel's website is the best place for this. www.intel.com
Here is a link to all of the drivers for this board.
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel®+845+Chipset+Family+Boards&ProductProduct=Intel®+Desktop+Board+D845GLLY
Make sure you have the chipset drivers installed before you install the 845 integrated graphics driver.
Good luck
Oct 26, 2009 | Intel D845GLLY Motherboard
No display on computer
First thing is do you have a beep when the system boots? Sounds like you may have a BIOS issue I would start there........your RAM and processor are more than likely NOT the problem
Apr 15, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
Intel d845 gvfn display problem.
sir i have a problemmy mother board intell d845 epi/d845gvsr my mother board is cannot desplayed or display is not come but if i remove rame the mother board is give error beaps if i attach ram board is not displayed
Apr 25, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Intel 845 gvsr no display
Intel d845 gvsr no display ,but the ram is ok when i incerted the ram there is no beep and there is no sound. may be bios corupted and how to solve the problem
Mar 09, 2008 | Intel Motherboard
Computers & Internet Logo
77 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
